Настройка кэша второго уровня. Hibernate
Пытаюсь настроить кэш второго уровня хибернейта. hibernate.properties Код: java 1. 2. Тестируемая сущность Код: java 1. 2. 3. EhCache.xml Код: xml 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. 15. Лог при старте проекта11:02:23,778 [TRACE][host-startStop-1][nate.internal.SessionFactoryImpl] - Building shared cache region for entity data [SampleEntity] 11:02:23,805 [DEBUG][host-startStop-1][ net.sf.ehcache.Cache] - Initialised cache: SampleEntity 11:02:23,805 [DEBUG][host-startStop-1][cache.config.ConfigurationHelper] - CacheDecoratorFactory not configured for defaultCache. Skipping for 'SampleEntity'. 11:02:23,805 [DEBUG][host-startStop-1][che.AbstractEhcacheRegionFactory] - started EHCache region: SampleEntity Но при каждом вызове sampleRepository.findAll() получаю в лог Лог11:09:32,508 [DEBUG][ate.engine.internal.TwoPhaseLoad] - Resolving associations for [SampleEntity#0] 11:09:32,508 [DEBUG][ate.engine.internal.TwoPhaseLoad] - Adding entity to second-level cache: [SampleEntity#0] 11:09:32,541 [DEBUG][ate.engine.internal.TwoPhaseLoad] - Done materializing entity [SampleEntity#0] 11:09:32,542 [DEBUG][ate.engine.internal.TwoPhaseLoad] - Resolving associations for [SampleEntity#1] 11:09:32,542 [DEBUG][ate.engine.internal.TwoPhaseLoad] - Adding entity to second-level cache: [SampleEntity#1] 11:09:32,543 [DEBUG][ate.engine.internal.TwoPhaseLoad] - Done materializing entity [SampleEntity#1] 11:09:32,544 [DEBUG][ate.engine.internal.TwoPhaseLoad] - Resolving associations for [SampleEntity#2] 11:09:32,544 [DEBUG][ate.engine.internal.TwoPhaseLoad] - Adding entity to second-level cache: [SampleEntity#2] 11:09:32,545 [DEBUG][ate.engine.internal.TwoPhaseLoad] - Done materializing entity [SampleEntity#2] 11:09:32,545 [DEBUG][ate.engine.internal.TwoPhaseLoad] - Resolving associations for [SampleEntity#3] 11:09:32,546 [DEBUG][ate.engine.internal.TwoPhaseLoad] - Adding entity to second-level cache: [SampleEntity#3] 11:09:32,546 [DEBUG][ate.engine.internal.TwoPhaseLoad] - Done materializing entity [SampleEntity#3] Правильно ли я понимаю, что при каждом вызове данные по новой записываются в кэш, и по факту кэширование у меня не работает? ... |
| 15.12.2015, 12:19:18 |
JonnySKSи по факту кэширование у меня не работает? по факту смотри select в БД ... |
| 15.12.2015, 12:29:13 |
#0-#3 это id сущности. 4 id - 4 разных сущности. Что должно кэшироваться-то? ... |
| 15.12.2015, 12:30:59 |
Blazkowicz#0-#3 это id сущности. 4 id - 4 разных сущности. Что должно кэшироваться-то? Да, это 3 объекта выбираются. Но При следующем запросе при выборке findAll() отображаются те же строки с Adding entity to second-level cache: [SampleEntity#...] Petro123, Из лога вижу что из кэша достается только HQL запроса Located HQL query plan in cache (select generatedAlias0 from SampleEntity generatedAlias0) Судя по логу селект снова проходит, из резалт сета получаются данные и записываются в кэш по новому. ... |
| 15.12.2015, 12:54:33 |
JonnySKS, Код: java 1. Смысл в том что у хибера по разному кешируются, загрузка сущности по id, загрузка результата по запросу и, если не ошибаюсь, загрузка коллекции по ассоциации. Repository.findAll для JPA работает через Query. Поэтому я предлагаю попробовать эту опцию. ... |
| 15.12.2015, 13:04:45 |
Blazkowicz, Спасибо, сейчас прочитаю о настройке кэширования запросов, проверю что выйдет в итоге. ... |
| 15.12.2015, 13:24:11 |
BlazkowiczRepository.findAll для JPA работает через Query. Поэтому я предлагаю попробовать эту опцию. Да, совет мне помог, включил кеширование запросов и добавил в интерфейс репозитория аннотацию Код: java 1. 2. 3. Из прочитанного понял что кэширование запросов менее гибкое, нежели кэширование второго уровня, хоть в моей ситуации с неизменными данными особой разницы, полагаю, не будет. Еще вопрос, конфигурацию регионов кэша он берет из того же EhCache? ... |
| 15.12.2015, 16:52:14 |
start [/forum/topic.php?fid=59&gotonew=1&tid=2124552]: |
29ms |
49ms |
100ms |
| others: | 408ms |
| total: | 658ms |
