A fatal error has been detected by the Java Runtime Environment
Доброго дня коллеги! Падает JRE, выдает следующее. JRE# # A fatal error has been detected by the Java Runtime Environment: # # EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x776f74b7, pid=5424, tid=9752 # # JRE version: 7.0_09-b05 # Java VM: Java HotSpot(TM) Client VM (23.5-b02 mixed mode, sharing windows-x86 ) # Problematic frame: # C [ntdll.dll+0x374b7] LdrUnlockLoaderLock+0x87b # # Failed to write core dump. Call to MiniDumpWriteDump() failed # # If you would like to submit a bug report, please visit: # http://bugreport.sun.com/bugreport/crash.jsp # The crash happened outside the Java Virtual Machine in native code. # See problematic frame for where to report the bug. # --------------- T H R E A D --------------- Current thread (0x4c9cb400): JavaThread "RMI TCP Connection(575)-127.0.0.1" daemon [_thread_in_native, id=9752, stack(0x65040000,0x65140000)] siginfo: ExceptionCode=0xc0000005, reading address 0x000000d8 Registers: EAX=0x00000000, EBX=0x4c827f30, ECX=0x34003400, EDX=0x4c827f30 ESP=0x6513e834, EBP=0x6513e870, ESI=0x34003400, EDI=0x340034e0 EIP=0x776f74b7, EFLAGS=0x00010202 Top of Stack: (sp=0x6513e834) 0x6513e834: 1abc78c1 0045a1e8 4c6d2e20 34003400 0x6513e844: 340034e0 34003400 00000000 4c6d2e20 0x6513e854: fffffffe 6513e834 6513e3fc 6513f54c 0x6513e864: 77731ecd 08c14299 fffffffe 6513e8ac 0x6513e874: 776f73ed 00000000 010a0000 4c827f48 0x6513e884: 4c9cb400 d72421b0 04030006 00000017 0x6513e894: 4c827f48 6513e888 d4b463c8 4c827f30 0x6513e8a4: 00000003 34003400 6513e8c4 776ee003 Instructions: (pc=0x776f74b7) 0x776f7497: 19 6a ff ff 8b da 8b f1 89 75 d8 8b 03 89 45 e0 0x776f74a7: 8b 7b 08 4f 4f c1 e7 04 03 fe 89 7d d4 8b 46 24 0x776f74b7: 66 83 b8 d8 00 00 00 00 0f 85 11 6f 03 00 0f b7 0x776f74c7: 47 04 89 45 dc 83 f8 02 0f 87 3b c0 00 00 53 6a Register to memory mapping: EAX=0x00000000 is an unknown value EBX=0x4c827f30 is an unknown value ECX=0x34003400 is an unallocated location in the heap EDX=0x4c827f30 is an unknown value ESP=0x6513e834 is pointing into the stack for thread: 0x4c9cb400 EBP=0x6513e870 is pointing into the stack for thread: 0x4c9cb400 ESI=0x34003400 is an unallocated location in the heap EDI=0x340034e0 is an unallocated location in the heap Stack: [0x65040000,0x65140000], sp=0x6513e834, free space=1018k Native frames: (J=compiled Java code, j=interpreted, Vv=VM code, C=native code) C [ntdll.dll+0x374b7] LdrUnlockLoaderLock+0x87b C [ntdll.dll+0x373ed] LdrUnlockLoaderLock+0x7b1 C [ntdll.dll+0x2e003] RtlFreeHeap+0x7e C [kernel32.dll+0x114dd] HeapFree+0x14 C [msvcr100.dll+0x1016a] free+0x1c C [net.dll+0x3287] Java_java_net_SocketInputStream_socketRead0+0x1e7 Java frames: (J=compiled Java code, j=interpreted, Vv=VM code) j java.net.SocketInputStream.socketRead0(Ljava/io/FileDescriptor;[BIII)I+0 j java.net.SocketInputStream.read([BIII)I+79 j java.net.SocketInputStream.read([BII)I+11 j java.io.BufferedInputStream.fill()V+175 J java.io.BufferedInputStream.read()I j java.io.DataInputStream.readInt()I+4 j sun.rmi.transport.tcp.TCPTransport$ConnectionHandler.run0()V+100 j sun.rmi.transport.tcp.TCPTransport$ConnectionHandler.run()V+50 J java.util.concurrent.ThreadPoolExecutor.runWorker(Ljava/util/concurrent/ThreadPoolExecutor$Worker;)V j java.util.concurrent.ThreadPoolExecutor$Worker.run()V+5 j java.lang.Thread.run()V+11 v ~StubRoutines::call_stub Есть у кого соображения? Заранее благодарен. ... |
| 26.07.2013, 10:11:53 |
Всё время вот тут падает C [ntdll.dll+0x374b7] LdrUnlockLoaderLock+0x87b или разные stacktrace бывают? ... |
| 26.07.2013, 10:23:15 |
Если ntdll.dll поврежден - 99% вирус. Если не поврежден - проверить железо. Другие программы не падают? ... |
| 26.07.2013, 11:07:17 |
BlazkowiczВсё время вот тут падает C [ntdll.dll+0x374b7] LdrUnlockLoaderLock+0x87b или разные stacktrace бывают? Падает переодически, но это единственный случай, когда удалось получить хоть какой то лог... ... |
| 26.07.2013, 12:09:51 |
ivanraЕсли ntdll.dll поврежден - 99% вирус. Если не поврежден - проверить железо. Другие программы не падают? У меня тоже подозрение на железо. Других программ там не запускается. Но, есть два варианта этой программы, один написан на Java, другой на C++ или Modula2(точно не знаю) и падают оба варианта через несколько часов работы. Дело точно не Java, просто была надежда, что кто то встречал подобное... ... |
| 26.07.2013, 12:15:52 |
ЕвгенийВ, Нужно такие побольше подобных краш логов собрать и сравнить. Попробуйте поменять сетевуху. Дело точно не в Java. ... |
| 26.07.2013, 12:22:23 |
BlazkowiczЕвгенийВ, Нужно такие побольше подобных краш логов собрать и сравнить. Попробуйте поменять сетевуху. Дело точно не в Java. Спасибо! Я тоже думал о сетевухе! ... |
| 26.07.2013, 12:29:26 |
7.0_09 - довольно старая сборка. Я бы прежде всего обновил ее. ... |
| 26.07.2013, 14:01:58 |
start [/forum/topic.php?fid=59&gotonew=1&tid=2128923]: |
52ms |
69ms |
| others: | 280ms |
| total: | 476ms |
