Проблема с томкатом после добавления liquibase
Привет! Вот добавил в проект liquibase и сразу стала выскакивать ошибка. pom.xml Код: xml 1. 2. 3. 4. 5. 6. И бины прописал: Код: java 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. Собственно ошибка: Код: java 1. 2. 3. Полный отчет: Ошибка SLF4J: Failed to load class "org.slf4j.impl.StaticLoggerBinder". SLF4J: Defaulting to no-operation (NOP) logger implementation SLF4J: See http://www.slf4j.org/codes.html#StaticLoggerBinder for further details. [INFO] Error stacktraces are turned on. [INFO] Scanning for projects... [INFO] [INFO] ------------------------------------------------------------------------ [INFO] Building SiteDesigner Maven Webapp 0.0.1-SNAPSHOT [INFO] ------------------------------------------------------------------------ [INFO] [INFO] >>> tomcat7-maven-plugin:2.1:run (default-cli) @ SiteDesigner >>> [INFO] [INFO] --- maven-resources-plugin:2.5:resources (default-resources) @ SiteDesigner --- [debug] execute contextualize [INFO] Using 'UTF-8' encoding to copy filtered resources. [INFO] Copying 5 resources [INFO] [INFO] --- maven-compiler-plugin:3.1:compile (default-compile) @ SiteDesigner --- [INFO] Nothing to compile - all classes are up to date [INFO] [INFO] <<< tomcat7-maven-plugin:2.1:run (default-cli) @ SiteDesigner <<< [INFO] [INFO] --- tomcat7-maven-plugin:2.1:run (default-cli) @ SiteDesigner --- [INFO] Running war on http://localhost:8080/SiteDesigner [INFO] Using existing Tomcat server configuration at D:\workspace\training\SiteDesigner\target\tomcat [INFO] create webapp with contextPath: /SiteDesigner Jun 16, 2014 12:26:04 PM org.apache.coyote.AbstractProtocol init INFO: Initializing ProtocolHandler ["http-bio-8080"] Jun 16, 2014 12:26:04 PM org.apache.catalina.core.StandardService startInternal INFO: Starting service Tomcat Jun 16, 2014 12:26:04 PM org.apache.catalina.core.StandardEngine startInternal INFO: Starting Servlet Engine: Apache Tomcat/7.0.37 Jun 16, 2014 12:26:04 PM org.apache.catalina.core.ContainerBase startInternal SEVERE: A child container failed during start java.util.concurrent.ExecutionException: org.apache.catalina.LifecycleException: Failed to start component [StandardEngine[Tomcat].StandardHost[localhost].StandardContext[/SiteDesigner]] at java.util.concurrent.FutureTask.report(FutureTask.java:122) at java.util.concurrent.FutureTask.get(FutureTask.java:188) at org.apache.catalina.core.ContainerBase.startInternal(ContainerBase.java:1123) at org.apache.catalina.core.StandardHost.startInternal(StandardHost.java:800) at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:150) at org.apache.catalina.core.ContainerBase$StartChild.call(ContainerBase.java:1559) at org.apache.catalina.core.ContainerBase$StartChild.call(ContainerBase.java:1549) at java.util.concurrent.FutureTask.run(FutureTask.java:262) at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145) at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615) at java.lang.Thread.run(Thread.java:745) Caused by: org.apache.catalina.LifecycleException: Failed to start component [StandardEngine[Tomcat].StandardHost[localhost].StandardContext[/SiteDesigner]] at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:154) ... 6 more Caused by: java.lang.ClassCastException: org.springframework.web.SpringServletContainerInitializer cannot be cast to javax.servlet.ServletContainerInitializer at org.apache.catalina.startup.ContextConfig.getServletContainerInitializer(ContextConfig.java:1661) at org.apache.catalina.startup.ContextConfig.processServletContainerInitializers(ContextConfig.java:1569) at org.apache.catalina.startup.ContextConfig.webConfig(ContextConfig.java:1277) at org.apache.catalina.startup.ContextConfig.configureStart(ContextConfig.java:878) at org.apache.catalina.startup.ContextConfig.lifecycleEvent(ContextConfig.java:369) at org.apache.catalina.util.LifecycleSupport.fireLifecycleEvent(LifecycleSupport.java:119) at org.apache.catalina.util.LifecycleBase.fireLifecycleEvent(LifecycleBase.java:90) at org.apache.catalina.core.StandardContext.startInternal(StandardContext.java:5179) at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:150) ... 6 more Jun 16, 2014 12:26:04 PM org.apache.catalina.core.ContainerBase startInternal SEVERE: A child container failed during start java.util.concurrent.ExecutionException: org.apache.catalina.LifecycleException: Failed to start component [StandardEngine[Tomcat].StandardHost[localhost]] at java.util.concurrent.FutureTask.report(FutureTask.java:122) at java.util.concurrent.FutureTask.get(FutureTask.java:188) at org.apache.catalina.core.ContainerBase.startInternal(ContainerBase.java:1123) at org.apache.catalina.core.StandardEngine.startInternal(StandardEngine.java:302) at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:150) at org.apache.catalina.core.StandardService.startInternal(StandardService.java:443) at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:150) at org.apache.catalina.core.StandardServer.startInternal(StandardServer.java:732) at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:150) at org.apache.catalina.startup.Tomcat.start(Tomcat.java:335) at org.apache.tomcat.maven.plugin.tomcat7.run.AbstractRunMojo.startContainer(AbstractRunMojo.java:1091) at org.apache.tomcat.maven.plugin.tomcat7.run.AbstractRunMojo.execute(AbstractRunMojo.java:512) at org.apache.maven.plugin.DefaultBuildPluginManager.executeMojo(DefaultBuildPluginManager.java:101) at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:209) at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:153) at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:145) at org.apache.maven.lifecycle.internal.LifecycleModuleBuilder.buildProject(LifecycleModuleBuilder.java:84) at org.apache.maven.lifecycle.internal.LifecycleModuleBuilder.buildProject(LifecycleModuleBuilder.java:59) at org.apache.maven.lifecycle.internal.LifecycleStarter.singleThreadedBuild(LifecycleStarter.java:183) at org.apache.maven.lifecycle.internal.LifecycleStarter.execute(LifecycleStarter.java:161) at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:320) at org.apache.maven.DefaultMaven.execute(DefaultMaven.java:156) at org.apache.maven.cli.MavenCli.execute(MavenCli.java:537) at org.apache.maven.cli.MavenCli.doMain(MavenCli.java:196) at org.apache.maven.cli.MavenCli.main(MavenCli.java:141) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.lang.reflect.Method.invoke(Method.java:606) at org.codehaus.plexus.classworlds.launcher.Launcher.launchEnhanced(Launcher.java:290) at org.codehaus.plexus.classworlds.launcher.Launcher.launch(Launcher.java:230) at org.codehaus.plexus.classworlds.launcher.Launcher.mainWithExitCode(Launcher.java:409) at org.codehaus.plexus.classworlds.launcher.Launcher.main(Launcher.java:352) Caused by: org.apache.catalina.LifecycleException: Failed to start component [StandardEngine[Tomcat].StandardHost[localhost]] at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:154) at org.apache.catalina.core.ContainerBase$StartChild.call(ContainerBase.java:1559) at org.apache.catalina.core.ContainerBase$StartChild.call(ContainerBase.java:1549) at java.util.concurrent.FutureTask.run(FutureTask.java:262) at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145) at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615) at java.lang.Thread.run(Thread.java:745) Caused by: org.apache.catalina.LifecycleException: A child container failed during start at org.apache.catalina.core.ContainerBase.startInternal(ContainerBase.java:1131) at org.apache.catalina.core.StandardHost.startInternal(StandardHost.java:800) at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:150) ... 6 more [INFO] ------------------------------------------------------------------------ [INFO] BUILD FAILURE [INFO] ------------------------------------------------------------------------ [INFO] Total time: 1.982s [INFO] Finished at: Mon Jun 16 12:26:04 FET 2014 [INFO] Final Memory: 17M/221M [INFO] ------------------------------------------------------------------------ [ERROR] Failed to execute goal org.apache.tomcat.maven:tomcat7-maven-plugin:2.1:run (default-cli) on project SiteDesigner: Could not start Tomcat: Failed to start component [StandardServer[-1]]: Failed to start component [StandardService[Tomcat]]: Failed to start component [StandardEngine[Tomcat]]: A child container failed during start -> [Help 1] org.apache.maven.lifecycle.LifecycleExecutionException: Failed to execute goal org.apache.tomcat.maven:tomcat7-maven-plugin:2.1:run (default-cli) on project SiteDesigner: Could not start Tomcat at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:217) at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:153) at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:145) at org.apache.maven.lifecycle.internal.LifecycleModuleBuilder.buildProject(LifecycleModuleBuilder.java:84) at org.apache.maven.lifecycle.internal.LifecycleModuleBuilder.buildProject(LifecycleModuleBuilder.java:59) at org.apache.maven.lifecycle.internal.LifecycleStarter.singleThreadedBuild(LifecycleStarter.java:183) at org.apache.maven.lifecycle.internal.LifecycleStarter.execute(LifecycleStarter.java:161) at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:320) at org.apache.maven.DefaultMaven.execute(DefaultMaven.java:156) at org.apache.maven.cli.MavenCli.execute(MavenCli.java:537) at org.apache.maven.cli.MavenCli.doMain(MavenCli.java:196) at org.apache.maven.cli.MavenCli.main(MavenCli.java:141) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.lang.reflect.Method.invoke(Method.java:606) at org.codehaus.plexus.classworlds.launcher.Launcher.launchEnhanced(Launcher.java:290) at org.codehaus.plexus.classworlds.launcher.Launcher.launch(Launcher.java:230) at org.codehaus.plexus.classworlds.launcher.Launcher.mainWithExitCode(Launcher.java:409) at org.codehaus.plexus.classworlds.launcher.Launcher.main(Launcher.java:352) Caused by: org.apache.maven.plugin.MojoExecutionException: Could not start Tomcat at org.apache.tomcat.maven.plugin.tomcat7.run.AbstractRunMojo.execute(AbstractRunMojo.java:520) at org.apache.maven.plugin.DefaultBuildPluginManager.executeMojo(DefaultBuildPluginManager.java:101) at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:209) ... 19 more Caused by: org.apache.catalina.LifecycleException: Failed to start component [StandardServer[-1]] at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:154) at org.apache.catalina.startup.Tomcat.start(Tomcat.java:335) at org.apache.tomcat.maven.plugin.tomcat7.run.AbstractRunMojo.startContainer(AbstractRunMojo.java:1091) at org.apache.tomcat.maven.plugin.tomcat7.run.AbstractRunMojo.execute(AbstractRunMojo.java:512) ... 21 more Caused by: org.apache.catalina.LifecycleException: Failed to start component [StandardService[Tomcat]] at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:154) at org.apache.catalina.core.StandardServer.startInternal(StandardServer.java:732) at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:150) ... 24 more Caused by: org.apache.catalina.LifecycleException: Failed to start component [StandardEngine[Tomcat]] at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:154) at org.apache.catalina.core.StandardService.startInternal(StandardService.java:443) at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:150) ... 26 more Caused by: org.apache.catalina.LifecycleException: A child container failed during start at org.apache.catalina.core.ContainerBase.startInternal(ContainerBase.java:1131) at org.apache.catalina.core.StandardEngine.startInternal(StandardEngine.java:302) at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:150) ... 28 more [ERROR] [ERROR] Re-run Maven using the -X switch to enable full debug logging. [ERROR] [ERROR] For more information about the errors and possible solutions, please read the following articles: [ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/MojoExecutionException Вроде подключил все как надо, доступ к БД в бине dataSource. ... |
| 16.06.2014, 14:40:24 |
Файл db.changelog-master.xml имеется, версия сервлетов 2.4, версия веб-проекта 3.0 ... |
| 16.06.2014, 14:43:20 |
А ещё версия у меня томката 7.0.53, но при дебаге в еклипсе пишет другую версию: Код: java 1. 2. 3. ... |
| 16.06.2014, 14:45:41 |
Научитесь искать ключевую ошибку. Вот она. авторCaused by: java.lang.ClassCastException: org.springframework.web.SpringServletContainerInitializer cannot be cast to javax.servlet.ServletContainerInitializer Похоже что у вас в приложение servlet api попадает. Tomcat вообще-то исключает такие либы при деплое приложения. Старая версия какая-то? ... |
| 16.06.2014, 14:46:24 |
pom покажите. Там есть servlet api? Для него проставлен scope=compile? ... |
| 16.06.2014, 14:48:18 |
pom.xml Код: xml 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. 15. 16. 17. 18. 19. 20. 21. 22. 23. 24. 25. 26. 27. 28. 29. 30. 31. 32. 33. 34. 35. 36. 37. 38. 39. 40. 41. 42. 43. 44. 45. 46. 47. 48. 49. 50. 51. 52. 53. 54. 55. 56. 57. 58. 59. 60. 61. 62. 63. 64. 65. 66. 67. 68. 69. 70. 71. 72. 73. 74. 75. 76. 77. 78. 79. 80. 81. 82. 83. 84. 85. 86. 87. 88. 89. 90. 91. 92. 93. 94. 95. 96. 97. 98. 99. 100. 101. 102. 103. 104. 105. 106. 107. 108. 109. 110. 111. 112. 113. 114. 115. 116. 117. 118. 119. 120. 121. 122. 123. 124. 125. 126. 127. 128. 129. 130. 131. 132. 133. 134. 135. 136. 137. 138. 139. 140. 141. 142. 143. 144. 145. 146. 147. 148. 149. 150. 151. 152. 153. 154. 155. 156. 157. 158. 159. 160. 161. scope стоял provider, поменял на compile, но ошибка не исчезла. ... |
| 16.06.2014, 14:52:23 |
Паша01scope стоял provider, поменял на compile, но ошибка не исчезла. Вы бы что ли сверялись с документацией иногда. А то кто-то ляпнет на форуме, а вы и верите на слово. Конечно provided. http://maven.apache.org/guides/introduction/introduction-to-dependency-mechanism.html ... |
| 16.06.2014, 14:56:23 |
ну да, вижу, но на ошибку не влияет =( ... |
| 16.06.2014, 15:00:52 |
А зачем Tomcat из мавена запускать? Эклипс сам не умеет? ... |
| 16.06.2014, 15:03:30 |
BlazkowiczА зачем Tomcat из мавена запускать? Эклипс сам не умеет? Ну думал, что 1 командой мавен и скомпилирует, и задеплоит, и сам томкат запустит. ... |
| 16.06.2014, 15:05:40 |
0) Сделать clean. Попробовать ещё раз. 1) Убедиться что дело действительно в servlet-api. Запустить. Увидеть ошибку. Посмотреть че там в target собралось. Найти там servlet-api в либах. 2) Если servlet-api обнаружен, искать источник. ... |
| 16.06.2014, 15:12:01 |
Blazkowicz Спасибо, теперь хоть знаю, куда копать, уже столько раз помогали ))) ... |
| 16.06.2014, 15:13:17 |
В общем как всегда, проблема всплыла из неожиданного места. Код: xml 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. 15. 16. 17. 18. 19. Мавен после указания tomcat7-maven-plugin качал другую версию библиотеки servlet-api, которая и вызывала конфликт. Короче убрал его нафиг, все заработало и зацвело. ... |
| 16.06.2014, 17:58:06 |
start [/forum/topic.php?fid=59&gotonew=1&tid=2127044]: |
47ms |
77ms |
| others: | 305ms |
| total: | 512ms |
