GWT & Maven
Создал проект maven с архитектурой gwt Вываливается ошибка авторDescription Resource Path Location Type 1 problem was encountered while building the effective model for org.apache.maven.plugins:maven-resources-plugin:2.6 [ERROR] Invalid packaging for parent POM [unknown-group-id]:[unknown-artifact-id]:[unknown-version], must be "pom" but is "jar" @ [unknown-group-id]:[unknown-artifact-id]:[unknown-version] pom.xml /example line 1 Maven Configuration Problem В чем причина? ... |
| 14.04.2015, 11:06:19 |
GWT & Maven
maytonПокажи весь pom. автор <?xml version="1.0" encoding="UTF-8" ?> - <project xmlns=" http://maven.apache.org/POM/4.0.0" xmlns:xsi=" http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation=" http://maven.apache.org/POM/4.0.0 http://maven.apache.org/maven-v4_0_0.xsd"> - <!-- POM file generated with GWT webAppCreator --> <modelVersion>4.0.0</modelVersion> <groupId>by.gwt.test</groupId> <artifactId>example</artifactId> <packaging>war</packaging> <version>1.0-SNAPSHOT</version> <name>GWT Maven Archetype</name> - <properties> - <!-- Convenience property to set the GWT version --> <gwtVersion>2.7.0</gwtVersion> - <!-- GWT needs at least java 1.5 --> <webappDirectory>${project.build.directory}/${project.build.finalName}</webappDirectory> <project.build.sourceEncoding>UTF-8</project.build.sourceEncoding> </properties> - <dependencies> - <dependency> <groupId>com.google.gwt</groupId> <artifactId>gwt-servlet</artifactId> <version>${gwtVersion}</version> <scope>runtime</scope> </dependency> - <dependency> <groupId>com.google.gwt</groupId> <artifactId>gwt-user</artifactId> <version>${gwtVersion}</version> <scope>provided</scope> </dependency> - <dependency> <groupId>junit</groupId> <artifactId>junit</artifactId> <version>4.12</version> <scope>test</scope> </dependency> - <dependency> <groupId>javax.validation</groupId> <artifactId>validation-api</artifactId> <version>1.1.0.Final</version> <scope>test</scope> </dependency> - <dependency> <groupId>javax.validation</groupId> <artifactId>validation-api</artifactId> <version>1.1.0.Final</version> <classifier>sources</classifier> <scope>test</scope> </dependency> </dependencies> - <build> <finalName>${war.name}</finalName> - <!-- Generate compiled stuff in the folder used for developing mode --> <outputDirectory>${webappDirectory}/WEB-INF/classes</outputDirectory> - <resources> - <resource> <directory>src/main/java</directory> - <includes> <include>**/*.*</include> </includes> </resource> - <resource> <directory>src/main/resources</directory> - <includes> <include>**/*.*</include> </includes> </resource> </resources> - <plugins> - <!-- GWT Maven Plugin --> - <plugin> <groupId>org.codehaus.mojo</groupId> <artifactId>gwt-maven-plugin</artifactId> <version>2.7.0</version> - <executions> - <execution> - <goals> <goal>compile</goal> <goal>test</goal> <goal>i18n</goal> <goal>generateAsync</goal> </goals> </execution> </executions> - <!-- Plugin configuration. There are many available options, see gwt-maven-plugin documentation at codehaus.org --> - <configuration> <runTarget>SimpleExample.html</runTarget> <hostedWebapp>${webappDirectory}</hostedWebapp> <i18nMessagesBundle>by.gwt.test.client.Messages</i18nMessagesBundle> </configuration> </plugin> - <!-- Copy static web files before executing gwt:run --> - <plugin> <groupId>org.apache.maven.plugins</groupId> <artifactId>maven-war-plugin</artifactId> <version>2.6</version> - <executions> - <execution> <phase>compile</phase> - <goals> <goal>exploded</goal> </goals> </execution> </executions> - <configuration> <webappDirectory>${webappDirectory}</webappDirectory> </configuration> </plugin> - <plugin> <groupId>org.apache.maven.plugins</groupId> <artifactId>maven-compiler-plugin</artifactId> <version>3.3</version> - <configuration> <source>1.5</source> <target>1.5</target> </configuration> </plugin> </plugins> </build> </project> Таже самая ошибка при попытке создать проект GWTP ... |
| 14.04.2015, 21:26:31 |
start [/forum/topic.php?fid=59&gotonew=1&tid=2125538]: |
28ms |
80ms |
78ms |
| others: | 383ms |
| total: | 649ms |
