Форумы / Java [игнор отключен] [закрыт для гостей] / Vaadin, Как убрать отступ снизу от меню?
3 сообщений из 3, страница 1 из 1
    #38595397
Фотография BlackGnomeГуест
Привет
собрал примеры в кучу:
Код: java
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
21.
22.
23.
24.
25.
26.
27.
28.
29.
30.
31.
32.
33.
34.
35.
36.
37.
38.
39.
40.
41.
42.
43.
44.
45.
46.
47.
48.
49.
50.
51.
52.
53.
54.
55.
56.
57.
58.
59.
60.
61.
62.
63.
64.
65.
66.
67.
68.
69.
70.
71.
72.
73.
74.
75.
76.
77.
78.
79.
80.
81.
82.
83.
84.
85.
86.
87.
88.
89.
90.
91.
92.
93.
94.
95.
96.
97.
98.
99.
100.
101.
102.
103.
104.
105.
106.
107.
108.
109.
		VerticalLayout mainLayot = new VerticalLayout ();
		mainLayot.setMargin(false);
		HorizontalSplitPanel mainSplit = new HorizontalSplitPanel();
		final Object[][] planets = new Object[][]{
		        new Object[]{"Mercury"},
		        new Object[]{"Venus"},
		        new Object[]{"Earth", "The Moon"},
		        new Object[]{"Mars", "Phobos", "Deimos"},
		        new Object[]{"Jupiter", "Io", "Europa", "Ganymedes",
		                                "Callisto"},
		        new Object[]{"Saturn",  "Titan", "Tethys", "Dione",
		                                "Rhea", "Iapetus"},
		        new Object[]{"Uranus",  "Miranda", "Ariel", "Umbriel",
		                                "Titania", "Oberon"},
		        new Object[]{"Neptune", "Triton", "Proteus", "Nereid",
		                                "Larissa"}};
		Tree tree = new Tree("The Planets and Major Moons");
		/* Add planets as root items in the tree. */
		for (int i=0; i<planets.length; i++) {
		    String planet = (String) (planets[i][0]);
		    tree.addItem(planet);
		    if (planets[i].length == 1) {
		        // The planet has no moons so make it a leaf.
		        tree.setChildrenAllowed(planet, false);
		    } else {
		        // Add children (moons) under the planets.
		        for (int j=1; j<planets[i].length; j++) {
		            String moon = (String) planets[i][j];
		            // Add the item as a regular item.
		            tree.addItem(moon);
		            // Set it to be a child.
		            tree.setParent(moon, planet);
		            // Make the moons look like leaves.
		            tree.setChildrenAllowed(moon, false);
		        // Expand the subtree.
		        tree.expandItemsRecursively(planet);
        //menubar
		final MenuBar menu = new MenuBar();
		menu.setWidth("100%");
        menu.addItem("Customer", null, null);
        menu.addItem("Reports", null, null);
        menu.addItem("About", null, null);
        mainLayot.setSpacing(false);
        mainLayot.addComponent(menu);
		mainLayot.addComponent(mainSplit);
		mainLayot.setComponentAlignment(mainSplit, Alignment.TOP_CENTER);
		mainSplit.setFirstComponent(tree);
		/* Create the table with a caption. */
		Table table = new Table("This is my Table");
		/* Define the names and data types of columns.
		 * The "default value" parameter is meaningless here. */
		table.addContainerProperty("First Name", String.class,  null);
		table.addContainerProperty("Last Name",  String.class,  null);
		table.addContainerProperty("Year",       Integer.class, null);
		/* Add a few items in the table. */
		table.addItem(new Object[] {
		    "Nicolaus","Copernicus",new Integer(1473)}, new Integer(1));
		    "Tycho",   "Brahe",     new Integer(1546)}, new Integer(2));
		    "Giordano","Bruno",     new Integer(1548)}, new Integer(3));
		    "Galileo", "Galilei",   new Integer(1564)}, new Integer(4));
		    "Johannes","Kepler",    new Integer(1571)}, new Integer(5));
		    "Isaac",   "Newton",    new Integer(1643)}, new Integer(6));
		mainSplit.setSecondComponent(table);
		table.setSizeFull();
		mainLayot.setSizeFull();
		tree.setSizeFull();
		setContent(mainLayot);
Не могу понять, как сделать так , чтобы mainSplit занимал всё свободное пространство, после добавления menu, всё едет вниз
    #38595426
ferc
BlackGnomeГуест,
Код: java
1.
mainLayot.setExpandRatio(mainSplit,2.0f);
    #38595438
ferc,
Спасибо!
