Задачи на Алгоритмы. Решение. Покритикуйте
Задачи на Алгоритмы. Решение. Покритикуйте Problem 1. Given array a of N elements transpose it as follows {a[N-1], a[N-2],…, a[0]} Memory consumption (not including the space for array) – O(1) Running time – O(N) Problem 2. Given sorted arrays a of n elements and b of m elements produce sorted array c of n+m elements that consists of all elements from arrays a and b. Program reads and stores the arrays in files a, b and c one number per line. Memory consumption – O(1) Running time – O(n+m) Problem 3. The following function double rand() returns a random floating point number evenly distributed over interval [0;1). Write an expression (or a function) that returns a) a random integer N so that 7 <= N <= 23 b) a random number N from set {3.5, 4.5, 5.5, …, 13.5} c) a random string from set { “asdf”, “a”, “jkl;”, “cc”, “zaxd” } Problem 4. Given array a of N (N > 1) elements and integer K (0 < K <= N-1) transpose the array as follows {a[K], …, a[N-1], a[0],…, a[K-1]} Memory consumption (not including the space for array) – O(1) Running time – O(N). What data structure(s) can be used to implement the mini-framework for this problem effectively? Problem 5. Write a program that prints all permutations (in any order) of sequence {1, 2, 3, …, N}. Hint: there are N! permutations. Problem 6. Write a program that takes a string as a parameter and prints out all substrings of the following format: <tag>some text</tag>. Here ‘tag’ can be any alphanumeric character string. The input string is assumed not to have nested tags. Hint: regular expressions should be used for string matching What updates will be required in your program in case of nested tags? Код решения наиболее последней версии тут: AlgorithmsSolver - класс алгоритмов AlgorithmsStarter - класс для запуска Скачать дополнительно: a.txt – используется в Problem 2, предполагается нахождение в корне C:\ b.txt – используется в Problem 2, предполагается нахождение в корне C:\ combinatoricslib-2.0.jar – используется в Problem 5 commons-io-2.4.jar – используется в Problem 6 nested_tags.html – используется в Problem 6, предполагается нахождение в корне C:\ ... |
| 13.03.2013, 02:17:01 |
Denis_m1st, Дружище, скачивать файло и подразумевать наличие поделок дяди Билла у всех - моветон. Давай публикуй сюда само "мясо" так сказать, т.е. конкретные методы, реализующие все это, а здешняя публика контекст вокруг всего этого домыслит думаю без проблем. Если что, докинете еще код, главное - ставить разметку Код: java 1. и все будет. Скачивать, запускать и т.д. - это сразу O(n^10) :-) ... |
| 13.03.2013, 09:15:57 |
По-моему, проблема 2 не решена. Потребляемая память O(n+m) вместо O(1); Время исполнения - O(n+m)ln(n+m) ... |
| 13.03.2013, 09:21:48 |
Kostya IlyinovDenis_m1st, Дружище, скачивать файло и подразумевать наличие поделок дяди Билла у всех - моветон. Давай публикуй сюда само "мясо" так сказать, т.е. конкретные методы, реализующие все это, а здешняя публика контекст вокруг всего этого домыслит думаю без проблем. Если что, докинете еще код, главное - ставить разметку Код: java 1. и все будет. Скачивать, запускать и т.д. - это сразу O(n^10) :-) Файло можно не качать, они предоставлены только для удобства. Проделки дяди Билла не должны мешать при оценке решения. Докидать код - моветон. Здешняя публика прекрасно умеет домысливать по src на ideone.com (см. ссылки: AlgorithmsSolver и AlgorithmsStarter). ... |
| 14.03.2013, 07:47:54 |
ivanraПо-моему, проблема 2 не решена. Потребляемая память O(n+m) вместо O(1); Время исполнения - O(n+m)ln(n+m) Есть ли какие-нибудь тулзы, которые выдают результат в виде математической оценки времени исполнения и потребляемой памяти? ... |
| 14.03.2013, 07:57:10 |
Denis_m1st, :-) Вот это было бы здорово. Но увы :-) ... |
| 14.03.2013, 09:38:52 |
Есть ли какие-нибудь тулзы, которые выдают результат в виде математической оценки времени исполнения и потребляемой памяти? http://ru.wikipedia.org/wiki/%D0%9F%D1%80%D0%BE%D0%B1%D0%BB%D0%B5%D0%BC%D0%B0_%D0%BE%D1%81%D1%82%D0%B0%D0%BD%D0%BE%D0%B2%D0%BA%D0%B8 ... |
| 14.03.2013, 10:51:02 |
start [/forum/topic.php?fid=59&gotonew=1&tid=2129792]: |
29ms |
61ms |
88ms |
| others: | 376ms |
| total: | 628ms |
