jdbc
В запросе указано два параметра, и передается два, почему тогда на строке 173 Код: java 1. возникает ошибка? Код: java 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. автормар 16, 2014 11:01:10 AM Dao addTask INFO: from dao addTask... мар 16, 2014 11:01:10 AM Dao addTask INFO: user_id=7 мар 16, 2014 11:01:10 AM Dao addTask INFO: SQLException while add new task. java.sql.SQLException: Parameter index out of range (2 > number of parameters, which is 1). at com.mysql.jdbc.SQLError.createSQLException(SQLError.java:1086) at com.mysql.jdbc.SQLError.createSQLException(SQLError.java:989) at com.mysql.jdbc.SQLError.createSQLException(SQLError.java:975) at com.mysql.jdbc.SQLError.createSQLException(SQLError.java:920) at com.mysql.jdbc.PreparedStatement.checkBounds(PreparedStatement.java:3796) at com.mysql.jdbc.PreparedStatement.setInternal(PreparedStatement.java:3778) at com.mysql.jdbc.PreparedStatement.setInternal(PreparedStatement.java:3823) at com.mysql.jdbc.PreparedStatement.setInt(PreparedStatement.java:3767) at Dao.addTask(Dao.java:173) ... |
| 16.03.2014, 13:07:09 |
jdbc
rema174, Код: java 1. ??? ... |
| 16.03.2014, 13:17:23 |
start [/forum/topic.php?fid=59&gotonew=1&tid=2127498]: |
25ms |
52ms |
43ms |
| others: | 297ms |
| total: | 475ms |
