Удаление процессом в винде
Нужно реализовать на Java приложение ,которое снимает в Windows все процессы с пределенным именем. Как? Если конкретно ,прибить Хром с процессами плагинов ... |
| 15.01.2017, 15:00:10 |
аif you want to kill external processes (which you did not spawn from your Java app), then one thing you can do is to call O/S utilities which allow you to do that. For example, you can try a Runtime.exec() on kill command under Unix / Linux and check for return values to ensure that the application was killed or not (0 means success, -1 means error). But that of course will make your application platform dependent. http://stackoverflow.com/questions/6356340/killing-a-process-using-java ... |
| 15.01.2017, 15:30:41 |
Паша01аif you want to kill external processes (which you did not spawn from your Java app), then one thing you can do is to call O/S utilities which allow you to do that. For example, you can try a Runtime.exec() on kill command under Unix / Linux and check for return values to ensure that the application was killed or not (0 means success, -1 means error). But that of course will make your application platform dependent. http://stackoverflow.com/questions/6356340/killing-a-process-using-java добавлю:Taskkill - https://technet.microsoft.com/ru-ru/library/bb491009.aspx Parameters/fSpecifies that process(es) be forcefully terminated. This parameter is ignored for remote processes; all remote processes are forcefully terminated/tSpecifies to terminate all child processes along with the parent process commonly known as a tree kill. ... |
| 15.01.2017, 18:19:24 |
start [/forum/topic.php?fid=59&gotonew=1&tid=2123260]: |
23ms |
46ms |
68ms |
| others: | 332ms |
| total: | 535ms |
