WildFly module
#39359960
Ссылка:
И еще ошибка идет
1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. 15. 16. 17. 18. 19. 20. 21. 22. 23. 24. 25. 26. 27. 28. 29. 30. 31. 32. 33. 34. 35. 36. 37. 38. 39. 40. 41. 42. 43. 44. 45. 46. 47. 48. 49. 50. 51. 52. 53. 54. 55. 56. 57. 58. 59. 60. 61. 62. 63. 64. 65. 66. 67. 68. 69. 70. 71. 72. 73. 74. 75. 76. 77. 78. 79.
00:26:27,299 ERROR [stderr] (default task-16) javax.el.ELException: Function 'p:component' not found
00:26:27,299 ERROR [stderr] (default task-16) at com.sun.el.lang.ExpressionBuilder.visit(ExpressionBuilder.java:275)
00:26:27,299 ERROR [stderr] (default task-16) at com.sun.el.parser.SimpleNode.accept(SimpleNode.java:172)
00:26:27,299 ERROR [stderr] (default task-16) at com.sun.el.lang.ExpressionBuilder.prepare(ExpressionBuilder.java:227)
00:26:27,299 ERROR [stderr] (default task-16) at com.sun.el.lang.ExpressionBuilder.build(ExpressionBuilder.java:238)
00:26:27,299 ERROR [stderr] (default task-16) at com.sun.el.lang.ExpressionBuilder.createValueExpression(ExpressionBuilder.java:295)
00:26:27,299 ERROR [stderr] (default task-16) at com.sun.el.ExpressionFactoryImpl.createValueExpression(ExpressionFactoryImpl.java:112)
00:26:27,299 ERROR [stderr] (default task-16) at com.sun.faces.facelets.el.ELText$ELTextVariable.apply(ELText.java:211)
00:26:27,299 ERROR [stderr] (default task-16) at com.sun.faces.facelets.el.ELText$ELTextComposite.apply(ELText.java:188)
00:26:27,299 ERROR [stderr] (default task-16) at com.sun.faces.facelets.compiler.AttributeInstruction.apply(AttributeInstruction.java:101)
00:26:27,299 ERROR [stderr] (default task-16) at com.sun.faces.facelets.compiler.UIInstructionHandler.apply(UIInstructionHandler.java:142)
00:26:27,299 ERROR [stderr] (default task-16) at javax.faces.view.facelets.CompositeFaceletHandler.apply(CompositeFaceletHandler.java:95)
00:26:27,300 ERROR [stderr] (default task-16) at javax.faces.view.facelets.DelegatingMetaTagHandler.applyNextHandler(DelegatingMetaTagHandler.java:137)
00:26:27,300 ERROR [stderr] (default task-16) at com.sun.faces.facelets.tag.jsf.ComponentTagHandlerDelegateImpl.apply(ComponentTagHandlerDelegateImpl.java:202)
00:26:27,300 ERROR [stderr] (default task-16) at javax.faces.view.facelets.DelegatingMetaTagHandler.apply(DelegatingMetaTagHandler.java:120)
00:26:27,300 ERROR [stderr] (default task-16) at javax.faces.view.facelets.CompositeFaceletHandler.apply(CompositeFaceletHandler.java:95)
00:26:27,300 ERROR [stderr] (default task-16) at com.sun.faces.facelets.compiler.NamespaceHandler.apply(NamespaceHandler.java:93)
00:26:27,300 ERROR [stderr] (default task-16) at com.sun.faces.facelets.compiler.EncodingHandler.apply(EncodingHandler.java:87)
00:26:27,300 ERROR [stderr] (default task-16) at com.sun.faces.facelets.impl.DefaultFacelet.include(DefaultFacelet.java:312)
00:26:27,300 ERROR [stderr] (default task-16) at com.sun.faces.facelets.impl.DefaultFacelet.include(DefaultFacelet.java:371)
00:26:27,300 ERROR [stderr] (default task-16) at com.sun.faces.facelets.impl.DefaultFacelet.include(DefaultFacelet.java:350)
00:26:27,300 ERROR [stderr] (default task-16) at com.sun.faces.facelets.impl.DefaultFaceletContext.includeFacelet(DefaultFaceletContext.java:199)
00:26:27,300 ERROR [stderr] (default task-16) at com.sun.faces.facelets.tag.ui.CompositionHandler.apply(CompositionHandler.java:174)
00:26:27,300 ERROR [stderr] (default task-16) at com.sun.faces.facelets.impl.DefaultFacelet.apply(DefaultFacelet.java:161)
00:26:27,300 ERROR [stderr] (default task-16) at com.sun.faces.application.view.FaceletViewHandlingStrategy.buildView(FaceletViewHandlingStrategy.java:1006)
00:26:27,300 ERROR [stderr] (default task-16) at com.sun.faces.lifecycle.RenderResponsePhase.execute(RenderResponsePhase.java:99)
00:26:27,300 ERROR [stderr] (default task-16) at com.sun.faces.lifecycle.Phase.doPhase(Phase.java:101)
00:26:27,301 ERROR [stderr] (default task-16) at com.sun.faces.lifecycle.LifecycleImpl.render(LifecycleImpl.java:219)
00:26:27,301 ERROR [stderr] (default task-16) at javax.faces.webapp.FacesServlet.service(FacesServlet.java:659)
00:26:27,301 ERROR [stderr] (default task-16) at io.undertow.servlet.handlers.ServletHandler.handleRequest(ServletHandler.java:85)
00:26:27,301 ERROR [stderr] (default task-16) at io.undertow.servlet.handlers.FilterHandler$FilterChainImpl.doFilter(FilterHandler.java:129)
00:26:27,301 ERROR [stderr] (default task-16) at org.primefaces.webapp.filter.FileUploadFilter.doFilter(FileUploadFilter.java:100)
00:26:27,301 ERROR [stderr] (default task-16) at io.undertow.servlet.core.ManagedFilter.doFilter(ManagedFilter.java:61)
00:26:27,301 ERROR [stderr] (default task-16) at io.undertow.servlet.handlers.FilterHandler$FilterChainImpl.doFilter(FilterHandler.java:131)
00:26:27,301 ERROR [stderr] (default task-16) at com.github.zhanhb.filter.CharacterEncodingFilter.doFilter(CharacterEncodingFilter.java:55)
00:26:27,301 ERROR [stderr] (default task-16) at by.softclub.abank.admin.ui.faces.UrlFilter.doFilter(UrlFilter.java:118)
00:26:27,301 ERROR [stderr] (default task-16) at io.undertow.servlet.handlers.FilterHandler.handleRequest(FilterHandler.java:84)
00:26:27,301 ERROR [stderr] (default task-16) at io.undertow.servlet.handlers.security.ServletSecurityRoleHandler.handleRequest(ServletSecurityRoleHandler.java:62)
00:26:27,302 ERROR [stderr] (default task-16) at io.undertow.servlet.handlers.ServletDispatchingHandler.handleRequest(ServletDispatchingHandler.java:36)
00:26:27,302 ERROR [stderr] (default task-16) at org.wildfly.extension.undertow.security.SecurityContextAssociationHandler.handleRequest(SecurityContextAssociationHandler.java:78)
00:26:27,302 ERROR [stderr] (default task-16) at io.undertow.server.handlers.PredicateHandler.handleRequest(PredicateHandler.java:43)
00:26:27,302 ERROR [stderr] (default task-16) at io.undertow.servlet.handlers.security.SSLInformationAssociationHandler.handleRequest(SSLInformationAssociationHandler.java:131)
00:26:27,302 ERROR [stderr] (default task-16) at io.undertow.servlet.handlers.security.ServletAuthenticationCallHandler.handleRequest(ServletAuthenticationCallHandler.java:57)
00:26:27,302 ERROR [stderr] (default task-16) at io.undertow.security.handlers.AbstractConfidentialityHandler.handleRequest(AbstractConfidentialityHandler.java:46)
00:26:27,302 ERROR [stderr] (default task-16) at io.undertow.servlet.handlers.security.ServletConfidentialityConstraintHandler.handleRequest(ServletConfidentialityConstraintHandler.java:64)
00:26:27,302 ERROR [stderr] (default task-16) at io.undertow.security.handlers.AuthenticationMechanismsHandler.handleRequest(AuthenticationMechanismsHandler.java:60)
00:26:27,302 ERROR [stderr] (default task-16) at io.undertow.servlet.handlers.security.CachedAuthenticatedSessionHandler.handleRequest(CachedAuthenticatedSessionHandler.java:77)
00:26:27,302 ERROR [stderr] (default task-16) at io.undertow.security.handlers.NotificationReceiverHandler.handleRequest(NotificationReceiverHandler.java:50)
00:26:27,302 ERROR [stderr] (default task-16) at io.undertow.security.handlers.AbstractSecurityContextAssociationHandler.handleRequest(AbstractSecurityContextAssociationHandler.java:43)
00:26:27,302 ERROR [stderr] (default task-16) at org.wildfly.extension.undertow.security.jacc.JACCContextIdHandler.handleRequest(JACCContextIdHandler.java:61)
00:26:27,303 ERROR [stderr] (default task-16) at io.undertow.server.handlers.PredicateHandler.handleRequest(PredicateHandler.java:43)
00:26:27,303 ERROR [stderr] (default task-16) at io.undertow.servlet.handlers.ServletInitialHandler.handleFirstRequest(ServletInitialHandler.java:292)
00:26:27,303 ERROR [stderr] (default task-16) at io.undertow.servlet.handlers.ServletInitialHandler.access$100(ServletInitialHandler.java:81)
00:26:27,303 ERROR [stderr] (default task-16) at io.undertow.servlet.handlers.ServletInitialHandler$2.call(ServletInitialHandler.java:138)
00:26:27,303 ERROR [stderr] (default task-16) at io.undertow.servlet.handlers.ServletInitialHandler$2.call(ServletInitialHandler.java:135)
00:26:27,303 ERROR [stderr] (default task-16) at io.undertow.servlet.core.ServletRequestContextThreadSetupAction$1.call(ServletRequestContextThreadSetupAction.java:48)
00:26:27,303 ERROR [stderr] (default task-16) at io.undertow.servlet.core.ContextClassLoaderSetupAction$1.call(ContextClassLoaderSetupAction.java:43)
00:26:27,303 ERROR [stderr] (default task-16) at io.undertow.servlet.api.LegacyThreadSetupActionWrapper$1.call(LegacyThreadSetupActionWrapper.java:44)
00:26:27,304 ERROR [stderr] (default task-16) at io.undertow.servlet.handlers.ServletInitialHandler.dispatchRequest(ServletInitialHandler.java:272)
00:26:27,304 ERROR [stderr] (default task-16) at io.undertow.servlet.handlers.ServletInitialHandler.access$000(ServletInitialHandler.java:81)
00:26:27,304 ERROR [stderr] (default task-16) at io.undertow.servlet.handlers.ServletInitialHandler$1.handleRequest(ServletInitialHandler.java:104)
00:26:27,304 ERROR [stderr] (default task-16) at io.undertow.server.Connectors.executeRootHandler(Connectors.java:202)
00:26:27,304 ERROR [stderr] (default task-16) at io.undertow.server.HttpServerExchange$1.run(HttpServerExchange.java:805)
00:26:27,304 ERROR [stderr] (default task-16) at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
00:26:27,304 ERROR [stderr] (default task-16) at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
00:26:27,304 ERROR [stderr] (default task-16) at java.lang.Thread.run(Thread.java:745)
