Почему @Transactional надо навешивать на конкретные классы, а не интерфейсы
Из доки(второго спринг) авторThe Spring team's recommendation is that you only annotate concrete classes with the @Transactional annotation, as opposed to annotating interfaces. You certainly can place the @Transactional annotation on an interface (or an interface method), but this will only work as you would expect it to if you are using interface-based proxies. The fact that annotations are not inherited means that if you are using class-based proxies then the transaction settings will not be recognised by the class-based proxying infrastructure and the object will not be wrapped in a transactional proxy (which would be decidedly bad). So please do take the Spring team's advice and only annotate concrete classes (and the methods of concrete classes) with the @Transactional annotation. Note: Since this mechanism is based on proxies, only 'external' method calls coming in through the proxy will be intercepted. This means that 'self-invocation', i.e. a method within the target object calling some other method of the target object, won't lead to an actual transaction at runtime even if the invoked method is marked with @Transactional! Я не понял фразы The fact that annotations are not inherited means that if you are using class-based proxies then the transaction settings will not be recognised by the class-based proxying infrastructure and the object will not be wrapped in a transactional proxy (which would be decidedly bad) Аннотации не наследуются; это значит, что если ты используешь class-based прокси, то @Transactional не будет прочитан. Не осознал причинно следственной связи. Помогите осознать ... |
| 14.04.2016, 22:43:28 |
1) Ты бы ещепервый спринг изучал :) 2) Попробуй написать свой процессор аннотаций, где навесь аннотацию на интерфейс, и попробуй получить ее в наследнике ... |
| 14.04.2016, 23:07:56 |
забыл ник1) Ты бы ещепервый спринг изучал :) Да просто заинтересовался вопросом а нагуглил только для второго. не думаю, что кардинально что-то поменялось забыл ник2) Попробуй написать свой процессор аннотаций, где навесь аннотацию на интерфейс, и попробуй получить ее в наследнике в имплементаторе всмысле? ... |
| 14.04.2016, 23:46:32 |
Код: java 1. 2. 3. 4. 5. 6. 7. 8. 9. ... |
| 15.04.2016, 00:04:26 |
забыл ник Код: java 1. 2. 3. 4. 5. 6. 7. 8. 9. Ну у класса B и нет, это я понимаю. ... |
| 15.04.2016, 00:10:53 |
забыл ник, всё равно не понятно ... |
| 15.04.2016, 00:16:29 |
забыл ник Код: java 1. 2. 3. 4. 5. 6. 7. 8. 9. Взять все интерфейсы и прочитать? С другой стороны тот факт, что метод требует транзакцию- детали реализации, а не контракта! ... |
| 15.04.2016, 06:04:38 |
Alexey Tomin С другой стороны тот факт, что метод требует транзакцию- детали реализации, а не контракта! по-моему в доке по другому написано. ... |
| 15.04.2016, 09:48:18 |
Я заметил что на новичков очень сильное впечатление производят Java-annotations. Столкнувшись с этой технологией 1 раз они верят в нее как в черную магию и пытаются тулить эти заклинания в те проекты, где Spring и любой другой фреймворк даже рядом не был. ... |
| 15.04.2016, 11:23:15 |
это в каком это спринге аннторировались классы транзакшнл? вродь методы ща аннотируются только? если в контексте транзакшнл речь идет разумеется. ... |
| 15.04.2016, 18:15:25 |
maytonЯ заметил что на новичков очень сильное впечатление производят Java-annotations. Столкнувшись с этой технологией 1 раз они верят в нее как в черную магию и пытаются тулить эти заклинания в те проекты, где Spring и любой другой фреймворк даже рядом не был. Заметил, что умничать все горазды, а ответить никто не может. Вопрос не ясен разве? ... |
| 15.04.2016, 20:05:49 |
lor2это в каком это спринге аннторировались классы транзакшнл? вродь методы ща аннотируются только? если в контексте транзакшнл речь идет разумеется. в 2-ом, 3-ем, 4-ом на данный момент) в первом хз ... |
| 15.04.2016, 20:07:00 |
lor2, http://docs.spring.io/spring/docs/current/javadoc-api/org/springframework/transaction/annotation/Transactional.html Код: java 1. ... |
| 15.04.2016, 20:07:46 |
и в чем скрытый смысл аннотировать транзакцией КЛАСС? ну это так вопрос, в целях самообразования. ... |
| 16.04.2016, 09:53:50 |
lor2и в чем скрытый смысл аннотировать транзакцией КЛАСС? ну это так вопрос, в целях самообразования. Это всего лишь shortcut того, что все методы будут транзакционными ... |
| 16.04.2016, 11:10:29 |
забыл ник, а как @Validated на интерфейсе работает? ... |
| 16.04.2016, 12:54:41 |
up ... |
| 17.04.2016, 00:16:58 |
Есть базовый вопрос : по написанию метода equals Josh Bloch on Design https://www.artima.com/intv/bloch17.html есть instanceof versus getClass in equals Methods есть спринг в котором есть понятие прокси ... |
| 18.04.2016, 08:06:55 |
start [/forum/topic.php?fid=59&gotonew=1&tid=2124153]: |
28ms |
56ms |
90ms |
| others: | 442ms |
| total: | 680ms |
