массив: 10 городов 365 дней
Пытаюсь вытащить температуру 10 городов за 365 дней. результат нечетабельный и выходит за пределы массива 10. toString метод не получается использовать. public class NewClass { int [][] temparature = new int [10][365]; public void nur() { for (int i = 0; i <= temparature.length; i ++){ for (int y = 0; y <= temparature[i].length; y++) { temparature[i][y] = (int)(Math.random()*1); System.out.println("temper [i] = " + temparature[i] + " temper[y] = " +temparature[y]); } } } } public class Main { public static void main(String[] args) { NewClass n = new NewClass(); n.nur(); } } результат: run: temper [i] = [I@93dcd temper[y] = [I@93dcd temper [i] = [I@93dcd temper[y] = [I@b89838 temper [i] = [I@93dcd temper[y] = [I@111a3ac temper [i] = [I@93dcd temper[y] = [I@110b053 temper [i] = [I@93dcd temper[y] = [I@a83b8a temper [i] = [I@93dcd temper[y] = [I@dd20f6 temper [i] = [I@93dcd temper[y] = [I@19efb05 temper [i] = [I@93dcd temper[y] = [I@723d7c temper [i] = [I@93dcd temper[y] = [I@22c95b temper [i] = [I@93dcd temper[y] = [I@1d1acd3 Exception in thread "main" java.lang.ArrayIndexOutOfBoundsException: 10 at javaapplication15.NewClass.nur(NewClass.java:8) at javaapplication15.Main.main(Main.java:8) Java Result: 1 BUILD SUCCESSFUL (total time: 0 seconds) ... |
| 19.01.2014, 00:57:22 |
Arkadi, Код: java 1. ... |
| 19.01.2014, 06:28:52 |
Usman, че то ступил, да понял. Спасибо! ... |
| 19.01.2014, 10:18:17 |
start [/forum/topic.php?fid=59&gotonew=1&tid=2127799]: |
27ms |
83ms |
25ms |
103ms |
| others: | 339ms |
| total: | 631ms |
