com.mysql.jdbc.exceptions.jdbc4.CommunicationsException: Communications link failure
При каждом запросе такая ошибка в логах. Тем не менее, приложение продолжает работать. Не понятно, из-за чего это? Tomcat6, MySQL5.1, JDBC get error com.mysql.jdbc.exceptions.jdbc4.CommunicationsException: Communications link failure The last packet successfully received from the server was 65,205 milliseconds ago. The last packet sent successfully to the server was 1 milliseconds ago. at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method) at sun.reflect.NativeConstructorAccessorImpl.newInstance(Unknown Source) at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(Unknown Source) at java.lang.reflect.Constructor.newInstance(Unknown Source) at com.mysql.jdbc.Util.handleNewInstance(Util.java:411) at com.mysql.jdbc.SQLError.createCommunicationsException(SQLError.java:1121) at com.mysql.jdbc.MysqlIO.reuseAndReadPacket(MysqlIO.java:3603) at com.mysql.jdbc.MysqlIO.reuseAndReadPacket(MysqlIO.java:3492) at com.mysql.jdbc.MysqlIO.checkErrorPacket(MysqlIO.java:4043) at com.mysql.jdbc.MysqlIO.sendCommand(MysqlIO.java:2503) at com.mysql.jdbc.MysqlIO.sqlQueryDirect(MysqlIO.java:2664) at com.mysql.jdbc.ConnectionImpl.execSQL(ConnectionImpl.java:2809) at com.mysql.jdbc.ConnectionImpl.execSQL(ConnectionImpl.java:2758) at com.mysql.jdbc.StatementImpl.executeQuery(StatementImpl.java:1612) at data.WorkDao.allWorks(WorkDao.java:37) at control.ManagerBean.getWorks(ManagerBean.java:45) at sun.reflect.GeneratedMethodAccessor26.invoke(Unknown Source) at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source) at java.lang.reflect.Method.invoke(Unknown Source) at javax.el.BeanELResolver.getValue(BeanELResolver.java:83) at javax.el.CompositeELResolver.getValue(CompositeELResolver.java:54) at com.sun.faces.el.FacesCompositeELResolver.getValue(FacesCompositeELResolver.java:71) at org.jboss.el.parser.AstPropertySuffix.getValue(AstPropertySuffix.java:53) at org.jboss.el.parser.AstValue.getValue(AstValue.java:67) at org.jboss.el.ValueExpressionImpl.getValue(ValueExpressionImpl.java:186) at com.sun.faces.facelets.el.TagValueExpression.getValue(TagValueExpression.java:106) at javax.faces.component.ComponentStateHelper.eval(ComponentStateHelper.java:190) at javax.faces.component.ComponentStateHelper.eval(ComponentStateHelper.java:178) at javax.faces.component.UIData.getValue(UIData.java:554) at org.primefaces.component.datatable.DataTable.getValue(DataTable.java:910) at org.primefaces.component.api.UIData.getDataModel(UIData.java:615) at org.primefaces.component.api.UIData.setRowModel(UIData.java:422) at org.primefaces.component.api.UIData.setRowIndex(UIData.java:414) at org.primefaces.component.api.UIData.visitTree(UIData.java:669) at javax.faces.component.UIComponent.visitTree(UIComponent.java:1487) at javax.faces.component.UIForm.visitTree(UIForm.java:331) at javax.faces.component.UIComponent.visitTree(UIComponent.java:1487) at javax.faces.component.UIComponent.visitTree(UIComponent.java:1487) at com.sun.faces.application.view.StateManagementStrategyImpl.restoreView(StateManagementStrategyImpl.java:234) at com.sun.faces.application.StateManagerImpl.restoreView(StateManagerImpl.java:177) at com.sun.faces.application.view.ViewHandlingStrategy.restoreView(ViewHandlingStrategy.java:119) at com.sun.faces.application.view.FaceletViewHandlingStrategy.restoreView(FaceletViewHandlingStrategy.java:438) at com.sun.faces.application.view.MultiViewHandler.restoreView(MultiViewHandler.java:144) at com.sun.faces.lifecycle.RestoreViewPhase.execute(RestoreViewPhase.java:182) at com.sun.faces.lifecycle.Phase.doPhase(Phase.java:97) at com.sun.faces.lifecycle.RestoreViewPhase.doPhase(RestoreViewPhase.java:107) at com.sun.faces.lifecycle.LifecycleImpl.execute(LifecycleImpl.java:114) at javax.faces.webapp.FacesServlet.service(FacesServlet.java:308) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:233) at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191) at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:127) at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102) at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109) at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:293) at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:859) at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:602) at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:489) at java.lang.Thread.run(Unknown Source) Caused by: java.io.EOFException: Can not read response from server. Expected to read 4 bytes, read 0 bytes before connec tion was unexpectedly lost. at com.mysql.jdbc.MysqlIO.readFully(MysqlIO.java:3052) at com.mysql.jdbc.MysqlIO.reuseAndReadPacket(MysqlIO.java:3503) ... 53 more ... |
| 23.01.2014, 21:26:10 |
Похоже что вообще не может к серверу приконектиться. Может это какая-то отдельная фича, которая ходит по другому адресу? ... |
| 23.01.2014, 21:43:38 |
Blazkowicz, вроде коннектится, там на каждой странице тенятся из базы. уточнение: оно появлятся не при каждом запросе, это показывает каждый раз то что уже записано. похоже на глюк со стороны провайдера: листал страницы много раз - ничего, потом опять появилось пару раз. перезагружаю приложение, листаю - ничего... потом снова разок появилось. ... |
| 23.01.2014, 22:13:17 |
rema174уточнение: оно появлятся не при каждом запросе, это показывает каждый раз то что уже записано. Ничего не понял. ... |
| 23.01.2014, 22:17:31 |
Blazkowiczrema174уточнение: оно появлятся не при каждом запросе, это показывает каждый раз то что уже записано. Ничего не понял. я так понимаю, что при возникновении ошибки она запишется в stderr.log теперь, если ошибка не возникает, и я снова запрошу содержание stderr.log, мне показывает то, что там уже было и есть. ... |
| 23.01.2014, 22:29:21 |
еще нюанс... приложение запущено и простаивает какое-то время: 5-10 минут теперь, если вызвать страницу, то ничего не приходит из mysql смотрю логи - опять возникла всё та же ошибка после этого, обновляю туже самую страницу - данные приходят. листаю - все работает простой и все по новой повторяется... _________ пробовал вот это http://stackoverflow.com/a/13065516/2382770 - не дает эффекта ... |
| 24.01.2014, 14:18:44 |
Мда. Совсем одно и тоже что было написано в первом посте. MySQL имеет свойство убивать соединения, которые некоторое время не используются. Если в Java используется пул соединений, то очевидно, что там они живут очень долго. Решение простое и уже обсуждалось на форуме не раз - настроить в пуле соединений превалидацию соединения перед отдачей. ... |
| 24.01.2014, 14:21:30 |
Blazkowicz, спасибо, получилось, хотя с пулом соединений еще предстоит разобраться... p.s. наверное, астрономы, исследующие новые миры, испытывают похожие чувства - заглядывая дальше вглубь вселенной, они понимают, как далеко еще предстоит залянуть ... |
| 24.01.2014, 15:37:26 |
start [/forum/topic.php?fid=59&gotonew=1&tid=2127769]: |
23ms |
57ms |
69ms |
| others: | 285ms |
| total: | 477ms |
