Подключение к БД MSSQL 2012 Express
Доброго времени суток! Ситуация такая, установил MSSQL 2012 Express. Залогиниться получается без проблем, т.е. ввожу адрес сервера 127.0.0.1/SQLEXPRESS , логин UserPasha , пароль Wat123 . Работает. Но как только в приложении пытаюсь к БД подключиться, выдает ошибку java.sql.SQLException: Network error IOException: Connection refused: connect Полный лог ошибки WARN [com.mchange.v2.async.ThreadPoolAsynchronousRunner$PoolThread-#0] (BasicResourcePool.java:1841) - com.mchange.v2.resourcepool.BasicResourcePool$AcquireTask@52acc299 -- Acquisition Attempt Failed!!! Clearing pending acquires. While trying to acquire a needed new resource, we failed to succeed more than the maximum number of allowed acquisition attempts (30). Last acquisition attempt exception: java.sql.SQLException: Network error IOException: Connection refused: connect at net.sourceforge.jtds.jdbc.ConnectionJDBC2.<init>(ConnectionJDBC2.java:395) at net.sourceforge.jtds.jdbc.ConnectionJDBC3.<init>(ConnectionJDBC3.java:50) at net.sourceforge.jtds.jdbc.Driver.connect(Driver.java:184) at com.mchange.v2.c3p0.DriverManagerDataSource.getConnection(DriverManagerDataSource.java:134) at com.mchange.v2.c3p0.WrapperConnectionPoolDataSource.getPooledConnection(WrapperConnectionPoolDataSource.java:182) at com.mchange.v2.c3p0.WrapperConnectionPoolDataSource.getPooledConnection(WrapperConnectionPoolDataSource.java:171) at com.mchange.v2.c3p0.impl.C3P0PooledConnectionPool$1PooledConnectionResourcePoolManager.acquireResource(C3P0PooledConnectionPool.java:137) at com.mchange.v2.resourcepool.BasicResourcePool.doAcquire(BasicResourcePool.java:1014) at com.mchange.v2.resourcepool.BasicResourcePool.access$800(BasicResourcePool.java:32) at com.mchange.v2.resourcepool.BasicResourcePool$AcquireTask.run(BasicResourcePool.java:1810) at com.mchange.v2.async.ThreadPoolAsynchronousRunner$PoolThread.run(ThreadPoolAsynchronousRunner.java:547) Caused by: java.net.ConnectException: Connection refused: connect at java.net.DualStackPlainSocketImpl.connect0(Native Method) at java.net.DualStackPlainSocketImpl.socketConnect(DualStackPlainSocketImpl.java:79) at java.net.AbstractPlainSocketImpl.doConnect(AbstractPlainSocketImpl.java:339) at java.net.AbstractPlainSocketImpl.connectToAddress(AbstractPlainSocketImpl.java:200) at java.net.AbstractPlainSocketImpl.connect(AbstractPlainSocketImpl.java:182) at java.net.PlainSocketImpl.connect(PlainSocketImpl.java:172) at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:392) at java.net.Socket.connect(Socket.java:579) at sun.reflect.GeneratedMethodAccessor24.invoke(Unknown Source) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.lang.reflect.Method.invoke(Method.java:606) at net.sourceforge.jtds.jdbc.SharedSocket.createSocketForJDBC3(SharedSocket.java:305) at net.sourceforge.jtds.jdbc.SharedSocket.<init>(SharedSocket.java:255) at net.sourceforge.jtds.jdbc.ConnectionJDBC2.<init>(ConnectionJDBC2.java:323) ... 10 more WARN [RMI TCP Connection(3)-127.0.0.1] (JdbcServicesImpl.java:169) - HHH000342: Could not obtain connection to query metadata : Connections could not be acquired from the underlying database! WARN [com.mchange.v2.async.ThreadPoolAsynchronousRunner$PoolThread-#2] (BasicResourcePool.java:1841) - com.mchange.v2.resourcepool.BasicResourcePool$AcquireTask@531d49e6 -- Acquisition Attempt Failed!!! Clearing pending acquires. While trying to acquire a needed new resource, we failed to succeed more than the maximum number of allowed acquisition attempts (30). Last acquisition attempt exception: java.sql.SQLException: Network error IOException: Connection refused: connect at net.sourceforge.jtds.jdbc.ConnectionJDBC2.<init>(ConnectionJDBC2.java:395) at net.sourceforge.jtds.jdbc.ConnectionJDBC3.<init>(ConnectionJDBC3.java:50) at net.sourceforge.jtds.jdbc.Driver.connect(Driver.java:184) at com.mchange.v2.c3p0.DriverManagerDataSource.getConnection(DriverManagerDataSource.java:134) at com.mchange.v2.c3p0.WrapperConnectionPoolDataSource.getPooledConnection(WrapperConnectionPoolDataSource.java:182) at com.mchange.v2.c3p0.WrapperConnectionPoolDataSource.getPooledConnection(WrapperConnectionPoolDataSource.java:171) at com.mchange.v2.c3p0.impl.C3P0PooledConnectionPool$1PooledConnectionResourcePoolManager.acquireResource(C3P0PooledConnectionPool.java:137) at com.mchange.v2.resourcepool.BasicResourcePool.doAcquire(BasicResourcePool.java:1014) at com.mchange.v2.resourcepool.BasicResourcePool.access$800(BasicResourcePool.java:32) at com.mchange.v2.resourcepool.BasicResourcePool$AcquireTask.run(BasicResourcePool.java:1810) at com.mchange.v2.async.ThreadPoolAsynchronousRunner$PoolThread.run(ThreadPoolAsynchronousRunner.java:547) Caused by: java.net.ConnectException: Connection refused: connect at java.net.DualStackPlainSocketImpl.connect0(Native Method) at java.net.DualStackPlainSocketImpl.socketConnect(DualStackPlainSocketImpl.java:79) at java.net.AbstractPlainSocketImpl.doConnect(AbstractPlainSocketImpl.java:339) at java.net.AbstractPlainSocketImpl.connectToAddress(AbstractPlainSocketImpl.java:200) at java.net.AbstractPlainSocketImpl.connect(AbstractPlainSocketImpl.java:182) at java.net.PlainSocketImpl.connect(PlainSocketImpl.java:172) at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:392) at java.net.Socket.connect(Socket.java:579) at sun.reflect.GeneratedMethodAccessor24.invoke(Unknown Source) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.lang.reflect.Method.invoke(Method.java:606) at net.sourceforge.jtds.jdbc.SharedSocket.createSocketForJDBC3(SharedSocket.java:305) at net.sourceforge.jtds.jdbc.SharedSocket.<init>(SharedSocket.java:255) at net.sourceforge.jtds.jdbc.ConnectionJDBC2.<init>(ConnectionJDBC2.java:323) ... 10 more INFO [RMI TCP Connection(3)-127.0.0.1] (Dialect.java:128) - HHH000400: Using dialect: org.hibernate.dialect.SQLServerDialect INFO [RMI TCP Connection(3)-127.0.0.1] (LobCreatorBuilder.java:85) - HHH000422: Disabling contextual LOB creation as connection was null INFO [RMI TCP Connection(3)-127.0.0.1] (TransactionFactoryInitiator.java:73) - HHH000268: Transaction strategy: org.hibernate.engine.transaction.internal.jdbc.JdbcTransactionFactory INFO [RMI TCP Connection(3)-127.0.0.1] (ASTQueryTranslatorFactory.java:48) - HHH000397: Using ASTQueryTranslatorFactory INFO [RMI TCP Connection(3)-127.0.0.1] (Version.java:24) - Hibernate Validator 4.2.0.Final INFO [RMI TCP Connection(3)-127.0.0.1] (DefaultListableBeanFactory.java:596) - Pre-instantiating singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@20f8f517: defining beans [org.springframework.aop.config.internalAutoProxyCreator,org.springframework.transaction.annotation.AnnotationTransactionAttributeSource#0,org.springframework.transaction.interceptor.TransactionInterceptor#0,org.springframework.transaction.config.internalTransactionAdvisor,org.springframework.scheduling.support.ScheduledMethodRunnable#0,org.springframework.scheduling.config.CronTask#0,org.springframework.scheduling.config.ContextLifecycleScheduledTaskRegistrar#0,scopedTarget.userSession,userSession,changeGroupDAO,historyService,preferenceService,issueService,attachmentService,attachmentDAO,transactionManager,org.springframework.beans.factory.config.PropertyPlaceholderConfigurer#0,propertyConfigurer,org.springframework.beans.factory.config.PropertyPlaceholderConfigurer#1,viewResolverTiles,viewResolver,dataSource,persistenceUnitManager,org.springframework.orm.jpa.support.PersistenceAnnotationBeanPostProcessor#0,entityManagerFactory,jpaVendorAdapter,multipartResolver,packagesToScan,employeeDAO,employeeService,synchronizeWithLdapService,userRoleDAO,userRoleService,issueDAO,preferenceDAO,authAdUserDao,attributeDAO,attributeService,commentDAO,commentService,by_minskContextSource,us_mplsContextSource,by_minskLdapUrls,us_mplsLdapUrls,by_minskLdapTemplate,us_mplsLdapTemplate,velocityEngine,notificationsService,properties,exchange,emailEventHandlerService,tilesConfigurer,tokenRepository,persistentTokenRememberMeService,userDetailsService,customSecurityFilter,org.springframework.security.filterChains,org.springframework.security.filterChainProxy,org.springframework.security.web.PortMapperImpl#0,org.springframework.security.web.PortResolverImpl#0,org.springframework.security.config.authentication.AuthenticationManagerFactoryBean#0,org.springframework.security.authentication.ProviderManager#0,org.springframework.security.web.context.HttpSessionSecurityContextRepository#0,org.springframework.security.web.authentication.session.SessionFixationProtectionStrategy#0,org.springframework.security.web.savedrequest.HttpSessionRequestCache#0,org.springframework.security.web.access.channel.ChannelDecisionManagerImpl#0,org.springframework.security.web.access.expression.DefaultWebSecurityExpressionHandler#0,org.springframework.security.access.vote.AffirmativeBased#0,org.springframework.security.web.access.intercept.FilterSecurityInterceptor#0,org.springframework.security.web.access.DefaultWebInvocationPrivilegeEvaluator#0,org.springframework.security.authentication.AnonymousAuthenticationProvider#0,org.springframework.security.authentication.RememberMeAuthenticationProvider#0,org.springframework.security.web.authentication.www.BasicAuthenticationEntryPoint#0,org.springframework.security.web.authentication.UsernamePasswordAuthenticationFilter#0,org.springframework.security.userDetailsServiceFactory,org.springframework.security.web.DefaultSecurityFilterChain#0,org.springframework.security.authentication.DefaultAuthenticationEventPublisher#0,org.springframework.security.authenticationManager,authenticationFailureHandler,exceptionMappings,customAuthenticationProvider]; root of factory hierarchy INFO [RMI TCP Connection(3)-127.0.0.1] (DefaultSingletonBeanRegistry.java:444) - Destroying singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@20f8f517: defining beans [org.springframework.aop.config.internalAutoProxyCreator,org.springframework.transaction.annotation.AnnotationTransactionAttributeSource#0,org.springframework.transaction.interceptor.TransactionInterceptor#0,org.springframework.transaction.config.internalTransactionAdvisor,org.springframework.scheduling.support.ScheduledMethodRunnable#0,org.springframework.scheduling.config.CronTask#0,org.springframework.scheduling.config.ContextLifecycleScheduledTaskRegistrar#0,scopedTarget.userSession,userSession,changeGroupDAO,historyService,preferenceService,issueService,attachmentService,attachmentDAO,transactionManager,org.springframework.beans.factory.config.PropertyPlaceholderConfigurer#0,propertyConfigurer,org.springframework.beans.factory.config.PropertyPlaceholderConfigurer#1,viewResolverTiles,viewResolver,dataSource,persistenceUnitManager,org.springframework.orm.jpa.support.PersistenceAnnotationBeanPostProcessor#0,entityManagerFactory,jpaVendorAdapter,multipartResolver,packagesToScan,employeeDAO,employeeService,synchronizeWithLdapService,userRoleDAO,userRoleService,issueDAO,preferenceDAO,authAdUserDao,attributeDAO,attributeService,commentDAO,commentService,by_minskContextSource,us_mplsContextSource,by_minskLdapUrls,us_mplsLdapUrls,by_minskLdapTemplate,us_mplsLdapTemplate,velocityEngine,notificationsService,properties,exchange,emailEventHandlerService,tilesConfigurer,tokenRepository,persistentTokenRememberMeService,userDetailsService,customSecurityFilter,org.springframework.security.filterChains,org.springframework.security.filterChainProxy,org.springframework.security.web.PortMapperImpl#0,org.springframework.security.web.PortResolverImpl#0,org.springframework.security.config.authentication.AuthenticationManagerFactoryBean#0,org.springframework.security.authentication.ProviderManager#0,org.springframework.security.web.context.HttpSessionSecurityContextRepository#0,org.springframework.security.web.authentication.session.SessionFixationProtectionStrategy#0,org.springframework.security.web.savedrequest.HttpSessionRequestCache#0,org.springframework.security.web.access.channel.ChannelDecisionManagerImpl#0,org.springframework.security.web.access.expression.DefaultWebSecurityExpressionHandler#0,org.springframework.security.access.vote.AffirmativeBased#0,org.springframework.security.web.access.intercept.FilterSecurityInterceptor#0,org.springframework.security.web.access.DefaultWebInvocationPrivilegeEvaluator#0,org.springframework.security.authentication.AnonymousAuthenticationProvider#0,org.springframework.security.authentication.RememberMeAuthenticationProvider#0,org.springframework.security.web.authentication.www.BasicAuthenticationEntryPoint#0,org.springframework.security.web.authentication.UsernamePasswordAuthenticationFilter#0,org.springframework.security.userDetailsServiceFactory,org.springframework.security.web.DefaultSecurityFilterChain#0,org.springframework.security.authentication.DefaultAuthenticationEventPublisher#0,org.springframework.security.authenticationManager,authenticationFailureHandler,exceptionMappings,customAuthenticationProvider]; root of factory hierarchy INFO [RMI TCP Connection(3)-127.0.0.1] (AbstractEntityManagerFactoryBean.java:441) - Closing JPA EntityManagerFactory for persistence unit 'persistenceUnit' ERROR [RMI TCP Connection(3)-127.0.0.1] (ContextLoader.java:319) - Context initialization failed org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'historyService' defined in ServletContext resource [/WEB-INF/applicationContext.xml]: Cannot resolve reference to bean 'notificationsService' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'notificationsService' defined in ServletContext resource [/WEB-INF/applicationContext.xml]: Cannot resolve reference to bean 'emailService' while setting constructor argument; nested exception is org.springframework.beans.factory.NoSuchBeanDefinitionException: No bean named 'emailService' is defined at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveReference(BeanDefinitionValueResolver.java:329) at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveValueIfNecessary(BeanDefinitionValueResolver.java:107) at org.springframework.beans.factory.support.ConstructorResolver.resolveConstructorArguments(ConstructorResolver.java:629) at org.springframework.beans.factory.support.ConstructorResolver.autowireConstructor(ConstructorResolver.java:148) at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.autowireConstructor(AbstractAutowireCapableBeanFactory.java:1051) at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBeanInstance(AbstractAutowireCapableBeanFactory.java:955) at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:490) at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:461) at org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:295) at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:223) at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:292) at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:194) at org.springframework.beans.factory.support.DefaultListableBeanFactory.preInstantiateSingletons(DefaultListableBeanFactory.java:626) at org.springframework.context.support.AbstractApplicationContext.finishBeanFactoryInitialization(AbstractApplicationContext.java:932) at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:479) at org.springframework.web.context.ContextLoader.configureAndRefreshWebApplicationContext(ContextLoader.java:389) at org.springframework.web.context.ContextLoader.initWebApplicationContext(ContextLoader.java:294) at org.springframework.web.context.ContextLoaderListener.contextInitialized(ContextLoaderListener.java:112) at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:4973) at org.apache.catalina.core.StandardContext.startInternal(StandardContext.java:5467) at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:150) at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:901) at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:877) at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:632) at org.apache.catalina.startup.HostConfig.manageApp(HostConfig.java:1763) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.lang.reflect.Method.invoke(Method.java:606) at org.apache.tomcat.util.modeler.BaseModelMBean.invoke(BaseModelMBean.java:301) at com.sun.jmx.interceptor.DefaultMBeanServerInterceptor.invoke(DefaultMBeanServerInterceptor.java:819) at com.sun.jmx.mbeanserver.JmxMBeanServer.invoke(JmxMBeanServer.java:801) at org.apache.catalina.mbeans.MBeanFactory.createStandardContext(MBeanFactory.java:618) at org.apache.catalina.mbeans.MBeanFactory.createStandardContext(MBeanFactory.java:565) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.lang.reflect.Method.invoke(Method.java:606) at org.apache.tomcat.util.modeler.BaseModelMBean.invoke(BaseModelMBean.java:301) at com.sun.jmx.interceptor.DefaultMBeanServerInterceptor.invoke(DefaultMBeanServerInterceptor.java:819) at com.sun.jmx.mbeanserver.JmxMBeanServer.invoke(JmxMBeanServer.java:801) at javax.management.remote.rmi.RMIConnectionImpl.doOperation(RMIConnectionImpl.java:1487) at javax.management.remote.rmi.RMIConnectionImpl.access$300(RMIConnectionImpl.java:97) at javax.management.remote.rmi.RMIConnectionImpl$PrivilegedOperation.run(RMIConnectionImpl.java:1328) at javax.management.remote.rmi.RMIConnectionImpl.doPrivilegedOperation(RMIConnectionImpl.java:1420) at javax.management.remote.rmi.RMIConnectionImpl.invoke(RMIConnectionImpl.java:848) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.lang.reflect.Method.invoke(Method.java:606) at sun.rmi.server.UnicastServerRef.dispatch(UnicastServerRef.java:322) at sun.rmi.transport.Transport$1.run(Transport.java:177) at sun.rmi.transport.Transport$1.run(Transport.java:174) at java.security.AccessController.doPrivileged(Native Method) at sun.rmi.transport.Transport.serviceCall(Transport.java:173) at sun.rmi.transport.tcp.TCPTransport.handleMessages(TCPTransport.java:556) at sun.rmi.transport.tcp.TCPTransport$ConnectionHandler.run0(TCPTransport.java:811) at sun.rmi.transport.tcp.TCPTransport$ConnectionHandler.run(TCPTransport.java:670) at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145) at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615) at java.lang.Thread.run(Thread.java:745) Caused by: org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'notificationsService' defined in ServletContext resource [/WEB-INF/applicationContext.xml]: Cannot resolve reference to bean 'emailService' while setting constructor argument; nested exception is org.springframework.beans.factory.NoSuchBeanDefinitionException: No bean named 'emailService' is defined at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveReference(BeanDefinitionValueResolver.java:329) at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveValueIfNecessary(BeanDefinitionValueResolver.java:107) at org.springframework.beans.factory.support.ConstructorResolver.resolveConstructorArguments(ConstructorResolver.java:629) at org.springframework.beans.factory.support.ConstructorResolver.autowireConstructor(ConstructorResolver.java:148) at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.autowireConstructor(AbstractAutowireCapableBeanFactory.java:1051) at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBeanInstance(AbstractAutowireCapableBeanFactory.java:955) at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:490) at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:461) at org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:295) at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:223) at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:292) at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:194) at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveReference(BeanDefinitionValueResolver.java:323) ... 60 more Caused by: org.springframework.beans.factory.NoSuchBeanDefinitionException: No bean named 'emailService' is defined at org.springframework.beans.factory.support.DefaultListableBeanFactory.getBeanDefinition(DefaultListableBeanFactory.java:568) at org.springframework.beans.factory.support.AbstractBeanFactory.getMergedLocalBeanDefinition(AbstractBeanFactory.java:1102) at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:278) at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:194) at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveReference(BeanDefinitionValueResolver.java:323) ... 72 more Приложение написано на Spring, Hibernate, Maven. Вот профиль в maven Код: xml 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. Вот путь к БД прописываю Код: java 1. 2. 3. 4. Пробывал по-разному писать IP сервера, не помогло. Есть подозрение на то, что это из-за строки на скриншоте, которую подчеркивает серым. ... |
| 05.07.2014, 20:13:44 |
Паша01 , Поставьте брейкпоинт в исходниках Spring в том месте, где он начинает создавать этот бин. И посмотрите, как выглядит строка подкючения, все ли в нее правильно вставилось. ... |
| 05.07.2014, 20:21:42 |
DEVcoach, А как мне это сделать? Я в этом деле новичек. Научите, пожалуйста. Уверен и в будущем пригодиться. Как я понимаю, вызывается класс из джарника Код: java 1. 2. А что дальше делать? Или киньте линк, где почитать про это. ... |
| 05.07.2014, 20:29:35 |
Паша01А как мне это сделать?Можно и без отладчика. Руками вписываете нужные значения вместо ${переменная} ... |
| 06.07.2014, 06:38:12 |
У SQL Server в настройках нужно TCP коннектор проверить. Зачастую он выключен по-умолчанию. ... |
| 07.07.2014, 09:03:38 |
Паша01, SQLEXPRESS садится не на стандартный порт, надо идти в SQL Server Configuration Manager и в TCP/IP и в закладке IP-адреса узнать порт или выставит на стандартный 1433 ... |
| 07.07.2014, 09:32:33 |
BlazkowiczУ SQL Server в настройках нужно TCP коннектор проверить. Зачастую он выключен по-умолчанию. TCp коннектор включал в настройках сразу, и перепроверял несколько раз ... |
| 07.07.2014, 11:20:48 |
Паша01TCp коннектор включал в настройках сразу, и перепроверял несколько раз Тогда была бы другая ошибка. Именно эта обозначает не возможность подсоединения. java.sql.SQLException: Network error IOException: Connection refused: connect То есть. Либо TCP выключен. Либо включен, но на другом порту. Либо включен, на нужном порту, но закрыт firewall-ом. ... |
| 07.07.2014, 11:24:05 |
am_sasaПаша01, SQLEXPRESS садится не на стандартный порт, надо идти в SQL Server Configuration Manager и в TCP/IP и в закладке IP-адреса узнать порт или выставит на стандартный 1433 Поставил и на localhost и на IPAll, но ничего не поменялось ... |
| 07.07.2014, 11:26:52 |
BlazkowiczТогда была бы другая ошибка. Именно эта обозначает не возможность подсоединения. java.sql.SQLException: Network error IOException: Connection refused: connect То есть. Либо TCP выключен. Либо включен, но на другом порту. Либо включен, на нужном порту, но закрыт firewall-ом. TCP включал, на скрине видно firewall вообще вырубил, а порт на скрине в пред посте ставил, 1433 стоит ... |
| 07.07.2014, 11:31:45 |
Ну вроде одолел, поудаляв динамические IP и прописывая везде порт 1433. Но теперь другая ошибка nested exception is org.springframework.beans.factory.BeanCreationException: Unknown channel attribute tcp Полный лог ERROR [RMI TCP Connection(3)-127.0.0.1] (ContextLoader.java:319) - Context initialization failed org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'org.springframework.security.filterChains': Cannot resolve reference to bean 'org.springframework.security.web.DefaultSecurityFilterChain#0' while setting bean property 'sourceList' with key [0]; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'org.springframework.security.web.DefaultSecurityFilterChain#0': Cannot create inner bean '(inner bean)' of type [org.springframework.security.web.access.channel.ChannelProcessingFilter] while setting constructor argument with key [0]; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name '(inner bean)#1': Cannot create inner bean '(inner bean)' of type [org.springframework.security.web.access.intercept.DefaultFilterInvocationSecurityMetadataSource] while setting bean property 'securityMetadataSource'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name '(inner bean)#1': Cannot create inner bean '(inner bean)' of type [org.springframework.security.config.http.ChannelAttributeFactory] while setting constructor argument with key [Root bean: class [org.springframework.security.web.util.AntPathRequestMatcher]; scope=; abstract=false; lazyInit=false; autowireMode=0; dependencyCheck=0; autowireCandidate=true; primary=false; factoryBeanName=null; factoryMethodName=null; initMethodName=null; destroyMethodName=null]; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name '(inner bean)#2': Instantiation of bean failed; nested exception is org.springframework.beans.factory.BeanDefinitionStoreException: Factory method [public static java.util.List org.springframework.security.config.http.ChannelAttributeFactory.createChannelAttributes(java.lang.String)] threw exception; nested exception is org.springframework.beans.factory.BeanCreationException: Unknown channel attribute tcp at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveReference(BeanDefinitionValueResolver.java:329) at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveValueIfNecessary(BeanDefinitionValueResolver.java:107) at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveManagedList(BeanDefinitionValueResolver.java:353) at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveValueIfNecessary(BeanDefinitionValueResolver.java:154) at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.applyPropertyValues(AbstractAutowireCapableBeanFactory.java:1393) at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.populateBean(AbstractAutowireCapableBeanFactory.java:1134) at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:522) at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:461) at org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:295) at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:223) at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:292) at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:194) at org.springframework.beans.factory.support.DefaultListableBeanFactory.preInstantiateSingletons(DefaultListableBeanFactory.java:608) at org.springframework.context.support.AbstractApplicationContext.finishBeanFactoryInitialization(AbstractApplicationContext.java:932) at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:479) at org.springframework.web.context.ContextLoader.configureAndRefreshWebApplicationContext(ContextLoader.java:389) at org.springframework.web.context.ContextLoader.initWebApplicationContext(ContextLoader.java:294) at org.springframework.web.context.ContextLoaderListener.contextInitialized(ContextLoaderListener.java:112) at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:4973) at org.apache.catalina.core.StandardContext.startInternal(StandardContext.java:5467) at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:150) at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:901) at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:877) at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:632) at org.apache.catalina.startup.HostConfig.manageApp(HostConfig.java:1763) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.lang.reflect.Method.invoke(Method.java:606) at org.apache.tomcat.util.modeler.BaseModelMBean.invoke(BaseModelMBean.java:301) at com.sun.jmx.interceptor.DefaultMBeanServerInterceptor.invoke(DefaultMBeanServerInterceptor.java:819) at com.sun.jmx.mbeanserver.JmxMBeanServer.invoke(JmxMBeanServer.java:801) at org.apache.catalina.mbeans.MBeanFactory.createStandardContext(MBeanFactory.java:618) at org.apache.catalina.mbeans.MBeanFactory.createStandardContext(MBeanFactory.java:565) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.lang.reflect.Method.invoke(Method.java:606) at org.apache.tomcat.util.modeler.BaseModelMBean.invoke(BaseModelMBean.java:301) at com.sun.jmx.interceptor.DefaultMBeanServerInterceptor.invoke(DefaultMBeanServerInterceptor.java:819) at com.sun.jmx.mbeanserver.JmxMBeanServer.invoke(JmxMBeanServer.java:801) at javax.management.remote.rmi.RMIConnectionImpl.doOperation(RMIConnectionImpl.java:1487) at javax.management.remote.rmi.RMIConnectionImpl.access$300(RMIConnectionImpl.java:97) at javax.management.remote.rmi.RMIConnectionImpl$PrivilegedOperation.run(RMIConnectionImpl.java:1328) at javax.management.remote.rmi.RMIConnectionImpl.doPrivilegedOperation(RMIConnectionImpl.java:1420) at javax.management.remote.rmi.RMIConnectionImpl.invoke(RMIConnectionImpl.java:848) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.lang.reflect.Method.invoke(Method.java:606) at sun.rmi.server.UnicastServerRef.dispatch(UnicastServerRef.java:322) at sun.rmi.transport.Transport$1.run(Transport.java:177) at sun.rmi.transport.Transport$1.run(Transport.java:174) at java.security.AccessController.doPrivileged(Native Method) at sun.rmi.transport.Transport.serviceCall(Transport.java:173) at sun.rmi.transport.tcp.TCPTransport.handleMessages(TCPTransport.java:556) at sun.rmi.transport.tcp.TCPTransport$ConnectionHandler.run0(TCPTransport.java:811) at sun.rmi.transport.tcp.TCPTransport$ConnectionHandler.run(TCPTransport.java:670) at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145) at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615) at java.lang.Thread.run(Thread.java:745) Caused by: org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'org.springframework.security.web.DefaultSecurityFilterChain#0': Cannot create inner bean '(inner bean)' of type [org.springframework.security.web.access.channel.ChannelProcessingFilter] while setting constructor argument with key [0]; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name '(inner bean)#1': Cannot create inner bean '(inner bean)' of type [org.springframework.security.web.access.intercept.DefaultFilterInvocationSecurityMetadataSource] while setting bean property 'securityMetadataSource'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name '(inner bean)#1': Cannot create inner bean '(inner bean)' of type [org.springframework.security.config.http.ChannelAttributeFactory] while setting constructor argument with key [Root bean: class [org.springframework.security.web.util.AntPathRequestMatcher]; scope=; abstract=false; lazyInit=false; autowireMode=0; dependencyCheck=0; autowireCandidate=true; primary=false; factoryBeanName=null; factoryMethodName=null; initMethodName=null; destroyMethodName=null]; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name '(inner bean)#2': Instantiation of bean failed; nested exception is org.springframework.beans.factory.BeanDefinitionStoreException: Factory method [public static java.util.List org.springframework.security.config.http.ChannelAttributeFactory.createChannelAttributes(java.lang.String)] threw exception; nested exception is org.springframework.beans.factory.BeanCreationException: Unknown channel attribute tcp at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveInnerBean(BeanDefinitionValueResolver.java:282) at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveValueIfNecessary(BeanDefinitionValueResolver.java:126) at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveManagedList(BeanDefinitionValueResolver.java:353) at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveValueIfNecessary(BeanDefinitionValueResolver.java:154) at org.springframework.beans.factory.support.ConstructorResolver.resolveConstructorArguments(ConstructorResolver.java:615) at org.springframework.beans.factory.support.ConstructorResolver.autowireConstructor(ConstructorResolver.java:148) at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.autowireConstructor(AbstractAutowireCapableBeanFactory.java:1051) at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBeanInstance(AbstractAutowireCapableBeanFactory.java:955) at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:490) at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:461) at org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:295) at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:223) at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:292) at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:194) at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveReference(BeanDefinitionValueResolver.java:323) ... 60 more Caused by: org.springframework.beans.factory.BeanCreationException: Error creating bean with name '(inner bean)#1': Cannot create inner bean '(inner bean)' of type [org.springframework.security.web.access.intercept.DefaultFilterInvocationSecurityMetadataSource] while setting bean property 'securityMetadataSource'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name '(inner bean)#1': Cannot create inner bean '(inner bean)' of type [org.springframework.security.config.http.ChannelAttributeFactory] while setting constructor argument with key [Root bean: class [org.springframework.security.web.util.AntPathRequestMatcher]; scope=; abstract=false; lazyInit=false; autowireMode=0; dependencyCheck=0; autowireCandidate=true; primary=false; factoryBeanName=null; factoryMethodName=null; initMethodName=null; destroyMethodName=null]; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name '(inner bean)#2': Instantiation of bean failed; nested exception is org.springframework.beans.factory.BeanDefinitionStoreException: Factory method [public static java.util.List org.springframework.security.config.http.ChannelAttributeFactory.createChannelAttributes(java.lang.String)] threw exception; nested exception is org.springframework.beans.factory.BeanCreationException: Unknown channel attribute tcp at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveInnerBean(BeanDefinitionValueResolver.java:282) at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveValueIfNecessary(BeanDefinitionValueResolver.java:126) at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.applyPropertyValues(AbstractAutowireCapableBeanFactory.java:1393) at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.populateBean(AbstractAutowireCapableBeanFactory.java:1134) at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:522) at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:461) at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveInnerBean(BeanDefinitionValueResolver.java:271) ... 74 more Caused by: org.springframework.beans.factory.BeanCreationException: Error creating bean with name '(inner bean)#1': Cannot create inner bean '(inner bean)' of type [org.springframework.security.config.http.ChannelAttributeFactory] while setting constructor argument with key [Root bean: class [org.springframework.security.web.util.AntPathRequestMatcher]; scope=; abstract=false; lazyInit=false; autowireMode=0; dependencyCheck=0; autowireCandidate=true; primary=false; factoryBeanName=null; factoryMethodName=null; initMethodName=null; destroyMethodName=null]; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name '(inner bean)#2': Instantiation of bean failed; nested exception is org.springframework.beans.factory.BeanDefinitionStoreException: Factory method [public static java.util.List org.springframework.security.config.http.ChannelAttributeFactory.createChannelAttributes(java.lang.String)] threw exception; nested exception is org.springframework.beans.factory.BeanCreationException: Unknown channel attribute tcp at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveInnerBean(BeanDefinitionValueResolver.java:282) at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveValueIfNecessary(BeanDefinitionValueResolver.java:126) at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveManagedMap(BeanDefinitionValueResolver.java:379) at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveValueIfNecessary(BeanDefinitionValueResolver.java:162) at org.springframework.beans.factory.support.ConstructorResolver.resolveConstructorArguments(ConstructorResolver.java:615) at org.springframework.beans.factory.support.ConstructorResolver.autowireConstructor(ConstructorResolver.java:148) at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.autowireConstructor(AbstractAutowireCapableBeanFactory.java:1051) at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBeanInstance(AbstractAutowireCapableBeanFactory.java:955) at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:490) at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:461) at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveInnerBean(BeanDefinitionValueResolver.java:271) ... 80 more Caused by: org.springframework.beans.factory.BeanCreationException: Error creating bean with name '(inner bean)#2': Instantiation of bean failed; nested exception is org.springframework.beans.factory.BeanDefinitionStoreException: Factory method [public static java.util.List org.springframework.security.config.http.ChannelAttributeFactory.createChannelAttributes(java.lang.String)] threw exception; nested exception is org.springframework.beans.factory.BeanCreationException: Unknown channel attribute tcp at org.springframework.beans.factory.support.ConstructorResolver.instantiateUsingFactoryMethod(ConstructorResolver.java:581) at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.instantiateUsingFactoryMethod(AbstractAutowireCapableBeanFactory.java:1031) at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBeanInstance(AbstractAutowireCapableBeanFactory.java:927) at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:490) at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:461) at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveInnerBean(BeanDefinitionValueResolver.java:271) ... 90 more Caused by: org.springframework.beans.factory.BeanDefinitionStoreException: Factory method [public static java.util.List org.springframework.security.config.http.ChannelAttributeFactory.createChannelAttributes(java.lang.String)] threw exception; nested exception is org.springframework.beans.factory.BeanCreationException: Unknown channel attribute tcp at org.springframework.beans.factory.support.SimpleInstantiationStrategy.instantiate(SimpleInstantiationStrategy.java:181) at org.springframework.beans.factory.support.ConstructorResolver.instantiateUsingFactoryMethod(ConstructorResolver.java:570) ... 95 more Caused by: org.springframework.beans.factory.BeanCreationException: Unknown channel attribute tcp at org.springframework.security.config.http.ChannelAttributeFactory.createChannelAttributes(ChannelAttributeFactory.java:31) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.lang.reflect.Method.invoke(Method.java:606) at org.springframework.beans.factory.support.SimpleInstantiationStrategy.instantiate(SimpleInstantiationStrategy.java:160) ... 96 more ... |
| 07.07.2014, 12:08:43 |
Паша01Ну вроде одолел, поудаляв динамические IP и прописывая везде порт 1433. Но теперь другая ошибка nested exception is org.springframework.beans.factory.BeanCreationException: Unknown channel attribute tcp Это к БД отношения не имеет. У вас в конфиге какой-то косяк. ... |
| 07.07.2014, 12:11:15 |
BlazkowiczПаша01Ну вроде одолел, поудаляв динамические IP и прописывая везде порт 1433. Но теперь другая ошибка nested exception is org.springframework.beans.factory.BeanCreationException: Unknown channel attribute tcp Это к БД отношения не имеет. У вас в конфиге какой-то косяк. Да, вы правы, поправил, заработало ) Спасибо за помощь ))) ... |
| 07.07.2014, 12:18:32 |
start [/forum/topic.php?fid=59&gotonew=1&tid=2126934]: |
27ms |
46ms |
97ms |
| others: | 303ms |
| total: | 529ms |
