NetBeans+Java+MSSQL
-------------------------------------------------------------------------------- Прошу помощи. Не могу подцепить базу Код: java 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. 15. 16. 17. 18. 19. 20. 21. 22. 23. 24. 25. 26. 27. 28. 29. 30. 31. 32. 33. 34. 35. 36. 37. 38. 39. 40. 41. 42. 43. 44. 45. 46. 47. 48. 49. 50. 51. 52. 53. 54. 55. 56. 57. 58. 59. 60. 61. 62. 63. 64. 65. 66. 67. 68. 69. 70. 71. 72. 73. 74. 75. 76. 77. 78. 79. 80. 81. 82. 83. 84. 85. 86. 87. 88. 89. 90. 91. 92. 93. 94. 95. 96. 97. 98. 99. 100. 101. 102. 103. 104. 105. 106. 107. 108. 109. 110. 111. 112. 113. 114. 115. 116. 117. 118. 119. 120. После нажатия на кнопку "Выполнить" выдает Exception Код: plaintext at jdbcselgui.JdbcSelGui.selectRecords(JdbcSelGui.java:106) at jdbcselgui.JdbcSelGui$1.actionPerformed(JdbcSelGui.java:73) at javax.swing.AbstractButton.fireActionPerformed(AbstractButto n.java:2018) at javax.swing.AbstractButton$Handler.actionPerformed(AbstractB utton.java:2341) at javax.swing.DefaultButtonModel.fireActionPerformed(DefaultBu ttonModel.java:402) at javax.swing.DefaultButtonModel.setPressed(DefaultButtonModel .java:259) at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(Bas icButtonListener.java:252) at java.awt.Component.processMouseEvent(Component.java:6505) at javax.swing.JComponent.processMouseEvent(JComponent.java:332 1) at java.awt.Component.processEvent(Component.java:6270) at java.awt.Container.processEvent(Container.java:2229) at java.awt.Component.dispatchEventImpl(Component.java:4861) at java.awt.Container.dispatchEventImpl(Container.java:2287) at java.awt.Component.dispatchEvent(Component.java:4687) at java.awt.LightweightDispatcher.retargetMouseEvent(Container. java:4832) at java.awt.LightweightDispatcher.processMouseEvent(Container.j ava:4492) at java.awt.LightweightDispatcher.dispatchEvent(Container.java: 4422) at java.awt.Container.dispatchEventImpl(Container.java:2273) at java.awt.Window.dispatchEventImpl(Window.java:2719) at java.awt.Component.dispatchEvent(Component.java:4687) at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:723) at java.awt.EventQueue.access$200(EventQueue.java:103) at java.awt.EventQueue$3.run(EventQueue.java:682) at java.awt.EventQueue$3.run(EventQueue.java:680) at java.security.AccessController.doPrivileged(Native Method) at java.security.ProtectionDomain$1.doIntersectionPrivilege(Pro tectionDomain.java:76) at java.security.ProtectionDomain$1.doIntersectionPrivilege(Pro tectionDomain.java:87) at java.awt.EventQueue$4.run(EventQueue.java:696) at java.awt.EventQueue$4.run(EventQueue.java:694) at java.security.AccessController.doPrivileged(Native Method) at java.security.ProtectionDomain$1.doIntersectionPrivilege(Pro tectionDomain.java:76) at java.awt.EventQueue.dispatchEvent(EventQueue.java:693) at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDis patchThread.java:244) at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispat chThread.java:163) at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDis patchThread.java:151) at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread. java:147) at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread. java:139) at java.awt.EventDispatchThread.run(EventDispatchThread.java:97 ) ... |
| 07.07.2013, 11:29:26 |
NetBeans+Java+MSSQL
On 07.07.2013 12:29, doctor2008 wrote: > Прошу помощи. Не могу подцепить базу Из-за этого и NullPointerException, что соединение ты не установил. В методе connect() при неудачном соединении ты прячешь причину неудачи, лишь выводя sf.setText("Ошибка соединения..."); и не прерываешь выполнение. В результате получаешь NullPointerException потому что соединения нет, con == null. Как выглядит ошибка соединения? Posted via ActualForum NNTP Server 1.5 ... |
| 07.07.2013, 16:49:53 |
NetBeans+Java+MSSQL
Denis Popov, большое спасибо за отзывчивость. Собственно все что выдает IDE я отобразил. Если Вас не затруднит, помогите решить проблему. Заранее благодарен. ... |
| 08.07.2013, 06:45:52 |
NetBeans+Java+MSSQL
On 08.07.2013 07:45, doctor2008 wrote: > Собственно все что выдает IDE я отобразил. Если Вас не затруднит, помогите решить проблему. Заранее благодарен. Измени код в методе connect() чтобы увидеть ошибку соединения, или посмотри дебагером. Posted via ActualForum NNTP Server 1.5 ... |
| 08.07.2013, 08:07:29 |
NetBeans+Java+MSSQL
Denis Popov, почему не поддерживается. У меня 2008. com.microsoft.sqlserver.jdbc.SQLServerException: The server version is not supported. The target server must be SQL Server 2000 or later. at com.microsoft.sqlserver.jdbc.SQLServerException.makeFromDriverError(Unknown Source) at com.microsoft.sqlserver.jdbc.DBComms.Prelogin(Unknown Source) at com.microsoft.sqlserver.jdbc.DBComms.<init>(Unknown Source) at com.microsoft.sqlserver.jdbc.SQLServerConnection.connect(Unknown Source) at com.microsoft.sqlserver.jdbc.SQLServerDriver.connect(Unknown Source) at java.sql.DriverManager.getConnection(DriverManager.java:579) at java.sql.DriverManager.getConnection(DriverManager.java:221) at jdbcselgui.JdbcSelGui.connect(JdbcSelGui.java:94) at jdbcselgui.JdbcSelGui$1.actionPerformed(JdbcSelGui.java:72) at javax.swing.AbstractButton.fireActionPerformed(AbstractButton.java:2018) at javax.swing.AbstractButton$Handler.actionPerformed(AbstractButton.java:2341) at javax.swing.DefaultButtonModel.fireActionPerformed(DefaultButtonModel.java:402) at javax.swing.DefaultButtonModel.setPressed(DefaultButtonModel.java:259) at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(BasicButtonListener.java:252) at java.awt.Component.processMouseEvent(Component.java:6505) at javax.swing.JComponent.processMouseEvent(JComponent.java:3321) at java.awt.Component.processEvent(Component.java:6270) at java.awt.Container.processEvent(Container.java:2229) at java.awt.Component.dispatchEventImpl(Component.java:4861) at java.awt.Container.dispatchEventImpl(Container.java:2287) at java.awt.Component.dispatchEvent(Component.java:4687) at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4832) at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4492) at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4422) at java.awt.Container.dispatchEventImpl(Container.java:2273) at java.awt.Window.dispatchEventImpl(Window.java:2719) at java.awt.Component.dispatchEvent(Component.java:4687) at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:723) at java.awt.EventQueue.access$200(EventQueue.java:103) at java.awt.EventQueue$3.run(EventQueue.java:682) at java.awt.EventQueue$3.run(EventQueue.java:680) at java.security.AccessController.doPrivileged(Native Method) at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:76) at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:87) at java.awt.EventQueue$4.run(EventQueue.java:696) at java.awt.EventQueue$4.run(EventQueue.java:694) at java.security.AccessController.doPrivileged(Native Method) at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:76) at java.awt.EventQueue.dispatchEvent(EventQueue.java:693) at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:244) at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:163) at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:151) at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:147) at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:139) at java.awt.EventDispatchThread.run(EventDispatchThread.java:97) Exception in thread "AWT-EventQueue-0" java.lang.NullPointerException at jdbcselgui.JdbcSelGui.selectRecords(JdbcSelGui.java:105) at jdbcselgui.JdbcSelGui$1.actionPerformed(JdbcSelGui.java:73) at javax.swing.AbstractButton.fireActionPerformed(AbstractButton.java:2018) at javax.swing.AbstractButton$Handler.actionPerformed(AbstractButton.java:2341) at javax.swing.DefaultButtonModel.fireActionPerformed(DefaultButtonModel.java:402) at javax.swing.DefaultButtonModel.setPressed(DefaultButtonModel.java:259) at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(BasicButtonListener.java:252) at java.awt.Component.processMouseEvent(Component.java:6505) at javax.swing.JComponent.processMouseEvent(JComponent.java:3321) at java.awt.Component.processEvent(Component.java:6270) at java.awt.Container.processEvent(Container.java:2229) at java.awt.Component.dispatchEventImpl(Component.java:4861) at java.awt.Container.dispatchEventImpl(Container.java:2287) at java.awt.Component.dispatchEvent(Component.java:4687) at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4832) at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4492) at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4422) at java.awt.Container.dispatchEventImpl(Container.java:2273) at java.awt.Window.dispatchEventImpl(Window.java:2719) at java.awt.Component.dispatchEvent(Component.java:4687) at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:723) at java.awt.EventQueue.access$200(EventQueue.java:103) at java.awt.EventQueue$3.run(EventQueue.java:682) at java.awt.EventQueue$3.run(EventQueue.java:680) at java.security.AccessController.doPrivileged(Native Method) at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:76) at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:87) at java.awt.EventQueue$4.run(EventQueue.java:696) at java.awt.EventQueue$4.run(EventQueue.java:694) at java.security.AccessController.doPrivileged(Native Method) at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:76) at java.awt.EventQueue.dispatchEvent(EventQueue.java:693) at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:244) at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:163) at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:151) at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:147) at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:139) at java.awt.EventDispatchThread.run(EventDispatchThread.java:97) ... |
| 08.07.2013, 08:24:10 |
NetBeans+Java+MSSQL
doctor2008, На просторах интернета по вашей ошибки пишут следующие: авторAfter spending some time , I found that this issue will normally occur when you are using a older verison of JDBC driver to connect to sql server 2008. So make sure you are using sql server 2008 JDBC driver and you do not have sqlserver 2005 JDBC drivers in the classpath or in server/default/lib folder. When you download the SQlserver 2008 JDBC driver from the Microsoft website, you will get two jar files: sqljdbc4.jar and sqljdbc.jar. For JDK5 – use sqljdbc.jar for JDK6 – use sqljdbc4.jar When you JDK1.5 and trying to load sqljdbc4.jar, you might get the below exception.So use sqljdbc.jar[2008] ... |
| 08.07.2013, 09:21:33 |
NetBeans+Java+MSSQL
GregTk, Засада...Пути прописаны, драйвер скачан здесь: Скачать Драйвер Microsoft JDBC 4.0 для SQL Server с официального сайта... Драйвер JDBC 4.0 для SQL Server доступен для бесплатной загрузки всеми пользователями SQL Server; он обеспечивает доступ к Microsoft® SQL Server® 2012, SQL Server 2008 R2, SQL Server 2008, SQL Server 2005 и SQL Azure из любого приложения Java... microsoft.com›ru-RU/download/details.aspx… ... |
| 08.07.2013, 09:49:03 |
NetBeans+Java+MSSQL
On 08.07.2013 10:49, doctor2008 wrote: > Засада...Пути прописаны, драйвер скачан здесь: Строка коннекта правильная? Вот тут: http://msdn.microsoft.com/en-us/library/ms378428.aspx не сказано что после порта через двоеточие указывается база. Попробуй может: jdbc:sqlserver://localhost:1433l;database=SDO И проверь что используется действительно нужный драйвер. Posted via ActualForum NNTP Server 1.5 ... |
| 08.07.2013, 12:15:43 |
NetBeans+Java+MSSQL
On 08.07.2013 13:15, Denis Popov wrote: > jdbc:sqlserver://localhost:1433l;database=SDO Точнее: jdbc:sqlserver://localhost:1433l;databaseName=SDO Posted via ActualForum NNTP Server 1.5 ... |
| 08.07.2013, 12:17:09 |
NetBeans+Java+MSSQL
Denis Popov, спасибо, всё получилось. Возникла следующая проблема: при запросе не выводит данные из таблицы(соединение установлено) com.microsoft.sqlserver.jdbc.SQLServerException: Индекс 0 находится вне диапазона. at com.microsoft.sqlserver.jdbc.SQLServerException.makeFromDriverError(SQLServerException.java:190) at com.microsoft.sqlserver.jdbc.SQLServerResultSet.verifyValidColumnIndex(SQLServerResultSet.java:531) at com.microsoft.sqlserver.jdbc.SQLServerResultSet.getterGetColumn(SQLServerResultSet.java:2049) at com.microsoft.sqlserver.jdbc.SQLServerResultSet.getObject(SQLServerResultSet.java:2356) at jdbcselgui.DBTableModel.insertFromDB(DBTableModel.java:85) at jdbcselgui.JdbcSelGui.selectRecords(JdbcSelGui.java:109) at jdbcselgui.JdbcSelGui$1.actionPerformed(JdbcSelGui.java:74) at javax.swing.AbstractButton.fireActionPerformed(AbstractButton.java:2018) at javax.swing.AbstractButton$Handler.actionPerformed(AbstractButton.java:2341) at javax.swing.DefaultButtonModel.fireActionPerformed(DefaultButtonModel.java:402) at javax.swing.DefaultButtonModel.setPressed(DefaultButtonModel.java:259) at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(BasicButtonListener.java:252) at java.awt.Component.processMouseEvent(Component.java:6505) at javax.swing.JComponent.processMouseEvent(JComponent.java:3321) at java.awt.Component.processEvent(Component.java:6270) at java.awt.Container.processEvent(Container.java:2229) at java.awt.Component.dispatchEventImpl(Component.java:4861) at java.awt.Container.dispatchEventImpl(Container.java:2287) at java.awt.Component.dispatchEvent(Component.java:4687) at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4832) at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4492) at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4422) at java.awt.Container.dispatchEventImpl(Container.java:2273) at java.awt.Window.dispatchEventImpl(Window.java:2719) at java.awt.Component.dispatchEvent(Component.java:4687) at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:723) at java.awt.EventQueue.access$200(EventQueue.java:103) at java.awt.EventQueue$3.run(EventQueue.java:682) at java.awt.EventQueue$3.run(EventQueue.java:680) at java.security.AccessController.doPrivileged(Native Method) at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:76) at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:87) at java.awt.EventQueue$4.run(EventQueue.java:696) at java.awt.EventQueue$4.run(EventQueue.java:694) at java.security.AccessController.doPrivileged(Native Method) at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:76) at java.awt.EventQueue.dispatchEvent(EventQueue.java:693) at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:244) at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:163) at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:151) at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:147) at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:139) at java.awt.EventDispatchThread.run(EventDispatchThread.java:97) ... |
| 08.07.2013, 13:55:26 |
NetBeans+Java+MSSQL
В JDBC всё считается от 1, а не от 0. Как выглядит insertFromDB() остаётся только догадываться. ... |
| 08.07.2013, 13:59:52 |
start [/forum/search_topic.php?author=%D0%BD%D0%B5+%D0%BC%D0%BE%D0%B3%D1%83+%D0%BD%D0%B0%D0%B9%D1%82%D0%B8+%D0%BE%D1%82%D0%B2%D0%B5%D1%82&author_mode=last_posts&do_search=1]: |
31ms |
30ms |
25ms |
25ms |
25ms |
27ms |
25ms |
70ms |
73ms |
| others: | 14377ms |
| total: | 15000ms |
