Ошибка com.mysql.jdbc.CommunicationsException
Имеется ошибка вот такого рода: com.mysql.jdbc.CommunicationsException: The driver was unable to create a connection due to an inability to establish the client portion of a socket. This is usually caused by a limit on the number of sockets imposed by the operating system. This limit is usually configurable. For Unix-based platforms, see the manual page for the 'ulimit' command. Kernel or system reconfiguration may also be required. For Windows-based platforms, see Microsoft Knowledge Base Article 196271 (Q196271). Ошибка возникает при обрабатывании запроса SELECT * FROM tableName. ... |
| 10.08.2012, 16:58:28 |
stacktrace дайте посмотреть. ... |
| 10.08.2012, 17:06:12 |
Это он родимый и есть =) SQL Exception while getting DB connection: com.mysql.jdbc.CommunicationsException: The driver was unable to create a connection due to an inability to establish the client portion of a socket. This is usually caused by a limit on the number of sockets imposed by the operating system. This limit is usually configurable. For Unix-based platforms, see the manual page for the 'ulimit' command. Kernel or system reconfiguration may also be required. For Windows-based platforms, see Microsoft Knowledge Base Article 196271 (Q196271). авг 10, 2012 4:25:48 PM org.apache.catalina.core.StandardWrapperValve invoke SEVERE: Servlet.service() for servlet [by.belgaz.servlet.PersonalAccountSearchServlet] in context with path [/requestsForAlarm] threw exception java.lang.NullPointerException at by.belgaz.impl.GRSImplDB.getGRP(GRSImplDB.java:201) at by.belgaz.impl.AddressImplDB.getPersonalAddress(AddressImplDB.java:92) at by.belgaz.impl.SubscribeImplDB.getPersonsByName(SubscribeImplDB.java:486) at by.belgaz.servlet.PersonalAccountSearchServlet.doGet(PersonalAccountSearchServlet.java:177) at by.belgaz.servlet.PersonalAccountSearchServlet.doPost(PersonalAccountSearchServlet.java:200) at javax.servlet.http.HttpServlet.service(HttpServlet.java:641) at javax.servlet.http.HttpServlet.service(HttpServlet.java:722) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:305) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:210) at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:225) at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:123) at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:472) at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:168) at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:98) at org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:927) at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:118) at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:407) at org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1001) at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:579) at org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.run(JIoEndpoint.java:312) at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source) at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source) at java.lang.Thread.run(Unknown Source) Все что синим цветом выделено - это события, наступающие из-за того что вывелось раньше =) Красный цвет - это мой обработчик ошибок. Код: java 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. 15. 16. 17. 18. 19. 20. 21. ... |
| 10.08.2012, 17:28:00 |
garik_saperЭто он родимый и есть =) Нет, это вы его где-то, по ходу, потеряли. Ааа, ну вот же... Потому что вместо такой фигни: System.err.println("SQL Exception while getting DB connection: " + e); надо писать e.printStackTrace(); или использовать нормальный логгер. garik_saperВсе что синим цветом выделено - это события, наступающие из-за того что вывелось раньше =) Это не так интересно ... |
| 10.08.2012, 17:33:13 |
Вот то, что выдал мне трассировщик e.printStackTrace(); com.mysql.jdbc.CommunicationsException: The driver was unable to create a connection due to an inability to establish the client portion of a socket. This is usually caused by a limit on the number of sockets imposed by the operating system. This limit is usually configurable. For Unix-based platforms, see the manual page for the 'ulimit' command. Kernel or system reconfiguration may also be required. For Windows-based platforms, see Microsoft Knowledge Base Article 196271 (Q196271). at com.mysql.jdbc.Connection.createNewIO(Connection.java:2847) at com.mysql.jdbc.Connection.<init>(Connection.java:1555) at com.mysql.jdbc.NonRegisteringDriver.connect(NonRegisteringDriver.java:285) at java.sql.DriverManager.getConnection(Unknown Source) at java.sql.DriverManager.getConnection(Unknown Source) at by.belgaz.iface.BaseDBIface.getConnection(BaseDBIface.java:31) at by.belgaz.impl.AddressImplDB.getPersonalAddress(AddressImplDB.java:40) at by.belgaz.impl.SubscribeImplDB.getPersonsByName(SubscribeImplDB.java:486) at by.belgaz.servlet.PersonalAccountSearchServlet.doGet(PersonalAccountSearchServlet.java:177) at by.belgaz.servlet.PersonalAccountSearchServlet.doPost(PersonalAccountSearchServlet.java:200) at javax.servlet.http.HttpServlet.service(HttpServlet.java:641) at javax.servlet.http.HttpServlet.service(HttpServlet.java:722) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:305) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:210) at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:225) at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:123) at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:472) at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:168) at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:98) at org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:927) at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:118) at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:407) at org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1001) at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:579) at org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.run(JIoEndpoint.java:312) at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source) at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source) at java.lang.Thread.run(Unknown Source) ... |
| 10.08.2012, 17:47:24 |
Странно что у всех при этом есть ещё вложеное исключение, а у вас нет. ... |
| 10.08.2012, 18:07:07 |
А e.getCause().printStackTrace() ? ... |
| 10.08.2012, 18:07:41 |
Странно, но сегодня такой ошибки нету. Проблемы возникали на SELECT, который выбирал все записи из огромной таблицы. Адски грузился ЦП, а потом опа и все ЦА загружен на 5%, коннекта к БД нету. Открытый коннекшен не закрыт, но нулевой. Т.е. проблема возникла после перезагрузки и решилась очередной перезагрузкой. Видимых неисправностей я не вижу. ... |
| 13.08.2012, 10:51:23 |
start [/forum/topic.php?fid=59&gotonew=1&tid=2131162]: |
25ms |
56ms |
85ms |
| others: | 342ms |
| total: | 572ms |
