Tomcat, Spring, IDEA, Unable to create annotation scanner for web module
Здравствуйте, уважаемые! Решил создать в IDEA приложение, натыкал в модулях Spring core, Spring Integration, Web Application, Application server. Сервер - TomEE 7.0.47 Spring - 4.0.2 Создал сервлет, пытаюсь запустить на Томкэте, но он его, кажется, не может задеплоить. Аутпут с сервера: "C:\Program Files\Apache Software Foundation\apache-tomee-webprofile-1.6.0\bin\catalina.bat" run [2014-03-25 01:23:40,613] Artifact SMSService:war exploded: Server is not connected. Deploy is not available. Using CATALINA_BASE: "C:\Users\Ђ«ҐЄб ¤а\.IntelliJIdea13\system\tomcat\TomEE_7_0_47_SMSService_3" Using CATALINA_HOME: "C:\Program Files\Apache Software Foundation\apache-tomee-webprofile-1.6.0" Using CATALINA_TMPDIR: "C:\Program Files\Apache Software Foundation\apache-tomee-webprofile-1.6.0\temp" Using JRE_HOME: "C:\Program Files\Java\jdk1.8.0" Using CLASSPATH: "C:\Program Files\Apache Software Foundation\apache-tomee-webprofile-1.6.0\bin\bootstrap.jar;C:\Program Files\Apache Software Foundation\apache-tomee-webprofile-1.6.0\bin\tomcat-juli.jar" мар 25, 2014 1:23:42 AM org.apache.catalina.core.AprLifecycleListener init INFO: The APR based Apache Tomcat Native library which allows optimal performance in production environments was not found on the java.library.path: C:\Program Files\Java\jdk1.8.0\bin;C:\Windows\Sun\Java\bin;C:\Windows\system32;C:\Windows;C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;C:\Program Files (x86)\Borland\Delphi7\Bin;C:\Program Files (x86)\Borland\Delphi7\Projects\Bpl\;%CommonProgramFiles%\Microsoft Shared\Windows Live;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Program Files (x86)\ATI Technologies\ATI.ACE\Core-Static;C:\Program Files (x86)\Java\jre6\bin;C:\Program Files (x86)\Git\cmd;C:\Program Files\Java\jdk1.7.0_40\bin;C:\Program Files (x86)\Microsoft SQL Server\90\Tools\binn\;C:\Program Files\Oracle\JavaFX 2.0 SDK\bin;C:\Program Files (x86)\Rational\common;c:\aspectj1.7\bin;C:\Program Files\Microsoft SQL Server\110\Tools\Binn\;C:\Program Files\Common Files\Microsoft Shared\Windows Live;C:\Program Files\Java\jdk1.7.0_11\bin;D:\cygwin\bin;. мар 25, 2014 1:23:42 AM org.apache.coyote.AbstractProtocol init INFO: Initializing ProtocolHandler ["http-bio-8080"] мар 25, 2014 1:23:42 AM org.apache.coyote.AbstractProtocol init INFO: Initializing ProtocolHandler ["ajp-bio-8009"] мар 25, 2014 1:23:44 AM org.apache.openejb.util.OptionsLog info INFO: Using 'openejb.jdbc.datasource-creator=org.apache.tomee.jdbc.TomEEDataSourceCreator' мар 25, 2014 1:23:44 AM org.apache.tomee.catalina.TomcatLoader optionalService INFO: Optional service not installed: org.apache.tomee.webservices.TomeeJaxRsService мар 25, 2014 1:23:44 AM org.apache.tomee.catalina.TomcatLoader optionalService INFO: Optional service not installed: org.apache.tomee.webservices.TomeeJaxWsService мар 25, 2014 1:23:44 AM org.apache.openejb.OpenEJB$Instance <init> INFO: ******************************************************************************** мар 25, 2014 1:23:44 AM org.apache.openejb.OpenEJB$Instance <init> INFO: OpenEJB http://openejb.apache.org/ мар 25, 2014 1:23:44 AM org.apache.openejb.OpenEJB$Instance <init> INFO: Startup: Tue Mar 25 01:23:44 NOVT 2014 мар 25, 2014 1:23:44 AM org.apache.openejb.OpenEJB$Instance <init> INFO: Copyright 1999-2013 (C) Apache OpenEJB Project, All Rights Reserved. мар 25, 2014 1:23:44 AM org.apache.openejb.OpenEJB$Instance <init> INFO: Version: 4.6.0 мар 25, 2014 1:23:44 AM org.apache.openejb.OpenEJB$Instance <init> INFO: Build date: 20131117 мар 25, 2014 1:23:44 AM org.apache.openejb.OpenEJB$Instance <init> INFO: Build time: 06:49 мар 25, 2014 1:23:44 AM org.apache.openejb.OpenEJB$Instance <init> INFO: ******************************************************************************** мар 25, 2014 1:23:44 AM org.apache.openejb.OpenEJB$Instance <init> INFO: openejb.home = C:\Program Files\Apache Software Foundation\apache-tomee-webprofile-1.6.0 мар 25, 2014 1:23:44 AM org.apache.openejb.OpenEJB$Instance <init> INFO: openejb.base = C:\Users\Александр\.IntelliJIdea13\system\tomcat\TomEE_7_0_47_SMSService_3 мар 25, 2014 1:23:44 AM org.apache.openejb.cdi.CdiBuilder initializeOWB INFO: Created new singletonService org.apache.openejb.cdi.ThreadSingletonServiceImpl@57f23557 мар 25, 2014 1:23:44 AM org.apache.openejb.cdi.CdiBuilder initializeOWB INFO: Succeeded in installing singleton service мар 25, 2014 1:23:44 AM org.apache.openejb.config.ConfigurationFactory init INFO: openejb configuration file is 'C:\Users\Александр\.IntelliJIdea13\system\tomcat\TomEE_7_0_47_SMSService_3\conf\tomee.xml' мар 25, 2014 1:23:44 AM org.apache.openejb.config.ConfigurationFactory configureService INFO: Configuring Service(id=Tomcat Security Service, type=SecurityService, provider-id=Tomcat Security Service) мар 25, 2014 1:23:44 AM org.apache.openejb.config.ConfigurationFactory configureService INFO: Configuring Service(id=Default Transaction Manager, type=TransactionManager, provider-id=Default Transaction Manager) мар 25, 2014 1:23:44 AM org.apache.openejb.util.OptionsLog info INFO: Using 'openejb.system.apps=true' мар 25, 2014 1:23:44 AM org.apache.openejb.config.ConfigurationFactory configureApplication INFO: Configuring enterprise application: openejb мар 25, 2014 1:23:45 AM org.apache.openejb.config.InitEjbDeployments deploy INFO: Using openejb.deploymentId.format '{ejbName}' мар 25, 2014 1:23:45 AM org.apache.openejb.config.InitEjbDeployments deploy INFO: Auto-deploying ejb openejb/User: EjbDeployment(deployment-id=openejb/User) мар 25, 2014 1:23:45 AM org.apache.openejb.config.InitEjbDeployments deploy INFO: Auto-deploying ejb openejb/Deployer: EjbDeployment(deployment-id=openejb/Deployer) мар 25, 2014 1:23:45 AM org.apache.openejb.config.InitEjbDeployments deploy INFO: Auto-deploying ejb openejb/ConfigurationInfo: EjbDeployment(deployment-id=openejb/ConfigurationInfo) мар 25, 2014 1:23:45 AM org.apache.openejb.config.InitEjbDeployments deploy INFO: Auto-deploying ejb MEJB: EjbDeployment(deployment-id=MEJB) мар 25, 2014 1:23:45 AM org.apache.openejb.config.ConfigurationFactory configureService INFO: Configuring Service(id=Default Stateless Container, type=Container, provider-id=Default Stateless Container) мар 25, 2014 1:23:45 AM org.apache.openejb.config.AutoConfig createContainer INFO: Auto-creating a container for bean openejb/User: Container(type=STATELESS, id=Default Stateless Container) мар 25, 2014 1:23:45 AM org.apache.openejb.config.AppInfoBuilder build INFO: Enterprise application "openejb" loaded. мар 25, 2014 1:23:45 AM org.apache.openejb.assembler.classic.Assembler createRecipe INFO: Creating TransactionManager(id=Default Transaction Manager) мар 25, 2014 1:23:45 AM org.apache.openejb.assembler.classic.Assembler createRecipe INFO: Creating SecurityService(id=Tomcat Security Service) мар 25, 2014 1:23:45 AM org.apache.openejb.assembler.classic.Assembler createRecipe INFO: Creating Container(id=Default Stateless Container) мар 25, 2014 1:23:45 AM org.apache.openejb.assembler.classic.Assembler createApplication INFO: Assembling app: openejb мар 25, 2014 1:23:45 AM org.apache.openejb.util.OptionsLog info INFO: Using 'openejb.jndiname.format={deploymentId}{interfaceType.openejbLegacyName}' мар 25, 2014 1:23:45 AM org.apache.openejb.assembler.classic.JndiBuilder bind INFO: Jndi(name=openejb/UserBusinessRemote) --> Ejb(deployment-id=openejb/User) мар 25, 2014 1:23:45 AM org.apache.openejb.assembler.classic.JndiBuilder bind INFO: Jndi(name=global/openejb/openejb/User!org.apache.openejb.assembler.util.User) --> Ejb(deployment-id=openejb/User) мар 25, 2014 1:23:45 AM org.apache.openejb.assembler.classic.JndiBuilder bind INFO: Jndi(name=global/openejb/openejb/User) --> Ejb(deployment-id=openejb/User) мар 25, 2014 1:23:45 AM org.apache.openejb.assembler.classic.JndiBuilder bind INFO: Jndi(name=openejb/DeployerBusinessRemote) --> Ejb(deployment-id=openejb/Deployer) мар 25, 2014 1:23:45 AM org.apache.openejb.assembler.classic.JndiBuilder bind INFO: Jndi(name=global/openejb/openejb/Deployer!org.apache.openejb.assembler.Deployer) --> Ejb(deployment-id=openejb/Deployer) мар 25, 2014 1:23:45 AM org.apache.openejb.assembler.classic.JndiBuilder bind INFO: Jndi(name=global/openejb/openejb/Deployer) --> Ejb(deployment-id=openejb/Deployer) мар 25, 2014 1:23:45 AM org.apache.openejb.assembler.classic.JndiBuilder bind INFO: Jndi(name=openejb/ConfigurationInfoBusinessRemote) --> Ejb(deployment-id=openejb/ConfigurationInfo) мар 25, 2014 1:23:45 AM org.apache.openejb.assembler.classic.JndiBuilder bind INFO: Jndi(name=global/openejb/openejb/ConfigurationInfo!org.apache.openejb.assembler.classic.cmd.ConfigurationInfo) --> Ejb(deployment-id=openejb/ConfigurationInfo) мар 25, 2014 1:23:45 AM org.apache.openejb.assembler.classic.JndiBuilder bind INFO: Jndi(name=global/openejb/openejb/ConfigurationInfo) --> Ejb(deployment-id=openejb/ConfigurationInfo) мар 25, 2014 1:23:45 AM org.apache.openejb.assembler.classic.JndiBuilder bind INFO: Jndi(name=MEJB) --> Ejb(deployment-id=MEJB) мар 25, 2014 1:23:45 AM org.apache.openejb.assembler.classic.JndiBuilder bind INFO: Jndi(name=global/openejb/MEJB!javax.management.j2ee.ManagementHome) --> Ejb(deployment-id=MEJB) мар 25, 2014 1:23:45 AM org.apache.openejb.assembler.classic.JndiBuilder bind INFO: Jndi(name=global/openejb/MEJB) --> Ejb(deployment-id=MEJB) мар 25, 2014 1:23:45 AM org.apache.openejb.assembler.classic.Assembler startEjbs INFO: Created Ejb(deployment-id=MEJB, ejb-name=MEJB, container=Default Stateless Container) мар 25, 2014 1:23:45 AM org.apache.openejb.assembler.classic.Assembler startEjbs INFO: Created Ejb(deployment-id=openejb/ConfigurationInfo, ejb-name=openejb/ConfigurationInfo, container=Default Stateless Container) мар 25, 2014 1:23:45 AM org.apache.openejb.assembler.classic.Assembler startEjbs INFO: Created Ejb(deployment-id=openejb/Deployer, ejb-name=openejb/Deployer, container=Default Stateless Container) мар 25, 2014 1:23:45 AM org.apache.openejb.assembler.classic.Assembler startEjbs INFO: Created Ejb(deployment-id=openejb/User, ejb-name=openejb/User, container=Default Stateless Container) мар 25, 2014 1:23:45 AM org.apache.openejb.assembler.classic.Assembler startEjbs INFO: Started Ejb(deployment-id=MEJB, ejb-name=MEJB, container=Default Stateless Container) мар 25, 2014 1:23:45 AM org.apache.openejb.assembler.classic.Assembler startEjbs INFO: Started Ejb(deployment-id=openejb/ConfigurationInfo, ejb-name=openejb/ConfigurationInfo, container=Default Stateless Container) мар 25, 2014 1:23:45 AM org.apache.openejb.assembler.classic.Assembler startEjbs INFO: Started Ejb(deployment-id=openejb/Deployer, ejb-name=openejb/Deployer, container=Default Stateless Container) мар 25, 2014 1:23:45 AM org.apache.openejb.assembler.classic.Assembler startEjbs INFO: Started Ejb(deployment-id=openejb/User, ejb-name=openejb/User, container=Default Stateless Container) мар 25, 2014 1:23:45 AM org.apache.openejb.assembler.classic.Assembler deployMBean INFO: Deployed MBean(openejb.user.mbeans:application=openejb,group=org.apache.openejb.assembler.monitoring,name=JMXDeployer) мар 25, 2014 1:23:45 AM org.apache.openejb.assembler.classic.Assembler createApplication INFO: Deployed Application(path=openejb) мар 25, 2014 1:23:46 AM org.apache.openejb.server.SimpleServiceManager start INFO: ** Bound Services ** мар 25, 2014 1:23:46 AM org.apache.openejb.server.SimpleServiceManager printRow INFO: NAME IP PORT мар 25, 2014 1:23:46 AM org.apache.openejb.server.SimpleServiceManager start INFO: ------- мар 25, 2014 1:23:46 AM org.apache.openejb.server.SimpleServiceManager start INFO: Ready! мар 25, 2014 1:23:46 AM org.apache.catalina.startup.Catalina load INFO: Initialization processed in 4462 ms мар 25, 2014 1:23:46 AM org.apache.tomee.catalina.OpenEJBNamingContextListener bindResource INFO: Importing a Tomcat Resource with id 'UserDatabase' of type 'org.apache.catalina.UserDatabase'. мар 25, 2014 1:23:46 AM org.apache.openejb.assembler.classic.Assembler createRecipe INFO: Creating Resource(id=UserDatabase) мар 25, 2014 1:23:46 AM org.apache.catalina.core.StandardService startInternal INFO: Starting service Catalina мар 25, 2014 1:23:46 AM org.apache.catalina.core.StandardEngine startInternal INFO: Starting Servlet Engine: Apache Tomcat (TomEE)/7.0.47 (1.6.0) мар 25, 2014 1:23:46 AM org.apache.coyote.AbstractProtocol start INFO: Starting ProtocolHandler ["http-bio-8080"] мар 25, 2014 1:23:46 AM org.apache.coyote.AbstractProtocol start INFO: Starting ProtocolHandler ["ajp-bio-8009"] мар 25, 2014 1:23:46 AM org.apache.catalina.startup.Catalina start INFO: Server startup in 190 ms Connected to server [2014-03-25 01:23:48,097] Artifact SMSService:war exploded: Artifact is being deployed, please wait... мар 25, 2014 1:23:48 AM org.apache.tomee.catalina.TomcatWebAppBuilder deployWebApps INFO: using default host: localhost мар 25, 2014 1:23:48 AM org.apache.tomee.catalina.TomcatWebAppBuilder init INFO: ------------------------- localhost -> / мар 25, 2014 1:23:48 AM org.apache.catalina.core.ContainerBase addChildInternal SEVERE: ContainerBase.addChild: start: org.apache.catalina.LifecycleException: Failed to start component [StandardEngine[Catalina].StandardHost[localhost].StandardContext[/]] at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:154) at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:901) at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:877) at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:633) at org.apache.tomee.catalina.TomcatWebAppBuilder.deployWar(TomcatWebAppBuilder.java:622) at org.apache.tomee.catalina.TomcatWebAppBuilder.deployWebApps(TomcatWebAppBuilder.java:593) at org.apache.tomee.catalina.deployment.TomcatWebappDeployer.deploy(TomcatWebappDeployer.java:44) at org.apache.openejb.assembler.DeployerEjb.deploy(DeployerEjb.java:168) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.lang.reflect.Method.invoke(Method.java:483) at org.apache.openejb.core.interceptor.ReflectionInvocationContext$Invocation.invoke(ReflectionInvocationContext.java:182) at org.apache.openejb.core.interceptor.ReflectionInvocationContext.proceed(ReflectionInvocationContext.java:164) at org.apache.openejb.security.internal.InternalSecurityInterceptor.invoke(InternalSecurityInterceptor.java:34) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.lang.reflect.Method.invoke(Method.java:483) at org.apache.openejb.core.interceptor.ReflectionInvocationContext$Invocation.invoke(ReflectionInvocationContext.java:182) at org.apache.openejb.core.interceptor.ReflectionInvocationContext.proceed(ReflectionInvocationContext.java:164) at org.apache.openejb.monitoring.StatsInterceptor.record(StatsInterceptor.java:180) at org.apache.openejb.monitoring.StatsInterceptor.invoke(StatsInterceptor.java:99) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.lang.reflect.Method.invoke(Method.java:483) at org.apache.openejb.core.interceptor.ReflectionInvocationContext$Invocation.invoke(ReflectionInvocationContext.java:182) at org.apache.openejb.core.interceptor.ReflectionInvocationContext.proceed(ReflectionInvocationContext.java:164) at org.apache.openejb.core.interceptor.InterceptorStack.invoke(InterceptorStack.java:80) at org.apache.openejb.core.stateless.StatelessContainer._invoke(StatelessContainer.java:212) at org.apache.openejb.core.stateless.StatelessContainer.invoke(StatelessContainer.java:181) at org.apache.openejb.server.ejbd.EjbRequestHandler.doEjbObject_BUSINESS_METHOD(EjbRequestHandler.java:370) at org.apache.openejb.server.ejbd.EjbRequestHandler.processRequest(EjbRequestHandler.java:181) at org.apache.openejb.server.ejbd.EjbDaemon.processEjbRequest(EjbDaemon.java:344) at org.apache.openejb.server.ejbd.EjbDaemon.service(EjbDaemon.java:240) at org.apache.openejb.server.ejbd.EjbServer.service(EjbServer.java:86) at org.apache.openejb.server.httpd.ServerServlet.service(ServerServlet.java:58) at javax.servlet.http.HttpServlet.service(HttpServlet.java:728) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:305) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:210) at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:222) at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:123) at org.apache.tomee.catalina.OpenEJBValve.invoke(OpenEJBValve.java:45) at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:171) at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:100) at org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:953) at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:118) at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:408) at org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1041) at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:603) at org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.run(JIoEndpoint.java:312) at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142) at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617) at java.lang.Thread.run(Thread.java:744) Caused by: org.apache.tomee.catalina.TomEERuntimeException: org.apache.openejb.OpenEJBException: Unable to create annotation scanner for web module : null at org.apache.tomee.catalina.TomcatWebAppBuilder.loadApplication(TomcatWebAppBuilder.java:2049) at org.apache.tomee.catalina.TomcatWebAppBuilder.startInternal(TomcatWebAppBuilder.java:1091) at org.apache.tomee.catalina.TomcatWebAppBuilder.configureStart(TomcatWebAppBuilder.java:1051) at org.apache.tomee.catalina.GlobalListenerSupport.lifecycleEvent(GlobalListenerSupport.java:127) at org.apache.catalina.util.LifecycleSupport.fireLifecycleEvent(LifecycleSupport.java:119) at org.apache.catalina.util.LifecycleBase.fireLifecycleEvent(LifecycleBase.java:90) at org.apache.catalina.core.StandardContext.startInternal(StandardContext.java:5322) at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:150) ... 54 more Caused by: org.apache.openejb.OpenEJBException: Unable to create annotation scanner for web module : null at org.apache.openejb.config.DeploymentLoader.addWebModule(DeploymentLoader.java:838) at org.apache.openejb.config.DeploymentLoader.load(DeploymentLoader.java:219) at org.apache.tomee.catalina.TomcatWebAppBuilder.loadApplication(TomcatWebAppBuilder.java:2047) ... 61 more Caused by: java.lang.IllegalArgumentException at org.apache.xbean.asm4.ClassReader.<init>(Unknown Source) at org.apache.xbean.asm4.ClassReader.<init>(Unknown Source) at org.apache.xbean.asm4.ClassReader.<init>(Unknown Source) at org.apache.xbean.finder.AnnotationFinder.readClassDef(AnnotationFinder.java:1120) at org.apache.xbean.finder.AnnotationFinder.<init>(AnnotationFinder.java:139) at org.apache.xbean.finder.AnnotationFinder.<init>(AnnotationFinder.java:152) at org.apache.xbean.finder.AsynchronousInheritanceAnnotationFinder.<init>(AsynchronousInheritanceAnnotationFinder.java:43) at org.apache.openejb.config.FinderFactory.newFinder(FinderFactory.java:114) at org.apache.openejb.config.FinderFactory.create(FinderFactory.java:68) at org.apache.openejb.config.FinderFactory.createFinder(FinderFactory.java:57) at org.apache.openejb.config.DeploymentLoader.addWebModule(DeploymentLoader.java:830) ... 63 more мар 25, 2014 1:23:48 AM org.apache.openejb.core.transaction.EjbTransactionUtil handleSystemException SEVERE: EjbTransactionUtil.handleSystemException: java.lang.IllegalStateException: ContainerBase.addChild: start: org.apache.catalina.LifecycleException: Failed to start component [StandardEngine[Catalina].StandardHost[localhost].StandardContext[/]] org.apache.openejb.OpenEJBRuntimeException: java.lang.IllegalStateException: ContainerBase.addChild: start: org.apache.catalina.LifecycleException: Failed to start component [StandardEngine[Catalina].StandardHost[localhost].StandardContext[/]] at org.apache.tomee.catalina.deployment.TomcatWebappDeployer.deploy(TomcatWebappDeployer.java:46) at org.apache.openejb.assembler.DeployerEjb.deploy(DeployerEjb.java:168) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.lang.reflect.Method.invoke(Method.java:483) at org.apache.openejb.core.interceptor.ReflectionInvocationContext$Invocation.invoke(ReflectionInvocationContext.java:182) at org.apache.openejb.core.interceptor.ReflectionInvocationContext.proceed(ReflectionInvocationContext.java:164) at org.apache.openejb.security.internal.InternalSecurityInterceptor.invoke(InternalSecurityInterceptor.java:34) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.lang.reflect.Method.invoke(Method.java:483) at org.apache.openejb.core.interceptor.ReflectionInvocationContext$Invocation.invoke(ReflectionInvocationContext.java:182) at org.apache.openejb.core.interceptor.ReflectionInvocationContext.proceed(ReflectionInvocationContext.java:164) at org.apache.openejb.monitoring.StatsInterceptor.record(StatsInterceptor.java:180) at org.apache.openejb.monitoring.StatsInterceptor.invoke(StatsInterceptor.java:99) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.lang.reflect.Method.invoke(Method.java:483) at org.apache.openejb.core.interceptor.ReflectionInvocationContext$Invocation.invoke(ReflectionInvocationContext.java:182) at org.apache.openejb.core.interceptor.ReflectionInvocationContext.proceed(ReflectionInvocationContext.java:164) at org.apache.openejb.core.interceptor.InterceptorStack.invoke(InterceptorStack.java:80) at org.apache.openejb.core.stateless.StatelessContainer._invoke(StatelessContainer.java:212) at org.apache.openejb.core.stateless.StatelessContainer.invoke(StatelessContainer.java:181) at org.apache.openejb.server.ejbd.EjbRequestHandler.doEjbObject_BUSINESS_METHOD(EjbRequestHandler.java:370) at org.apache.openejb.server.ejbd.EjbRequestHandler.processRequest(EjbRequestHandler.java:181) at org.apache.openejb.server.ejbd.EjbDaemon.processEjbRequest(EjbDaemon.java:344) at org.apache.openejb.server.ejbd.EjbDaemon.service(EjbDaemon.java:240) at org.apache.openejb.server.ejbd.EjbServer.service(EjbServer.java:86) at org.apache.openejb.server.httpd.ServerServlet.service(ServerServlet.java:58) at javax.servlet.http.HttpServlet.service(HttpServlet.java:728) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:305) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:210) at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:222) at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:123) at org.apache.tomee.catalina.OpenEJBValve.invoke(OpenEJBValve.java:45) at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:171) at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:100) at org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:953) at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:118) at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:408) at org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1041) at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:603) at org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.run(JIoEndpoint.java:312) at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142) at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617) at java.lang.Thread.run(Thread.java:744) Caused by: java.lang.IllegalStateException: ContainerBase.addChild: start: org.apache.catalina.LifecycleException: Failed to start component [StandardEngine[Catalina].StandardHost[localhost].StandardContext[/]] at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:904) at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:877) at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:633) at org.apache.tomee.catalina.TomcatWebAppBuilder.deployWar(TomcatWebAppBuilder.java:622) at org.apache.tomee.catalina.TomcatWebAppBuilder.deployWebApps(TomcatWebAppBuilder.java:593) at org.apache.tomee.catalina.deployment.TomcatWebappDeployer.deploy(TomcatWebappDeployer.java:44) ... 48 more [2014-03-25 01:23:48,902] Artifact SMSService:war exploded: Error during artifact deployment. See server log for details. [2014-03-25 01:23:48,908] Artifact SMSService:war exploded: javax.ejb.EJBException: The bean encountered a non-application exception; nested exception is: org.apache.openejb.OpenEJBRuntimeException: java.lang.IllegalStateException: ContainerBase.addChild: start: org.apache.catalina.LifecycleException: Failed to start component [StandardEngine[Catalina].StandardHost[localhost].StandardContext[/]] мар 25, 2014 1:23:56 AM org.apache.catalina.startup.HostConfig deployDirectory INFO: Deploying web application directory C:\Program Files\Apache Software Foundation\apache-tomee-webprofile-1.6.0\webapps\manager мар 25, 2014 1:23:56 AM org.apache.tomee.catalina.TomcatWebAppBuilder init INFO: ------------------------- localhost -> /manager мар 25, 2014 1:23:56 AM org.apache.openejb.config.ConfigurationFactory configureApplication INFO: Configuring enterprise application: C:\Program Files\Apache Software Foundation\apache-tomee-webprofile-1.6.0\webapps\manager мар 25, 2014 1:23:56 AM org.apache.openejb.config.AppInfoBuilder build INFO: Enterprise application "C:\Program Files\Apache Software Foundation\apache-tomee-webprofile-1.6.0\webapps\manager" loaded. мар 25, 2014 1:23:56 AM org.apache.openejb.assembler.classic.Assembler createApplication INFO: Assembling app: C:\Program Files\Apache Software Foundation\apache-tomee-webprofile-1.6.0\webapps\manager мар 25, 2014 1:23:56 AM org.apache.openejb.cdi.CdiBuilder initSingleton INFO: Existing thread singleton service in SystemInstance(): org.apache.openejb.cdi.ThreadSingletonServiceImpl@57f23557 мар 25, 2014 1:23:56 AM org.apache.openejb.cdi.OpenEJBLifecycle startApplication INFO: OpenWebBeans Container is starting... мар 25, 2014 1:23:56 AM org.apache.webbeans.plugins.PluginLoader startUp INFO: Adding OpenWebBeansPlugin : [CdiPlugin] мар 25, 2014 1:23:56 AM org.apache.webbeans.plugins.PluginLoader startUp INFO: Adding OpenWebBeansPlugin : [OpenWebBeansJsfPlugin] мар 25, 2014 1:23:56 AM org.apache.webbeans.config.BeansDeployer validateInjectionPoints INFO: All injection points were validated successfully. мар 25, 2014 1:23:56 AM org.apache.openejb.cdi.OpenEJBLifecycle startApplication INFO: OpenWebBeans Container has started, it took 172 ms. мар 25, 2014 1:23:56 AM org.apache.tomee.catalina.TomcatWebAppBuilder deployWebApps INFO: using context file C:\Program Files\Apache Software Foundation\apache-tomee-webprofile-1.6.0\webapps\manager\META-INF\context.xml мар 25, 2014 1:23:56 AM org.apache.openejb.assembler.classic.Assembler createApplication INFO: Deployed Application(path=C:\Program Files\Apache Software Foundation\apache-tomee-webprofile-1.6.0\webapps\manager) "C:\Program Files\Apache Software Foundation\apache-tomee-webprofile-1.6.0\bin\catalina.bat" stop Using CATALINA_BASE: "C:\Users\Ђ«ҐЄб ¤а\.IntelliJIdea13\system\tomcat\TomEE_7_0_47_SMSService_3" Using CATALINA_HOME: "C:\Program Files\Apache Software Foundation\apache-tomee-webprofile-1.6.0" Using CATALINA_TMPDIR: "C:\Program Files\Apache Software Foundation\apache-tomee-webprofile-1.6.0\temp" Using JRE_HOME: "C:\Program Files\Java\jdk1.8.0" Using CLASSPATH: "C:\Program Files\Apache Software Foundation\apache-tomee-webprofile-1.6.0\bin\bootstrap.jar;C:\Program Files\Apache Software Foundation\apache-tomee-webprofile-1.6.0\bin\tomcat-juli.jar" мар 25, 2014 1:33:13 AM org.apache.catalina.core.StandardServer await INFO: A valid shutdown command was received via the shutdown port. Stopping the Server instance. мар 25, 2014 1:33:13 AM org.apache.coyote.AbstractProtocol pause INFO: Pausing ProtocolHandler ["http-bio-8080"] мар 25, 2014 1:33:13 AM org.apache.coyote.AbstractProtocol pause INFO: Pausing ProtocolHandler ["ajp-bio-8009"] мар 25, 2014 1:33:13 AM org.apache.catalina.core.StandardService stopInternal INFO: Stopping service Catalina мар 25, 2014 1:33:13 AM org.apache.openejb.assembler.classic.Assembler destroyApplication INFO: Undeploying app: C:\Program Files\Apache Software Foundation\apache-tomee-webprofile-1.6.0\webapps\manager мар 25, 2014 1:33:13 AM org.apache.coyote.AbstractProtocol stop INFO: Stopping ProtocolHandler ["http-bio-8080"] мар 25, 2014 1:33:13 AM org.apache.coyote.AbstractProtocol stop INFO: Stopping ProtocolHandler ["ajp-bio-8009"] мар 25, 2014 1:33:13 AM org.apache.openejb.server.SimpleServiceManager stop INFO: Stopping server services мар 25, 2014 1:33:13 AM org.apache.openejb.assembler.classic.Assembler destroyApplication INFO: Undeploying app: openejb мар 25, 2014 1:33:13 AM org.apache.coyote.AbstractProtocol destroy INFO: Destroying ProtocolHandler ["http-bio-8080"] мар 25, 2014 1:33:13 AM org.apache.coyote.AbstractProtocol destroy INFO: Destroying ProtocolHandler ["ajp-bio-8009"] Disconnected from server Логи Томкэта: мар 25, 2014 1:23:42 AM org.apache.catalina.core.AprLifecycleListener init at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:100) at org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:953) at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:118) at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:408) at org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1041) at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:603) at org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.run(JIoEndpoint.java:312) at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142) at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617) at java.lang.Thread.run(Thread.java:744) Caused by: org.apache.tomee.catalina.TomEERuntimeException: org.apache.openejb.OpenEJBException: Unable to create annotation scanner for web module : null at org.apache.tomee.catalina.TomcatWebAppBuilder.loadApplication(TomcatWebAppBuilder.java:2049) at org.apache.tomee.catalina.TomcatWebAppBuilder.startInternal(TomcatWebAppBuilder.java:1091) at org.apache.tomee.catalina.TomcatWebAppBuilder.configureStart(TomcatWebAppBuilder.java:1051) at org.apache.tomee.catalina.GlobalListenerSupport.lifecycleEvent(GlobalListenerSupport.java:127) at org.apache.catalina.util.LifecycleSupport.fireLifecycleEvent(LifecycleSupport.java:119) at org.apache.catalina.util.LifecycleBase.fireLifecycleEvent(LifecycleBase.java:90) at org.apache.catalina.core.StandardContext.startInternal(StandardContext.java:5322) at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:150) ... 54 more Caused by: org.apache.openejb.OpenEJBException: Unable to create annotation scanner for web module : null at org.apache.openejb.config.DeploymentLoader.addWebModule(DeploymentLoader.java:838) at org.apache.openejb.config.DeploymentLoader.load(DeploymentLoader.java:219) at org.apache.tomee.catalina.TomcatWebAppBuilder.loadApplication(TomcatWebAppBuilder.java:2047) ... 61 more Caused by: java.lang.IllegalArgumentException at org.apache.xbean.asm4.ClassReader.<init>(Unknown Source) at org.apache.xbean.asm4.ClassReader.<init>(Unknown Source) at org.apache.xbean.asm4.ClassReader.<init>(Unknown Source) at org.apache.xbean.finder.AnnotationFinder.readClassDef(AnnotationFinder.java:1120) at org.apache.xbean.finder.AnnotationFinder.<init>(AnnotationFinder.java:139) at org.apache.xbean.finder.AnnotationFinder.<init>(AnnotationFinder.java:152) at org.apache.xbean.finder.AsynchronousInheritanceAnnotationFinder.<init>(AsynchronousInheritanceAnnotationFinder.java:43) at org.apache.openejb.config.FinderFactory.newFinder(FinderFactory.java:114) at org.apache.openejb.config.FinderFactory.create(FinderFactory.java:68) at org.apache.openejb.config.FinderFactory.createFinder(FinderFactory.java:57) at org.apache.openejb.config.DeploymentLoader.addWebModule(DeploymentLoader.java:830) ... 63 more мар 25, 2014 1:23:48 AM org.apache.openejb.core.transaction.EjbTransactionUtil handleSystemException SEVERE: EjbTransactionUtil.handleSystemException: java.lang.IllegalStateException: ContainerBase.addChild: start: org.apache.catalina.LifecycleException: Failed to start component [StandardEngine[Catalina].StandardHost[localhost].StandardContext[/]] org.apache.openejb.OpenEJBRuntimeException: java.lang.IllegalStateException: ContainerBase.addChild: start: org.apache.catalina.LifecycleException: Failed to start component [StandardEngine[Catalina].StandardHost[localhost].StandardContext[/]] at org.apache.tomee.catalina.deployment.TomcatWebappDeployer.deploy(TomcatWebappDeployer.java:46) at org.apache.openejb.assembler.DeployerEjb.deploy(DeployerEjb.java:168) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.lang.reflect.Method.invoke(Method.java:483) at org.apache.openejb.core.interceptor.ReflectionInvocationContext$Invocation.invoke(ReflectionInvocationContext.java:182) at org.apache.openejb.core.interceptor.ReflectionInvocationContext.proceed(ReflectionInvocationContext.java:164) at org.apache.openejb.security.internal.InternalSecurityInterceptor.invoke(InternalSecurityInterceptor.java:34) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.lang.reflect.Method.invoke(Method.java:483) at org.apache.openejb.core.interceptor.ReflectionInvocationContext$Invocation.invoke(ReflectionInvocationContext.java:182) at org.apache.openejb.core.interceptor.ReflectionInvocationContext.proceed(ReflectionInvocationContext.java:164) at org.apache.openejb.monitoring.StatsInterceptor.record(StatsInterceptor.java:180) at org.apache.openejb.monitoring.StatsInterceptor.invoke(StatsInterceptor.java:99) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.lang.reflect.Method.invoke(Method.java:483) at org.apache.openejb.core.interceptor.ReflectionInvocationContext$Invocation.invoke(ReflectionInvocationContext.java:182) at org.apache.openejb.core.interceptor.ReflectionInvocationContext.proceed(ReflectionInvocationContext.java:164) at org.apache.openejb.core.interceptor.InterceptorStack.invoke(InterceptorStack.java:80) at org.apache.openejb.core.stateless.StatelessContainer._invoke(StatelessContainer.java:212) at org.apache.openejb.core.stateless.StatelessContainer.invoke(StatelessContainer.java:181) at org.apache.openejb.server.ejbd.EjbRequestHandler.doEjbObject_BUSINESS_METHOD(EjbRequestHandler.java:370) at org.apache.openejb.server.ejbd.EjbRequestHandler.processRequest(EjbRequestHandler.java:181) at org.apache.openejb.server.ejbd.EjbDaemon.processEjbRequest(EjbDaemon.java:344) at org.apache.openejb.server.ejbd.EjbDaemon.service(EjbDaemon.java:240) at org.apache.openejb.server.ejbd.EjbServer.service(EjbServer.java:86) at org.apache.openejb.server.httpd.ServerServlet.service(ServerServlet.java:58) at javax.servlet.http.HttpServlet.service(HttpServlet.java:728) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:305) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:210) at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:222) at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:123) at org.apache.tomee.catalina.OpenEJBValve.invoke(OpenEJBValve.java:45) at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:171) at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:100) at org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:953) at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:118) at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:408) at org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1041) at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:603) at org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.run(JIoEndpoint.java:312) at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142) at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617) at java.lang.Thread.run(Thread.java:744) Caused by: java.lang.IllegalStateException: ContainerBase.addChild: start: org.apache.catalina.LifecycleException: Failed to start component [StandardEngine[Catalina].StandardHost[localhost].StandardContext[/]] at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:904) at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:877) at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:633) at org.apache.tomee.catalina.TomcatWebAppBuilder.deployWar(TomcatWebAppBuilder.java:622) at org.apache.tomee.catalina.TomcatWebAppBuilder.deployWebApps(TomcatWebAppBuilder.java:593) at org.apache.tomee.catalina.deployment.TomcatWebappDeployer.deploy(TomcatWebappDeployer.java:44) ... 48 more мар 25, 2014 1:23:56 AM org.apache.catalina.startup.HostConfig deployDirectory Не могу понять, в чём проблема. Кажется, будто нужно что-то в конфиге прописать. Жду вашей помощи. Так же буду благодарен за полезные ссылки. ... |
| 24.03.2014, 22:55:35 |
Using JRE_HOME: "C:\Program Files\Java\jdk1.8.0" Не будет оно на восьмерке работать. Поставьте и настройте JDK 7 в проекте. ... |
| 24.03.2014, 23:03:15 |
start [/forum/topic.php?fid=59&gotonew=1&tid=2127449]: |
23ms |
53ms |
23ms |
76ms |
| others: | 298ms |
| total: | 516ms |
