Context initialization failed
Dobryi denn, pomogite novichku java, zapuskaju svoi projekt naprjmuju cherez tomcat kommandnoi strokoi vsje otlichno rabotaet, hochu sdelat nebolshije izmenenija v srede sping tool suite podkljuchaju etot ze tomcat cherez window preferences Server daet oshibku, ne poimu v chem delo märts 06, 2013 11:22:57 AM org.apache.catalina.core.AprLifecycleListener init INFO: The APR based Apache Tomcat Native library which allows optimal performance in production environments was not found on the java.library.path: C:\Program Files\Java\jdk1.7.0_15\bin;C:\WINDOWS\Sun\Java\bin;C:\WINDOWS\system32;C:\WINDOWS;C:\Program Files (x86)\Estonian ID Card\;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\Program Files\TortoiseSVN\bin;C:\Program Files\Java\jdk1.7.0_15\bin;C:\grails\bin;;. märts 06, 2013 11:22:57 AM org.apache.tomcat.util.digester.SetPropertiesRule begin WARNING: [SetPropertiesRule]{Server/Service/Engine/Host/Context} Setting property 'source' to 'org.eclipse.jst.jee.server:jais' did not find a matching property. märts 06, 2013 11:22:58 AM org.apache.coyote.AbstractProtocolHandler init INFO: Initializing ProtocolHandler ["http-bio-8088"] märts 06, 2013 11:22:58 AM org.apache.coyote.AbstractProtocolHandler init INFO: Initializing ProtocolHandler ["http-bio-8080"] märts 06, 2013 11:22:58 AM org.apache.coyote.AbstractProtocolHandler init INFO: Initializing ProtocolHandler ["ajp-bio-8009"] märts 06, 2013 11:22:58 AM org.apache.catalina.startup.Catalina load INFO: Initialization processed in 773 ms märts 06, 2013 11:22:58 AM org.apache.catalina.core.StandardService startInternal INFO: Starting service Catalina märts 06, 2013 11:22:58 AM org.apache.catalina.core.StandardEngine startInternal INFO: Starting Servlet Engine: Apache Tomcat/7.0.12 märts 06, 2013 11:23:00 AM org.apache.catalina.core.ApplicationContext log INFO: Initializing Spring root WebApplicationContext 11:23:06,168 ERROR ContextLoader:215 - Context initialization failed org.springframework.beans.factory.BeanInitializationException: Could not load properties; nested exception is java.io.FileNotFoundException: class path resource [xtee.properties] cannot be opened because it does not exist at org.springframework.beans.factory.config.PropertyResourceConfigurer.postProcessBeanFactory(PropertyResourceConfigurer.java:78) at org.springframework.context.support.AbstractApplicationContext.invokeBeanFactoryPostProcessors(AbstractApplicationContext.java:663) at org.springframework.context.support.AbstractApplicationContext.invokeBeanFactoryPostProcessors(AbstractApplicationContext.java:638) at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:407) at org.springframework.web.context.ContextLoader.createWebApplicationContext(ContextLoader.java:255) at org.springframework.web.context.ContextLoader.initWebApplicationContext(ContextLoader.java:199) at org.springframework.web.context.ContextLoaderListener.contextInitialized(ContextLoaderListener.java:45) at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:4701) at org.apache.catalina.core.StandardContext$1.call(StandardContext.java:5204) at org.apache.catalina.core.StandardContext$1.call(StandardContext.java:5199) at java.util.concurrent.FutureTask$Sync.innerRun(FutureTask.java:334) at java.util.concurrent.FutureTask.run(FutureTask.java:166) at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145) at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615) at java.lang.Thread.run(Thread.java:722) Caused by: java.io.FileNotFoundException: class path resource [xtee.properties] cannot be opened because it does not exist at org.springframework.core.io.ClassPathResource.getInputStream(ClassPathResource.java:158) at org.springframework.core.io.support.PropertiesLoaderSupport.loadProperties(PropertiesLoaderSupport.java:181) at org.springframework.core.io.support.PropertiesLoaderSupport.mergeProperties(PropertiesLoaderSupport.java:161) at org.springframework.beans.factory.config.PropertyResourceConfigurer.postProcessBeanFactory(PropertyResourceConfigurer.java:69) ... 14 more märts 06, 2013 11:23:06 AM org.apache.catalina.core.StandardContext listenerStart SEVERE: Exception sending context initialized event to listener instance of class org.springframework.web.context.ContextLoaderListener org.springframework.beans.factory.BeanInitializationException: Could not load properties; nested exception is java.io.FileNotFoundException: class path resource [xtee.properties] cannot be opened because it does not exist at org.springframework.beans.factory.config.PropertyResourceConfigurer.postProcessBeanFactory(PropertyResourceConfigurer.java:78) at org.springframework.context.support.AbstractApplicationContext.invokeBeanFactoryPostProcessors(AbstractApplicationContext.java:663) at org.springframework.context.support.AbstractApplicationContext.invokeBeanFactoryPostProcessors(AbstractApplicationContext.java:638) at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:407) at org.springframework.web.context.ContextLoader.createWebApplicationContext(ContextLoader.java:255) at org.springframework.web.context.ContextLoader.initWebApplicationContext(ContextLoader.java:199) at org.springframework.web.context.ContextLoaderListener.contextInitialized(ContextLoaderListener.java:45) at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:4701) at org.apache.catalina.core.StandardContext$1.call(StandardContext.java:5204) at org.apache.catalina.core.StandardContext$1.call(StandardContext.java:5199) at java.util.concurrent.FutureTask$Sync.innerRun(FutureTask.java:334) at java.util.concurrent.FutureTask.run(FutureTask.java:166) at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145) at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615) at java.lang.Thread.run(Thread.java:722) Caused by: java.io.FileNotFoundException: class path resource [xtee.properties] cannot be opened because it does not exist at org.springframework.core.io.ClassPathResource.getInputStream(ClassPathResource.java:158) at org.springframework.core.io.support.PropertiesLoaderSupport.loadProperties(PropertiesLoaderSupport.java:181) at org.springframework.core.io.support.PropertiesLoaderSupport.mergeProperties(PropertiesLoaderSupport.java:161) at org.springframework.beans.factory.config.PropertyResourceConfigurer.postProcessBeanFactory(PropertyResourceConfigurer.java:69) ... 14 more märts 06, 2013 11:23:06 AM org.apache.catalina.core.StandardContext startInternal SEVERE: Error listenerStart märts 06, 2013 11:23:06 AM org.apache.catalina.core.StandardContext startInternal SEVERE: Context [/jais] startup failed due to previous errors märts 06, 2013 11:23:06 AM org.apache.catalina.core.ApplicationContext log INFO: Closing Spring root WebApplicationContext märts 06, 2013 11:23:06 AM org.apache.coyote.AbstractProtocolHandler start INFO: Starting ProtocolHandler ["http-bio-8088"] märts 06, 2013 11:23:06 AM org.apache.coyote.AbstractProtocolHandler start INFO: Starting ProtocolHandler ["http-bio-8080"] märts 06, 2013 11:23:06 AM org.apache.coyote.AbstractProtocolHandler start INFO: Starting ProtocolHandler ["ajp-bio-8009"] märts 06, 2013 11:23:06 AM org.apache.catalina.startup.Catalina start INFO: Server startup in 8301 ms ... |
| 06.03.2013, 14:50:53 |
Caused by: java.io.FileNotFoundException: class path resource [xtee.properties] cannot be opened because it does not exist Вот это основаня проблема, в класспасе нет этого файла. ... |
| 06.03.2013, 14:56:18 |
etot fail realno nahoditsja tam C:\tomcat\tomcat7\apache-tomcat-7.0.12_cas\webapps\jais\WEB-INF\classes ne ponjatno pochemu ne vidit ... |
| 06.03.2013, 15:00:55 |
romanjne ponjatno pochemu ne vidit спринговая конфигурация неправильно на него ссылается, или он лежит не там где надо ... |
| 06.03.2013, 15:24:33 |
romanjetot fail realno nahoditsja tam C:\tomcat\tomcat7\apache-tomcat-7.0.12_cas\webapps\jais\WEB-INF\classes ne ponjatno pochemu ne vidit Вряд ли sping tool suite aka Eclipse, хранит class файлы именно там. Посмотрите свойства проекта. ... |
| 06.03.2013, 15:26:11 |
pomestil xtee.properties v svoi proekt teper vydaet novuju oshibku märts 06, 2013 2:36:06 PM org.apache.catalina.core.AprLifecycleListener init INFO: The APR based Apache Tomcat Native library which allows optimal performance in production environments was not found on the java.library.path: C:\Program Files\Java\jdk1.7.0_15\bin;C:\WINDOWS\Sun\Java\bin;C:\WINDOWS\system32;C:\WINDOWS;C:\Program Files (x86)\Estonian ID Card\;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\Program Files\TortoiseSVN\bin;C:\Program Files\Java\jdk1.7.0_15\bin;C:\grails\bin;;. märts 06, 2013 2:36:06 PM org.apache.tomcat.util.digester.SetPropertiesRule begin WARNING: [SetPropertiesRule]{Server/Service/Engine/Host/Context} Setting property 'source' to 'org.eclipse.jst.jee.server:jais' did not find a matching property. märts 06, 2013 2:36:07 PM org.apache.coyote.AbstractProtocolHandler init INFO: Initializing ProtocolHandler ["http-bio-8088"] märts 06, 2013 2:36:07 PM org.apache.coyote.AbstractProtocolHandler init INFO: Initializing ProtocolHandler ["http-bio-8080"] märts 06, 2013 2:36:07 PM org.apache.coyote.AbstractProtocolHandler init INFO: Initializing ProtocolHandler ["ajp-bio-8009"] märts 06, 2013 2:36:07 PM org.apache.catalina.startup.Catalina load INFO: Initialization processed in 1020 ms märts 06, 2013 2:36:07 PM org.apache.catalina.core.StandardService startInternal INFO: Starting service Catalina märts 06, 2013 2:36:07 PM org.apache.catalina.core.StandardEngine startInternal INFO: Starting Servlet Engine: Apache Tomcat/7.0.12 märts 06, 2013 2:36:08 PM org.apache.catalina.core.StandardContext listenerStart SEVERE: Error configuring application listener of class org.zkoss.zk.ui.http.HttpSessionListener java.lang.ClassNotFoundException: org.zkoss.zk.ui.http.HttpSessionListener at org.apache.catalina.loader.WebappClassLoader.loadClass(WebappClassLoader.java:1676) at org.apache.catalina.loader.WebappClassLoader.loadClass(WebappClassLoader.java:1521) at org.apache.catalina.core.DefaultInstanceManager.loadClass(DefaultInstanceManager.java:415) at org.apache.catalina.core.DefaultInstanceManager.loadClassMaybePrivileged(DefaultInstanceManager.java:397) at org.apache.catalina.core.DefaultInstanceManager.newInstance(DefaultInstanceManager.java:118) at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:4638) at org.apache.catalina.core.StandardContext$1.call(StandardContext.java:5204) at org.apache.catalina.core.StandardContext$1.call(StandardContext.java:5199) at java.util.concurrent.FutureTask$Sync.innerRun(FutureTask.java:334) at java.util.concurrent.FutureTask.run(FutureTask.java:166) at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145) at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615) at java.lang.Thread.run(Thread.java:722) märts 06, 2013 2:36:08 PM org.apache.catalina.core.StandardContext listenerStart SEVERE: Error configuring application listener of class org.jasig.cas.client.session.SingleSignOutHttpSessionListener java.lang.ClassNotFoundException: org.jasig.cas.client.session.SingleSignOutHttpSessionListener at org.apache.catalina.loader.WebappClassLoader.loadClass(WebappClassLoader.java:1676) at org.apache.catalina.loader.WebappClassLoader.loadClass(WebappClassLoader.java:1521) at org.apache.catalina.core.DefaultInstanceManager.loadClass(DefaultInstanceManager.java:415) at org.apache.catalina.core.DefaultInstanceManager.loadClassMaybePrivileged(DefaultInstanceManager.java:397) at org.apache.catalina.core.DefaultInstanceManager.newInstance(DefaultInstanceManager.java:118) at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:4638) at org.apache.catalina.core.StandardContext$1.call(StandardContext.java:5204) at org.apache.catalina.core.StandardContext$1.call(StandardContext.java:5199) at java.util.concurrent.FutureTask$Sync.innerRun(FutureTask.java:334) at java.util.concurrent.FutureTask.run(FutureTask.java:166) at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145) at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615) at java.lang.Thread.run(Thread.java:722) märts 06, 2013 2:36:08 PM org.apache.catalina.core.StandardContext listenerStart SEVERE: Error configuring application listener of class org.springframework.web.context.ContextLoaderListener java.lang.ClassNotFoundException: org.springframework.web.context.ContextLoaderListener at org.apache.catalina.loader.WebappClassLoader.loadClass(WebappClassLoader.java:1676) at org.apache.catalina.loader.WebappClassLoader.loadClass(WebappClassLoader.java:1521) at org.apache.catalina.core.DefaultInstanceManager.loadClass(DefaultInstanceManager.java:415) at org.apache.catalina.core.DefaultInstanceManager.loadClassMaybePrivileged(DefaultInstanceManager.java:397) at org.apache.catalina.core.DefaultInstanceManager.newInstance(DefaultInstanceManager.java:118) at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:4638) at org.apache.catalina.core.StandardContext$1.call(StandardContext.java:5204) at org.apache.catalina.core.StandardContext$1.call(StandardContext.java:5199) at java.util.concurrent.FutureTask$Sync.innerRun(FutureTask.java:334) at java.util.concurrent.FutureTask.run(FutureTask.java:166) at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145) at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615) at java.lang.Thread.run(Thread.java:722) märts 06, 2013 2:36:08 PM org.apache.catalina.core.StandardContext listenerStart SEVERE: Skipped installing application listeners due to previous error(s) märts 06, 2013 2:36:08 PM org.apache.catalina.core.StandardContext startInternal SEVERE: Error listenerStart märts 06, 2013 2:36:08 PM org.apache.catalina.core.StandardContext startInternal SEVERE: Context [/jais] startup failed due to previous errors märts 06, 2013 2:36:08 PM org.apache.coyote.AbstractProtocolHandler start INFO: Starting ProtocolHandler ["http-bio-8088"] märts 06, 2013 2:36:08 PM org.apache.coyote.AbstractProtocolHandler start INFO: Starting ProtocolHandler ["http-bio-8080"] märts 06, 2013 2:36:08 PM org.apache.coyote.AbstractProtocolHandler start INFO: Starting ProtocolHandler ["ajp-bio-8009"] märts 06, 2013 2:36:08 PM org.apache.catalina.startup.Catalina start INFO: Server startup in 1111 ms ... |
| 06.03.2013, 16:40:52 |
start [/forum/topic.php?fid=59&gotonew=1&tid=2129839]: |
45ms |
57ms |
| others: | 277ms |
| total: | 446ms |
