Пакетирование и распространение настольных приложений Java
http://www.jetbrains.com/idea/webhelp/configuring-compiler-settings.html там написаноIn the Resource patterns field, update the regular expression that describes extensions of the files to be recognized as resources. Separate individual patterns with semicolons (;) ... |
| 09.09.2012, 23:15:37 |
grasoff.net, сделала,не помогает.Суть в том,что из jar файла запускается,а в IDEA выдает ошибки.Вот такой код: import javax.swing.*; import java.io.BufferedReader; import java.io.IOException; import java.io.InputStream; import java.io.InputStreamReader; import java.util.ArrayList; import java.util.Iterator; import java.util.List; import java.util.Random; public class pass5 { public static void main(String[] args) throws IOException { List<String> list1 = pass5.readTextFromJar("/pass.txt"); Random rand = new Random(); int n = list1.size(); int k = rand.nextInt(n); String result = list1.get(k); if (result.length() >= 6) result = result + (rand.nextInt(9) + 1) + (rand.nextInt(9) + 1); else if (result.length() == 5) result = result + (rand.nextInt(9) + 1) + (rand.nextInt(9) + 1) + (rand.nextInt(9) + 1); else for (int g = 0; g < 4; g++) { int h = rand.nextInt(9) + 1; result = result + h; if (result.length() >= 13) break; } JOptionPane.showMessageDialog(null, result); String s1 = JOptionPane.showInputDialog("Введите ваше имя"); } public static List<String> readTextFromJar(String s) { InputStream is = null; BufferedReader br = null; String line; ArrayList<String> list = new ArrayList<String>(); try { is = pass5.class.getResourceAsStream(s); br = new BufferedReader(new InputStreamReader(is)); while (null != (line = br.readLine())) { if (!((line.length() < 5) || (line.length() > 9) || (line.contains("э") || (line.contains("Э")) || (line.contains("Х")) || (line.contains("х")) || (line.contains("Ж")) || (line.contains("Ё")) || (line.contains("ё")) || (line.contains("Ъ")) || (line.contains("ъ")) || (line.contains("Б")) || (line.contains("Б")) || (line.contains("Ю"))))) list.add(line); } } catch (Exception e) { e.printStackTrace(); } finally { try { if (br != null) br.close(); if (is != null) is.close(); } catch (IOException e) { e.printStackTrace(); } } return list; } } ... |
| 09.09.2012, 23:22:44 |
VilislacisСуть в том,что из jar файла запускается,а в IDEA выдает ошибкиу меня читается файл, но он пустой поэтому из ошибок только Exception in thread "main" java.lang.IllegalArgumentException: n must be positive at java.util.Random.nextInt(Random.java:250) at pass5.main(pass5.java:16) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25) at java.lang.reflect.Method.invoke(Method.java:597) at com.intellij.rt.execution.application.AppMain.main(AppMain.java:120) ... |
| 09.09.2012, 23:34:28 |
grasoff.netу меня читается файл, но он пустойпосле того как *.txt добавлено в ресурсы (как описано выше) ... |
| 09.09.2012, 23:35:41 |
grasoff.net, ... |
| 09.09.2012, 23:40:42 |
а вывод происходит? ... |
| 09.09.2012, 23:41:40 |
Vilislacisgrasoff.net, http://www.sql.ru/forum/actualfile.aspx?id=13137610] Приложенный файл (pass5.jar - 11Kb) ну вот после того как я актуализировал содержимое твоего файла pass.txt в свой файл - у меня в idea всё запускается ок ... |
| 09.09.2012, 23:43:05 |
Vilislacisа вывод происходит?да ... |
| 09.09.2012, 23:43:14 |
grasoff.netVilislacisа вывод происходит?даввод тоже ) после вывода ) ... |
| 09.09.2012, 23:43:32 |
grasoff.netVilislacisgrasoff.net, http://www.sql.ru/forum/actualfile.aspx?id=13137610] Приложенный файл (pass5.jar - 11Kb) ну вот после того как я актуализировал содержимое твоего файла pass.txt в свой файл - у меня в idea всё запускается ок актуализовать-это *.txt добавить в настройки? ... |
| 09.09.2012, 23:48:07 |
Vilislacisgrasoff.netпропущено... ну вот после того как я актуализировал содержимое твоего файла pass.txt в свой файл - у меня в idea всё запускается ок актуализовать-это *.txt добавить в настройки?нет я имел в виду - содержимое файла а так - *.txt надо добавить в resource patterns, если ещё не ) ... |
| 09.09.2012, 23:54:10 |
я так и делала,не помогает ... |
| 09.09.2012, 23:55:39 |
Vilislacisя так и делала,не помогаетскопируй всю строку в resource patterns и здесь покажи ... |
| 09.09.2012, 23:58:10 |
grasoff.net, resource patterns где добавлять?конечно,глупые вопросы,но первый раз работаю с IDEA,толком ничего не знаю тут.Спасибо за помощь) ... |
| 09.09.2012, 23:59:34 |
Vilislacis, ?*.properties;?*.xml;?*.gif;?*.png;?*.jpeg;?*.jpg;?*.html;?*.dtd;?*.tld;?*.ftl;?*.txt ... |
| 10.09.2012, 00:02:03 |
Vilislacis, вот эта строка ... |
| 10.09.2012, 00:02:30 |
Можно про актуализацию содержимого файла поподробнее? ... |
| 10.09.2012, 00:04:06 |
VilislacisVilislacis, ?*.properties;?*.xml;?*.gif;?*.png;?*.jpeg;?*.jpg;?*.html;?*.dtd;?*.tld;?*.ftl;?*.txtа поменяй на *.txt (без вопросика) бред конешно, но мало ли )) ... |
| 10.09.2012, 00:09:03 |
VilislacisМожно про актуализацию содержимого файла поподробнее?что подробнее ) я взял твоё pass5.jar, достал из него pass.txt и скопировал к себе в проект ) а пришли-ка лучше сам проект ... |
| 10.09.2012, 00:09:47 |
start [/forum/topic.php?fid=59&gotonew=1&tid=2130987]: |
83ms |
77ms |
| others: | 291ms |
| total: | 518ms |
