проблема при запуске проекта, grails tool suite
привет. подскажите, пожалуйста, где искать причину фейла старта проекта. Открыл проект, run->run on server->choose an existing server открывается http://localhost:8080/project-name/ description the requested resource is not available сам сервер стартует, в консоль выводится: Mar 31, 2015 8:14:06 PM org.apache.catalina.startup.Catalina load INFO: Initialization processed in 1721 ms Mar 31, 2015 8:14:08 PM org.apache.catalina.startup.Catalina start INFO: Server startup in 1988 ms в логах сервера два ворнинга и остальные инфо. ворнинги - did not find a matching property. последние записи сервера: 31-Mar-2015 20:23:11.224 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deployment of web application directory D:\Apps\ggts-bundle\pivotal-tc-server-developer-3.1.0.RELEASE\base-instance\webapps\ROOT has finished in 203 ms 31-Mar-2015 20:23:11.231 INFO [main] org.apache.coyote.AbstractProtocol.start Starting ProtocolHandler ["http-bio-8080"] ... |
| 31.03.2015, 19:38:06 |
на markers: Groovy:Apparent variable 'javax' was found in a static scope but doesn't refer to a local variable, static field or class. Possible causes: TypeNamesOnJavaObjects.groovy здесь: http://stackoverflow.com/questions/15769863/groovyapparent-variable-xyz-was-found-in-a-static-scope-but-doesnt-refer-to-a запускаю из корня проекта: grails clean | Configuring classpath :: problems summary :: :::: WARNINGS :::::::::::::::::::::::::::::::::::::::::::::: :: UNRESOLVED DEPENDENCIES :: :::::::::::::::::::::::::::::::::::::::::::::: :: org.springframework#spring-test;4.1.5.RELEASE: configuration not found in org.springframework#spring-test;4.1.5.RELEASE: 'compile'. It was re quired from org.grails#grails-plugin-testing;2.5.0 compile :::::::::::::::::::::::::::::::::::::::::::::: | Error Resolve error obtaining dependencies: Failed to resolve dependencies (Se t log level to 'warn' in BuildConfig.groovy for more information): - org.springframework:spring-test:4.1.5.RELEASE (Use --stacktrace to see the full trace) | Error Failed to resolve dependencies (Set log level to 'warn' in BuildConfig.g roovy for more information): - org.springframework:spring-test:4.1.5.RELEASE Может кто знает как решить? ... |
| 01.04.2015, 13:05:18 |
start [/forum/topic.php?fid=59&gotonew=1&tid=2125617]: |
63ms |
61ms |
| others: | 381ms |
| total: | 572ms |
