Как прикрутить RichFaces к JSF2 ?
Не получается запустить проект в єклипсе после добавления RichFaces тут эклипсу все нравится, никаких предупреждений Код: xml 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. 15. 16. 17. web.xml Код: xml 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. 15. 16. 17. 18. 19. 20. 21. 22. 23. 24. 25. 26. 27. 28. 29. 30. 31. 32. 33. 34. 35. 36. 37. 38. 39. 40. 41. 42. и библиотеки как написано в руководстве RichFaces libraries • richfaces-core-api.jar • richfaces-core-impl.jar • richfaces-components-api.jar • richfaces-components-ui.jar The framework depends on third-party dependencies which can be classified to mandatory and optional (libraries enabling certain functionality). Note that these dependencies may depend on their own runtime dependencies. Mandatory third-party dependencies • Google Guava • guava.jar(version 10.0.1) • CSS Parser • cssparser.jar(version 0.9.5) • Simple API for CSS • sac.jar(version 1.3) но при запуске SEVERE: A child container failed during start java.util.concurrent.ExecutionException: org.apache.catalina.LifecycleException: Failed to start component [StandardEngine[Catalina].StandardHost[localhost]] at java.util.concurrent.FutureTask$Sync.innerGet(Unknown Source) at java.util.concurrent.FutureTask.get(Unknown Source) at org.apache.catalina.core.ContainerBase.startInternal(ContainerBase.java:1123) at org.apache.catalina.core.StandardEngine.startInternal(StandardEngine.java:302) at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:150) at org.apache.catalina.core.StandardService.startInternal(StandardService.java:443) at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:150) at org.apache.catalina.core.StandardServer.startInternal(StandardServer.java:732) at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:150) at org.apache.catalina.startup.Catalina.start(Catalina.java:684) ... |
| 19.12.2013, 18:20:46 |
rema174SEVERE: A child container failed during start java.util.concurrent.ExecutionException: org.apache.catalina.LifecycleException: Failed to start component [StandardEngine[Catalina].StandardHost[localhost]] at java.util.concurrent.FutureTask$Sync.innerGet(Unknown Source) at java.util.concurrent.FutureTask.get(Unknown Source) at org.apache.catalina.core.ContainerBase.startInternal(ContainerBase.java:1123) at org.apache.catalina.core.StandardEngine.startInternal(StandardEngine.java:302) at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:150) at org.apache.catalina.core.StandardService.startInternal(StandardService.java:443) at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:150) at org.apache.catalina.core.StandardServer.startInternal(StandardServer.java:732) at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:150) at org.apache.catalina.startup.Catalina.start(Catalina.java:684) Учитесь читать логи и находить в них root cause exception. LifecycleException это лишь следствие ошибок залогировных выше. ... |
| 19.12.2013, 18:23:02 |
start [/forum/topic.php?fid=59&gotonew=1&tid=2127946]: |
25ms |
101ms |
23ms |
81ms |
| others: | 327ms |
| total: | 606ms |
