Не запускается ActiveMQ после переноса виртуалки на другую хост-машину, вроде в базе затык
Вопрос: как восстановить функционирование? INFO | Using Persistence Adapter: KahaDBPersistenceAdapter[/opt/apache-activemq-5.6.0/data/kahadb] INFO | KahaDB is version 4 INFO | Recovering from the journal ... INFO | Recovery replayed 1 operations from the journal in 0.024 seconds. ERROR | Failed to start ActiveMQ JMS Message Broker (localhost, null). Reason: java.io.IOException: Negative seek offset java.io.IOException: Negative seek offset at java.io.RandomAccessFile.seek(Native Method) at org.apache.kahadb.page.PageFile.readPage(PageFile.java:866) at org.apache.kahadb.page.Transaction$2.readPage(Transaction.java:446) at org.apache.kahadb.page.Transaction$2.<init>(Transaction.java:437) at org.apache.kahadb.page.Transaction.openInputStream(Transaction.java:4 ... |
| 19.10.2012, 10:00:18 |
Говорят что может дело в ВМ - http://activemq.2283324.n4.nabble.com/Failed-to-fill-batch-td4326152.html ... |
| 23.10.2012, 03:14:26 |
start [/forum/topic.php?fid=59&gotonew=1&tid=2130720]: |
76ms |
48ms |
| others: | 322ms |
| total: | 496ms |
