GWTP ClassFish
При попытке деплоя simple проекта GWTP Возникает ошибка автор[2015-04-15T22:23:07.918+0200] [glassfish 4.1] [SEVERE] [] [javax.enterprise.system.core] [tid: _ThreadID=45 _ThreadName=admin-listener(4)] [timeMillis: 1429129387918] [levelValue: 1000] [[ Exception while loading the app : CDI deployment failure:Exception List with 4 exceptions: Exception 0 : org.jboss.weld.exceptions.DeploymentException: WELD-001408: Unsatisfied dependencies for type Binder with qualifiers @Default at injection point [BackedAnnotatedParameter] Parameter 1 of [BackedAnnotatedConstructor] @Inject com.example.myproject.client.application.ApplicationView(Binder) at com.example.myproject.client.application.ApplicationView.<init>(ApplicationView.java:0) at org.jboss.weld.bootstrap.Validator.validateInjectionPointForDeploymentProblems(Validator.java:370) at org.jboss.weld.bootstrap.Validator.validateInjectionPoint(Validator.java:291) at org.jboss.weld.bootstrap.Validator.validateGeneralBean(Validator.java:134) at org.jboss.weld.bootstrap.Validator.validateRIBean(Validator.java:165) at org.jboss.weld.bootstrap.Validator.validateBean(Validator.java:529) at org.jboss.weld.bootstrap.Validator.validateBeans(Validator.java:515) at org.jboss.weld.bootstrap.Validator.validateDeployment(Validator.java:490) at org.jboss.weld.bootstrap.WeldStartup.validateBeans(WeldStartup.java:419) at org.jboss.weld.bootstrap.WeldBootstrap.validateBeans(WeldBootstrap.java:90) at org.glassfish.weld.WeldDeployer.event(WeldDeployer.java:225) at org.glassfish.kernel.event.EventsImpl.send(EventsImpl.java:131) at org.glassfish.internal.data.ApplicationInfo.load(ApplicationInfo.java:328) at com.sun.enterprise.v3.server.ApplicationLifecycle.deploy(ApplicationLifecycle.java:496) at com.sun.enterprise.v3.server.ApplicationLifecycle.deploy(ApplicationLifecycle.java:219) at org.glassfish.deployment.admin.DeployCommand.execute(DeployCommand.java:491) at com.sun.enterprise.v3.admin.CommandRunnerImpl$2$1.run(CommandRunnerImpl.java:539) at com.sun.enterprise.v3.admin.CommandRunnerImpl$2$1.run(CommandRunnerImpl.java:535) at java.security.AccessController.doPrivileged(Native Method) at javax.security.auth.Subject.doAs(Subject.java:360) at com.sun.enterprise.v3.admin.CommandRunnerImpl$2.execute(CommandRunnerImpl.java:534) at com.sun.enterprise.v3.admin.CommandRunnerImpl$3.run(CommandRunnerImpl.java:565) at com.sun.enterprise.v3.admin.CommandRunnerImpl$3.run(CommandRunnerImpl.java:557) at java.security.AccessController.doPrivileged(Native Method) at javax.security.auth.Subject.doAs(Subject.java:360) at com.sun.enterprise.v3.admin.CommandRunnerImpl.doCommand(CommandRunnerImpl.java:556) at com.sun.enterprise.v3.admin.CommandRunnerImpl.doCommand(CommandRunnerImpl.java:1464) at com.sun.enterprise.v3.admin.CommandRunnerImpl.access$1300(CommandRunnerImpl.java:109) at com.sun.enterprise.v3.admin.CommandRunnerImpl$ExecutionContext.execute(CommandRunnerImpl.java:1846) at com.sun.enterprise.v3.admin.CommandRunnerImpl$ExecutionContext.execute(CommandRunnerImpl.java:1722) at com.sun.enterprise.v3.admin.AdminAdapter.doCommand(AdminAdapter.java:534) at com.sun.enterprise.v3.admin.AdminAdapter.onMissingResource(AdminAdapter.java:224) at org.glassfish.grizzly.http.server.StaticHttpHandlerBase.service(StaticHttpHandlerBase.java:189) at com.sun.enterprise.v3.services.impl.ContainerMapper$HttpHandlerCallable.call(ContainerMapper.java:459) at com.sun.enterprise.v3.services.impl.ContainerMapper.service(ContainerMapper.java:167) at org.glassfish.grizzly.http.server.HttpHandler.runService(HttpHandler.java:201) at org.glassfish.grizzly.http.server.HttpHandler.doHandle(HttpHandler.java:175) at org.glassfish.grizzly.http.server.HttpServerFilter.handleRead(HttpServerFilter.java:235) at org.glassfish.grizzly.filterchain.ExecutorResolver$9.execute(ExecutorResolver.java:119) at org.glassfish.grizzly.filterchain.DefaultFilterChain.executeFilter(DefaultFilterChain.java:284) at org.glassfish.grizzly.filterchain.DefaultFilterChain.executeChainPart(DefaultFilterChain.java:201) at org.glassfish.grizzly.filterchain.DefaultFilterChain.execute(DefaultFilterChain.java:133) at org.glassfish.grizzly.filterchain.DefaultFilterChain.process(DefaultFilterChain.java:112) at org.glassfish.grizzly.ProcessorExecutor.execute(ProcessorExecutor.java:77) at org.glassfish.grizzly.nio.transport.TCPNIOTransport.fireIOEvent(TCPNIOTransport.java:561) at org.glassfish.grizzly.strategies.AbstractIOStrategy.fireIOEvent(AbstractIOStrategy.java:112) at org.glassfish.grizzly.strategies.WorkerThreadIOStrategy.run0(WorkerThreadIOStrategy.java:117) at org.glassfish.grizzly.strategies.WorkerThreadIOStrategy.access$100(WorkerThreadIOStrategy.java:56) at org.glassfish.grizzly.strategies.WorkerThreadIOStrategy$WorkerThreadRunnable.run(WorkerThreadIOStrategy.java:137) at org.glassfish.grizzly.threadpool.AbstractThreadPool$Worker.doWork(AbstractThreadPool.java:565) at org.glassfish.grizzly.threadpool.AbstractThreadPool$Worker.run(AbstractThreadPool.java:545) at java.lang.Thread.run(Thread.java:745) итд beans.xml я добавил автор<?xml version="1.0" encoding="UTF-8"?> <beans xmlns=" http://xmlns.jcp.org/xml/ns/javaee" xmlns:xsi=" http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation=" http://xmlns.jcp.org/xml/ns/javaee http://xmlns.jcp.org/xml/ns/javaee/beans_1_1.xsd" bean-discovery-mode="all"> </beans> При bean-discovery-mode="none" деплоится без ошибок, но ничего не отображается С чем это может быть связано? ... |
| 15.04.2015, 23:25:30 |
GWTP ClassFish
Или такое авторorg.jboss.weld.exceptions.DeploymentException: Exception List with 6 exceptions: Exception 0 : org.jboss.weld.exceptions.DeploymentException: WELD-001408: Unsatisfied dependencies for type Injector with qualifiers @Default at injection point [BackedAnnotatedParameter] Parameter 1 of [BackedAnnotatedConstructor] @Inject com.gwtplatform.dispatch.rpc.server.guice.actionhandlervalidator.LazyActionHandlerValidatorRegistryImpl(Injector) at com.gwtplatform.dispatch.rpc.server.guice.actionhandlervalidator.LazyActionHandlerValidatorRegistryImpl.<init>(LazyActionHandlerValidatorRegistryImpl.java:0) at org.jboss.weld.bootstrap.Validator.validateInjectionPointForDeploymentProblems(Validator.java:370) at org.jboss.weld.bootstrap.Validator.validateInjectionPoint(Validator.java:291) at org.jboss.weld.bootstrap.Validator.validateGeneralBean(Validator.java:134) at org.jboss.weld.bootstrap.Validator.validateRIBean(Validator.java:165) at org.jboss.weld.bootstrap.Validator.validateBean(Validator.java:529) at org.jboss.weld.bootstrap.Validator.validateBeans(Validator.java:515) at org.jboss.weld.bootstrap.Validator.validateDeployment(Validator.java:490) at org.jboss.weld.bootstrap.WeldStartup.validateBeans(WeldStartup.java:419) at org.jboss.weld.bootstrap.WeldBootstrap.validateBeans(WeldBootstrap.java:90) at org.glassfish.weld.WeldDeployer.event(WeldDeployer.java:225) at org.glassfish.kernel.event.EventsImpl.send(EventsImpl.java:131) at org.glassfish.internal.data.ApplicationInfo.load(ApplicationInfo.java:328) at com.sun.enterprise.v3.server.ApplicationLifecycle.deploy(ApplicationLifecycle.java:496) at com.sun.enterprise.v3.server.ApplicationLifecycle.deploy(ApplicationLifecycle.java:219) at org.glassfish.deployment.admin.DeployCommand.execute(DeployCommand.java:491) at com.sun.enterprise.v3.admin.CommandRunnerImpl$2$1.run(CommandRunnerImpl.java:539) at com.sun.enterprise.v3.admin.CommandRunnerImpl$2$1.run(CommandRunnerImpl.java:535) at java.security.AccessController.doPrivileged(Native Method) at javax.security.auth.Subject.doAs(Subject.java:360) at com.sun.enterprise.v3.admin.CommandRunnerImpl$2.execute(CommandRunnerImpl.java:534) at com.sun.enterprise.v3.admin.CommandRunnerImpl$3.run(CommandRunnerImpl.java:565) at com.sun.enterprise.v3.admin.CommandRunnerImpl$3.run(CommandRunnerImpl.java:557) at java.security.AccessController.doPrivileged(Native Method) at javax.security.auth.Subject.doAs(Subject.java:360) at com.sun.enterprise.v3.admin.CommandRunnerImpl.doCommand(CommandRunnerImpl.java:556) at com.sun.enterprise.v3.admin.CommandRunnerImpl.doCommand(CommandRunnerImpl.java:1464) at com.sun.enterprise.v3.admin.CommandRunnerImpl.access$1300(CommandRunnerImpl.java:109) at com.sun.enterprise.v3.admin.CommandRunnerImpl$ExecutionContext.execute(CommandRunnerImpl.java:1846) at com.sun.enterprise.v3.admin.CommandRunnerImpl$ExecutionContext.execute(CommandRunnerImpl.java:1722) at com.sun.enterprise.v3.admin.AdminAdapter.doCommand(AdminAdapter.java:534) at com.sun.enterprise.v3.admin.AdminAdapter.onMissingResource(AdminAdapter.java:224) at org.glassfish.grizzly.http.server.StaticHttpHandlerBase.service(StaticHttpHandlerBase.java:189) at com.sun.enterprise.v3.services.impl.ContainerMapper$HttpHandlerCallable.call(ContainerMapper.java:459) at com.sun.enterprise.v3.services.impl.ContainerMapper.service(ContainerMapper.java:167) at org.glassfish.grizzly.http.server.HttpHandler.runService(HttpHandler.java:201) at org.glassfish.grizzly.http.server.HttpHandler.doHandle(HttpHandler.java:175) at org.glassfish.grizzly.http.server.HttpServerFilter.handleRead(HttpServerFilter.java:235) at org.glassfish.grizzly.filterchain.ExecutorResolver$9.execute(ExecutorResolver.java:119) at org.glassfish.grizzly.filterchain.DefaultFilterChain.executeFilter(DefaultFilterChain.java:284) at org.glassfish.grizzly.filterchain.DefaultFilterChain.executeChainPart(DefaultFilterChain.java:201) at org.glassfish.grizzly.filterchain.DefaultFilterChain.execute(DefaultFilterChain.java:133) at org.glassfish.grizzly.filterchain.DefaultFilterChain.process(DefaultFilterChain.java:112) at org.glassfish.grizzly.ProcessorExecutor.execute(ProcessorExecutor.java:77) at org.glassfish.grizzly.nio.transport.TCPNIOTransport.fireIOEvent(TCPNIOTransport.java:561) at org.glassfish.grizzly.strategies.AbstractIOStrategy.fireIOEvent(AbstractIOStrategy.java:112) at org.glassfish.grizzly.strategies.WorkerThreadIOStrategy.run0(WorkerThreadIOStrategy.java:117) at org.glassfish.grizzly.strategies.WorkerThreadIOStrategy.access$100(WorkerThreadIOStrategy.java:56) at org.glassfish.grizzly.strategies.WorkerThreadIOStrategy$WorkerThreadRunnable.run(WorkerThreadIOStrategy.java:137) at org.glassfish.grizzly.threadpool.AbstractThreadPool$Worker.doWork(AbstractThreadPool.java:565) at org.glassfish.grizzly.threadpool.AbstractThreadPool$Worker.run(AbstractThreadPool.java:545) at java.lang.Thread.run(Thread.java:745) ... |
| 15.04.2015, 23:31:35 |
GWTP ClassFish
-=Koba=-, берешь гугль, копипастишь в него ошибку, изучаешь ссылки. особенно изучаешь ссылки на сайт stackoverflow.com. стараешься вникнуть и понять, а чем пишут, а не просто скопипастить из СО в код. ... |
| 16.04.2015, 09:41:33 |
GWTP ClassFish
Юрий321-=Koba=-, берешь гугль, копипастишь в него ошибку, изучаешь ссылки. особенно изучаешь ссылки на сайт stackoverflow.com. стараешься вникнуть и понять, а чем пишут, а не просто скопипастить из СО в код. Прежде чем сюда писать, я наверное так и сделал. ... |
| 16.04.2015, 11:23:16 |
start [/forum/topic.php?fid=59&gotonew=1&tid=2125531]: |
55ms |
90ms |
| others: | 375ms |
| total: | 616ms |
