Передача objecta
Ребята всем привет. Подскажите пожалуйста как с java передать Object в javascript. вот мой код подскажите что не правильно. java Код: java 1. 2. 3. javascript Код: javascript 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. 15. 16. 17. 18. 19. 20. 21. 22. 23. 24. 25. 26. 27. 28. 29. ... |
| 11.09.2015, 15:10:34 |
Передача objecta
Выдает ошибку авторException in thread "JavaFX Application Thread" netscape.javascript.JSException: SyntaxError: Expected token ']' at com.sun.webkit.dom.JSObject.fwkMakeException(JSObject.java:128) at com.sun.webkit.WebPage.twkExecuteScript(Native Method) at com.sun.webkit.WebPage.executeScript(WebPage.java:1427) at javafx.scene.web.WebEngine.executeScript(WebEngine.java:948) at price.FXMLDocumentController.MapScript(FXMLDocumentController.java:290) at price.FXMLDocumentController.access$500(FXMLDocumentController.java:23) at price.FXMLDocumentController$3.handle(FXMLDocumentController.java:172) at com.sun.javafx.event.CompositeEventHandler.dispatchBubblingEvent(CompositeEventHandler.java:86) at com.sun.javafx.event.EventHandlerManager.dispatchBubblingEvent(EventHandlerManager.java:238) at com.sun.javafx.event.EventHandlerManager.dispatchBubblingEvent(EventHandlerManager.java:191) at com.sun.javafx.event.CompositeEventDispatcher.dispatchBubblingEvent(CompositeEventDispatcher.java:59) at com.sun.javafx.event.BasicEventDispatcher.dispatchEvent(BasicEventDispatcher.java:58) at com.sun.javafx.event.EventDispatchChainImpl.dispatchEvent(EventDispatchChainImpl.java:114) at com.sun.javafx.event.BasicEventDispatcher.dispatchEvent(BasicEventDispatcher.java:56) at com.sun.javafx.event.EventDispatchChainImpl.dispatchEvent(EventDispatchChainImpl.java:114) at com.sun.javafx.event.BasicEventDispatcher.dispatchEvent(BasicEventDispatcher.java:56) at com.sun.javafx.event.EventDispatchChainImpl.dispatchEvent(EventDispatchChainImpl.java:114) at com.sun.javafx.event.EventUtil.fireEventImpl(EventUtil.java:74) at com.sun.javafx.event.EventUtil.fireEvent(EventUtil.java:54) at javafx.event.Event.fireEvent(Event.java:198) at javafx.scene.Scene$MouseHandler.process(Scene.java:3758) at javafx.scene.Scene$MouseHandler.access$1500(Scene.java:3486) at javafx.scene.Scene.impl_processMouseEvent(Scene.java:1762) at javafx.scene.Scene$ScenePeerListener.mouseEvent(Scene.java:2495) at com.sun.javafx.tk.quantum.GlassViewEventHandler$MouseEventNotification.run(GlassViewEventHandler.java:350) at com.sun.javafx.tk.quantum.GlassViewEventHandler$MouseEventNotification.run(GlassViewEventHandler.java:275) at java.security.AccessController.doPrivileged(Native Method) at com.sun.javafx.tk.quantum.GlassViewEventHandler.lambda$handleMouseEvent$350(GlassViewEventHandler.java:385) at com.sun.javafx.tk.quantum.GlassViewEventHandler$$Lambda$209/27770896.get(Unknown Source) at com.sun.javafx.tk.quantum.QuantumToolkit.runWithoutRenderLock(QuantumToolkit.java:404) at com.sun.javafx.tk.quantum.GlassViewEventHandler.handleMouseEvent(GlassViewEventHandler.java:384) at com.sun.glass.ui.View.handleMouseEvent(View.java:555) at com.sun.glass.ui.View.notifyMouse(View.java:927) at com.sun.glass.ui.win.WinApplication._runLoop(Native Method) at com.sun.glass.ui.win.WinApplication.lambda$null$145(WinApplication.java:101) at com.sun.glass.ui.win.WinApplication$$Lambda$36/17230114.run(Unknown Source) at java.lang.Thread.run(Thread.java:745) Подскажите где искать причину Заранее спасибо. ... |
| 11.09.2015, 15:11:50 |
Передача objecta
mixon21, правила хорошего тона говорят, давать ссылку на ранешнее обсуждение ... |
| 11.09.2015, 15:21:20 |
Передача objecta
mixon21, а так работает? Код: javascript 1. 2. ... |
| 11.09.2015, 15:32:54 |
Передача objecta
mixon21, вот это Код: java 1. 2. 3. будет примерно так webEngine.executeScript("init(1,1,[Ljava.lang.Object;@834893489,[Ljava.lang.Object;@89348934892лл); ... |
| 11.09.2015, 15:57:56 |
Передача objecta
maytonmixon21, а так работает? Код: javascript 1. 2. Так тоже не работает ... |
| 11.09.2015, 17:29:59 |
Передача objecta
0FDmixon21, вот это Код: java 1. 2. 3. будет примерно так webEngine.executeScript("init(1,1,[Ljava.lang.Object;@834893489,[Ljava.lang.Object;@89348934892лл); А как правильно? ... |
| 11.09.2015, 17:30:27 |
Передача objecta
0FDmixon21, вот это Код: java 1. 2. 3. будет примерно так webEngine.executeScript("init(1,1,[Ljava.lang.Object;@834893489,[Ljava.lang.Object;@89348934892лл); А как правильно передать обект? ... |
| 11.09.2015, 17:31:08 |
Передача objecta
mixon21 А как правильно передать обект? Строкой можно. Через запятую передать 1,2,3,4,5 содержимое массива. А там - соответсвтенно сделать обратно массив из строки. ... |
| 11.09.2015, 17:35:02 |
Передача objecta
maytonmixon21А как правильно передать обект? Строкой можно. Через запятую передать 1,2,3,4,5 содержимое массива. А там - соответсвтенно сделать обратно массив из строки. Примерчик можно? ... |
| 11.09.2015, 17:41:44 |
Передача objecta
Посмотри как тут http://stackoverflow.com/questions/409784/whats-the-simplest-way-to-print-a-java-array ... |
| 11.09.2015, 17:51:36 |
Передача objecta
mixon21, или https://docs.oracle.com/javase/8/javafx/api/javafx/scene/web/WebEngine.html -> Calling back to Java from JavaScript и например, через app передавать массивы. app.setLabelX(...); executeScript(...) ... |
| 11.09.2015, 18:00:07 |
Передача objecta
maytonПосмотри как тут http://stackoverflow.com/questions/409784/whats-the-simplest-way-to-print-a-java-array Пробую так Код: java 1. 2. 3. 4. 5. Неполучается. Другие примеры тоже не подходят ... |
| 11.09.2015, 18:06:12 |
Передача objecta
Но выходит другая ошибка. авторException in thread "JavaFX Application Thread" netscape.javascript.JSException: ReferenceError: Can't find variable: init at com.sun.webkit.dom.JSObject.fwkMakeException(JSObject.java:128) at com.sun.webkit.WebPage.twkExecuteScript(Native Method) at com.sun.webkit.WebPage.executeScript(WebPage.java:1427) at javafx.scene.web.WebEngine.executeScript(WebEngine.java:948) at price.FXMLDocumentController.MapScript(FXMLDocumentController.java:291) at price.FXMLDocumentController.access$500(FXMLDocumentController.java:23) at price.FXMLDocumentController$3.handle(FXMLDocumentController.java:172) at com.sun.javafx.event.CompositeEventHandler.dispatchBubblingEvent(CompositeEventHandler.java:86) at com.sun.javafx.event.EventHandlerManager.dispatchBubblingEvent(EventHandlerManager.java:238) at com.sun.javafx.event.EventHandlerManager.dispatchBubblingEvent(EventHandlerManager.java:191) at com.sun.javafx.event.CompositeEventDispatcher.dispatchBubblingEvent(CompositeEventDispatcher.java:59) at com.sun.javafx.event.BasicEventDispatcher.dispatchEvent(BasicEventDispatcher.java:58) at com.sun.javafx.event.EventDispatchChainImpl.dispatchEvent(EventDispatchChainImpl.java:114) at com.sun.javafx.event.BasicEventDispatcher.dispatchEvent(BasicEventDispatcher.java:56) at com.sun.javafx.event.EventDispatchChainImpl.dispatchEvent(EventDispatchChainImpl.java:114) at com.sun.javafx.event.BasicEventDispatcher.dispatchEvent(BasicEventDispatcher.java:56) at com.sun.javafx.event.EventDispatchChainImpl.dispatchEvent(EventDispatchChainImpl.java:114) at com.sun.javafx.event.EventUtil.fireEventImpl(EventUtil.java:74) at com.sun.javafx.event.EventUtil.fireEvent(EventUtil.java:54) at javafx.event.Event.fireEvent(Event.java:198) at javafx.scene.Scene$MouseHandler.process(Scene.java:3758) at javafx.scene.Scene$MouseHandler.access$1500(Scene.java:3486) at javafx.scene.Scene.impl_processMouseEvent(Scene.java:1762) at javafx.scene.Scene$ScenePeerListener.mouseEvent(Scene.java:2495) at com.sun.javafx.tk.quantum.GlassViewEventHandler$MouseEventNotification.run(GlassViewEventHandler.java:350) at com.sun.javafx.tk.quantum.GlassViewEventHandler$MouseEventNotification.run(GlassViewEventHandler.java:275) at java.security.AccessController.doPrivileged(Native Method) at com.sun.javafx.tk.quantum.GlassViewEventHandler.lambda$handleMouseEvent$350(GlassViewEventHandler.java:385) at com.sun.javafx.tk.quantum.GlassViewEventHandler$$Lambda$219/27770896.get(Unknown Source) at com.sun.javafx.tk.quantum.QuantumToolkit.runWithoutRenderLock(QuantumToolkit.java:404) at com.sun.javafx.tk.quantum.GlassViewEventHandler.handleMouseEvent(GlassViewEventHandler.java:384) at com.sun.glass.ui.View.handleMouseEvent(View.java:555) at com.sun.glass.ui.View.notifyMouse(View.java:927) at com.sun.glass.ui.win.WinApplication._runLoop(Native Method) at com.sun.glass.ui.win.WinApplication.lambda$null$145(WinApplication.java:101) at com.sun.glass.ui.win.WinApplication$$Lambda$36/17230114.run(Unknown Source) at java.lang.Thread.run(Thread.java:745) ... |
| 11.09.2015, 18:07:59 |
Передача objecta
mixon21Неполучается. Другие примеры тоже не подходят Чо такое "неполучается"? Лог давай. Или в дебаге покажи что есть. Скриншот там... ... |
| 11.09.2015, 18:10:03 |
Передача objecta
maytonmixon21Неполучается. Другие примеры тоже не подходят Чо такое "неполучается"? Лог давай. Или в дебаге покажи что есть. Скриншот там... В дебаге все принимает переменные labelX и labelY но почему-то не передают в функцию init(javascript). если ставлю обычные цифры без массива все нормально передает и все нормально работает. Как только меняю на объект перестает работать. ... |
| 11.09.2015, 18:21:41 |
Передача objecta
mixon21, И с javascript что-то не то: Код: java 1. 2. 3. 4. 5. 6. 7. ... |
| 11.09.2015, 18:27:25 |
Передача objecta
0FDmixon21, И с javascript что-то не то: Код: java 1. 2. 3. 4. 5. 6. 7. так функция init(javascript) не получает параметры. ... |
| 11.09.2015, 18:41:04 |
Передача objecta
Ребята помогите кто знает как передать объект с java в javascript сильно надо буду очень благодарен. ... |
| 11.09.2015, 22:56:38 |
Передача objecta
Все бухают. Терпи до понедельника. ... |
| 11.09.2015, 23:20:04 |
Передача objecta
maytonВсе бухают. Терпи до понедельника. Во вторник здавать надо а еще нада сделать email рассылку. скоторой первый раз встречаюсь. и записку к диплому. ... |
| 11.09.2015, 23:28:39 |
Передача objecta
mayton, так и ты знаешь ? ... |
| 11.09.2015, 23:29:49 |
start [/forum/topic.php?fid=59&gotonew=1&tid=2124949]: |
38ms |
91ms |
| others: | 338ms |
| total: | 537ms |
