Непонятная проблема tomcat
Падает tomcat каждые 15-30 минут. Подскажите на что он ругается в логе: =tomcat750-stderr.2017-06-29.log2017-06-29 02:56:52 Commons Daemon procrun stderr initialized июн 29, 2017 2:56:54 AM org.apache.catalina.core.AprLifecycleListener init INFO: Loaded APR based Apache Tomcat Native library 1.1.29 using APR version 1.4.8. июн 29, 2017 2:56:54 AM org.apache.catalina.core.AprLifecycleListener init INFO: APR capabilities: IPv6 [true], sendfile [true], accept filters [false], random [true]. июн 29, 2017 2:56:56 AM org.apache.catalina.core.AprLifecycleListener initializeSSL INFO: OpenSSL successfully initialized (OpenSSL 1.0.1e 11 Feb 2013) июн 29, 2017 2:56:56 AM org.apache.coyote.AbstractProtocol init INFO: Initializing ProtocolHandler ["http-apr-80"] июн 29, 2017 2:56:56 AM org.apache.coyote.AbstractProtocol init INFO: Initializing ProtocolHandler ["ajp-apr-8009"] июн 29, 2017 2:56:56 AM org.apache.catalina.startup.Catalina load INFO: Initialization processed in 2561 ms июн 29, 2017 2:56:56 AM org.apache.catalina.core.StandardService startInternal INFO: Starting service Catalina июн 29, 2017 2:56:56 AM org.apache.catalina.core.StandardEngine startInternal INFO: Starting Servlet Engine: Apache Tomcat/7.0.50 июн 29, 2017 2:56:56 AM org.apache.catalina.startup.HostConfig deployWAR INFO: Deploying web application archive C:\apache-tomcat-7.0.50\apache-tomcat-7.0.50\webapps\Replic.war июн 29, 2017 2:56:56 AM org.apache.catalina.startup.SetContextPropertiesRule begin WARNING: [SetContextPropertiesRule]{Context} Setting property 'antiJarLocking' to 'true' did not find a matching property. июн 29, 2017 2:57:00 AM org.apache.catalina.util.SessionIdGenerator createSecureRandom INFO: Creation of SecureRandom instance for session ID generation using [SHA1PRNG] took [234] milliseconds. июн 29, 2017 2:57:00 AM org.apache.catalina.startup.HostConfig deployWAR INFO: Deploying web application archive C:\apache-tomcat-7.0.50\apache-tomcat-7.0.50\webapps\ROOT.war июн 29, 2017 2:57:00 AM org.apache.catalina.startup.SetContextPropertiesRule begin WARNING: [SetContextPropertiesRule]{Context} Setting property 'antiJarLocking' to 'true' did not find a matching property. июн 29, 2017 2:58:58 AM org.apache.catalina.loader.WebappClassLoader validateJarFile INFO: validateJarFile(C:\apache-tomcat-7.0.50\apache-tomcat-7.0.50\temp\1-ROOT\WEB-INF\lib\el-api-6.0.29.jar) - jar not loaded. See Servlet Spec 3.0, section 10.7.2. Offending class: javax/el/Expression.class июн 29, 2017 2:58:58 AM org.apache.catalina.loader.WebappClassLoader validateJarFile INFO: validateJarFile(C:\apache-tomcat-7.0.50\apache-tomcat-7.0.50\temp\1-ROOT\WEB-INF\lib\servlet-api-6.0.29.jar) - jar not loaded. See Servlet Spec 3.0, section 10.7.2. Offending class: javax/servlet/Servlet.class июн 29, 2017 2:59:17 AM org.apache.catalina.startup.HostConfig deployDirectory INFO: Deploying web application directory C:\apache-tomcat-7.0.50\apache-tomcat-7.0.50\webapps\docs июн 29, 2017 2:59:17 AM org.apache.catalina.startup.SetContextPropertiesRule begin WARNING: [SetContextPropertiesRule]{Context} Setting property 'antiJarLocking' to 'true' did not find a matching property. июн 29, 2017 2:59:17 AM org.apache.catalina.startup.HostConfig deployDirectory INFO: Deploying web application directory C:\apache-tomcat-7.0.50\apache-tomcat-7.0.50\webapps\examples июн 29, 2017 2:59:17 AM org.apache.catalina.startup.SetContextPropertiesRule begin WARNING: [SetContextPropertiesRule]{Context} Setting property 'antiJarLocking' to 'true' did not find a matching property. июн 29, 2017 2:59:18 AM org.apache.catalina.startup.HostConfig deployDirectory INFO: Deploying web application directory C:\apache-tomcat-7.0.50\apache-tomcat-7.0.50\webapps\host-manager июн 29, 2017 2:59:18 AM org.apache.catalina.startup.SetContextPropertiesRule begin WARNING: [SetContextPropertiesRule]{Context} Setting property 'antiJarLocking' to 'true' did not find a matching property. июн 29, 2017 2:59:19 AM org.apache.catalina.startup.HostConfig deployDirectory INFO: Deploying web application directory C:\apache-tomcat-7.0.50\apache-tomcat-7.0.50\webapps\manager июн 29, 2017 2:59:19 AM org.apache.catalina.startup.SetContextPropertiesRule begin WARNING: [SetContextPropertiesRule]{Context} Setting property 'antiJarLocking' to 'true' did not find a matching property. июн 29, 2017 2:59:19 AM org.apache.coyote.AbstractProtocol start INFO: Starting ProtocolHandler ["http-apr-80"] июн 29, 2017 2:59:19 AM org.apache.coyote.AbstractProtocol start INFO: Starting ProtocolHandler ["ajp-apr-8009"] июн 29, 2017 2:59:19 AM org.apache.catalina.startup.Catalina start INFO: Server startup in 142721 ms июн 29, 2017 3:00:32 AM org.apache.coyote.AbstractProtocol pause INFO: Pausing ProtocolHandler ["http-apr-80"] июн 29, 2017 3:00:32 AM org.apache.coyote.AbstractProtocol pause INFO: Pausing ProtocolHandler ["ajp-apr-8009"] июн 29, 2017 3:00:32 AM org.apache.catalina.core.StandardService stopInternal INFO: Stopping service Catalina июн 29, 2017 3:00:37 AM org.apache.catalina.loader.WebappClassLoader clearReferencesThreads SEVERE: The web application [] appears to have started a thread named [DefaultQuartzScheduler_Worker-1] but has failed to stop it. This is very likely to create a memory leak. июн 29, 2017 3:00:37 AM org.apache.catalina.loader.WebappClassLoader clearReferencesThreads SEVERE: The web application [] appears to have started a thread named [Mojarra-WebResourceMonitor-1-thread-1] but has failed to stop it. This is very likely to create a memory leak. июн 29, 2017 3:00:37 AM org.apache.catalina.loader.WebappClassLoader clearReferencesThreads SEVERE: The web application [] appears to have started a thread named [Thread-6] but has failed to stop it. This is very likely to create a memory leak. июн 29, 2017 3:00:37 AM org.apache.catalina.loader.WebappClassLoader clearReferencesThreads SEVERE: The web application [/Replic] appears to have started a thread named [Abandoned connection cleanup thread] but has failed to stop it. This is very likely to create a memory leak. июн 29, 2017 3:00:37 AM org.apache.catalina.loader.WebappClassLoader clearReferencesThreads SEVERE: The web application [/Replic] appears to have started a thread named [MyScheduler_Worker-1] but has failed to stop it. This is very likely to create a memory leak. июн 29, 2017 3:00:37 AM org.apache.catalina.loader.WebappClassLoader clearReferencesThreads SEVERE: The web application [/Replic] appears to have started a thread named [Abandoned connection cleanup thread] but has failed to stop it. This is very likely to create a memory leak. июн 29, 2017 3:00:37 AM org.apache.coyote.AbstractProtocol stop INFO: Stopping ProtocolHandler ["http-apr-80"] июн 29, 2017 3:00:37 AM org.apache.coyote.AbstractProtocol stop INFO: Stopping ProtocolHandler ["ajp-apr-8009"] a.JSF.magazine.MagazineManager.update(MagazineManager.java:54) at arta.JSF.magazine.MagazineJob.execute(MagazineJob.java:23) at org.quartz.core.JobRunShell.run(JobRunShell.java:202) at org.quartz.simpl.SimpleThreadPool$WorkerThread.run(SimpleThreadPool.java:525) java.sql.SQLException: Column 'magazine_name' cannot be null Query: INSERT INTO magazine_client (magazine_name,status_id) VALUES (?,1) ON DUPLICATE KEY UPDATE status_id = ? Parameters: [null, 109] at arta.JSF.utility.AbstractQueryRunner.rethrow(AbstractQueryRunner.java:383) at arta.JSF.utility.QueryRunner.update(QueryRunner.java:551) at arta.JSF.utility.QueryRunner.update(QueryRunner.java:516) at arta.JSF.DAO.CommonGenericDAO.change(CommonGenericDAO.java:149) at arta.JSF.DAO.CommonGenericDAO.changeWithParameters(CommonGenericDAO.java:141) at arta.JSF.magazine.MagazineManager.setStatus(MagazineManager.java:263) at arta.JSF.magazine.MagazineManager.getFromServer(MagazineManager.java:249) at arta.JSF.magazine.MagazineManager.setStatus(MagazineManager.java:266) at arta.JSF.magazine.MagazineManager.getFromServer(MagazineManager.java:249) at arta.JSF.magazine.MagazineManager.setStatus(MagazineManager.java:266) at arta.JSF.magazine.MagazineManager.getFromServer(MagazineManager.java:249) at arta.JSF.magazine.MagazineManager.getNewMagazinesFromServer(MagazineManager.java:72) at arta.JSF.magazine.MagazineManager.update(MagazineManager.java:54) at arta.JSF.magazine.MagazineJob.execute(MagazineJob.java:23) at org.quartz.core.JobRunShell.run(JobRunShell.java:202) at org.quartz.simpl.SimpleThreadPool$WorkerThread.run(SimpleThreadPool.java:525) java.sql.SQLException: Column 'magazine_name' cannot be null Query: INSERT INTO magazine_client (magazine_name,status_id) VALUES (?,1) ON DUPLICATE KEY UPDATE status_id = ? Parameters: [null, 109] at arta.JSF.utility.AbstractQueryRunner.rethrow(AbstractQueryRunner.java:383) at arta.JSF.utility.QueryRunner.update(QueryRunner.java:551) at arta.JSF.utility.QueryRunner.update(QueryRunner.java:516) at arta.JSF.DAO.CommonGenericDAO.change(CommonGenericDAO.java:149) at arta.JSF.DAO.CommonGenericDAO.changeWithParameters(CommonGenericDAO.java:141) at arta.JSF.magazine.MagazineManager.setStatus(MagazineManager.java:263) at arta.JSF.magazine.MagazineManager.getFromServer(MagazineManager.java:249) at arta.JSF.magazine.MagazineManager.setStatus(MagazineManager.java:266) at arta.JSF.magazine.MagazineManager.getFromServer(MagazineManager.java:249) at arta.JSF.magazine.MagazineManager.setStatus(MagazineManager.java:266) at arta.JSF.magazine.MagazineManager.getFromServer(MagazineManager.java:249) at arta.JSF.magazine.MagazineManager.setStatus(MagazineManager.java:266) at arta.JSF.magazine.MagazineManager.getFromServer(MagazineManager.java:249) at arta.JSF.magazine.MagazineManager.getNewMagazinesFromServer(MagazineManager.java:72) at arta.JSF.magazine.MagazineManager.update(MagazineManager.java:54) at arta.JSF.magazine.MagazineJob.execute(MagazineJob.java:23) at org.quartz.core.JobRunShell.run(JobRunShell.java:202) at org.quartz.simpl.SimpleThreadPool$WorkerThread.run(SimpleThreadPool.java:525) java.sql.SQLException: Column 'magazine_name' cannot be null Query: INSERT INTO magazine_client (magazine_name,status_id) VALUES (?,1) ON DUPLICATE KEY UPDATE status_id = ? Parameters: [null, 109] at arta.JSF.utility.AbstractQueryRunner.rethrow(AbstractQueryRunner.java:383) at arta.JSF.utility.QueryRunner.update(QueryRunner.java:551) at arta.JSF.utility.QueryRunner.update(QueryRunner.java:516) at arta.JSF.DAO.CommonGenericDAO.change(CommonGenericDAO.java:149) at arta.JSF.DAO.CommonGenericDAO.changeWithParameters(CommonGenericDAO.java:141) at arta.JSF.magazine.MagazineManager.setStatus(MagazineManager.java:263) at arta.JSF.magazine.MagazineManager.getFromServer(MagazineManager.java:249) at arta.JSF.magazine.MagazineManager.setStatus(MagazineManager.java:266) at arta.JSF.magazine.MagazineManager.getFromServer(MagazineManager.java:249) at arta.JSF.magazine.MagazineManager.setStatus(MagazineManager.java:266) at arta.JSF.magazine.MagazineManager.getFromServer(MagazineManager.java:249) at arta.JSF.magazine.MagazineManager.setStatus(MagazineManager.java:266) at arta.JSF.magazine.MagazineManager.getFromServer(MagazineManager.java:249) at arta.JSF.magazine.MagazineManager.setStatus(MagazineManager.java:266) at arta.JSF.magazine.MagazineManager.getFromServer(MagazineManager.java:249) at arta.JSF.magazine.MagazineManager.getNewMagazinesFromServer(MagazineManager.java:72) at arta.JSF.magazine.MagazineManager.update(MagazineManager.java:54) at arta.JSF.magazine.MagazineJob.execute(MagazineJob.java:23) at org.quartz.core.JobRunShell.run(JobRunShell.java:202) at org.quartz.simpl.SimpleThreadPool$WorkerThread.run(SimpleThreadPool.java:525) java.sql.SQLException: Column 'magazine_name' cannot be null Query: INSERT INTO magazine_client (magazine_name,status_id) VALUES (?,1) ON DUPLICATE KEY UPDATE status_id = ? Parameters: [null, 109] at arta.JSF.utility.AbstractQueryRunner.rethrow(AbstractQueryRunner.java:383) at arta.JSF.utility.QueryRunner.update(QueryRunner.java:551) at arta.JSF.utility.QueryRunner.update(QueryRunner.java:516) at arta.JSF.DAO.CommonGenericDAO.change(CommonGenericDAO.java:149) at arta.JSF.DAO.CommonGenericDAO.changeWithParameters(CommonGenericDAO.java:141) at arta.JSF.magazine.MagazineManager.setStatus(MagazineManager.java:263) at arta.JSF.magazine.MagazineManager.getFromServer(MagazineManager.java:249) at arta.JSF.magazine.MagazineManager.setStatus(MagazineManager.java:266) at arta.JSF.magazine.MagazineManager.getFromServer(MagazineManager.java:249) at arta.JSF.magazine.MagazineManager.setStatus(MagazineManager.java:266) at arta.JSF.magazine.MagazineManager.getFromServer(MagazineManager.java:249) at arta.JSF.magazine.MagazineManager.setStatus(MagazineManager.java:266) at arta.JSF.magazine.MagazineManager.getFromServer(MagazineManager.java:249) at arta.JSF.magazine.MagazineManager.setStatus(MagazineManager.java:266) at arta.JSF.magazine.MagazineManager.getFromServer Данный лог файл за день может набрать в размере 40+ Гб. Софт - образовательный портал через который проводят тестирования. Проблема выявилась после того как разработчик обновил софт и томкат вместе с ним. Проблему же бесплатно фиксить не хочет/не может. ... |
| 29.06.2017, 01:16:56 |
Код: plaintext ... |
| 29.06.2017, 06:04:38 |
MakNaitПроблема выявилась после того как разработчик обновил софт и томкат вместе с ним. Проблему же бесплатно фиксить не хочет/не может. Как правильно заметил коллега Hett Код: java 1. Налицо попытка впихнуть в таблицу невпихуемое! Ткните носом разработчика в это сообщение и скажите ему, что исправление глюков уже оплаченной программы есть действо праведное и бескорыстное. ... |
| 29.06.2017, 09:48:44 |
start [/forum/topic.php?fid=59&gotonew=1&tid=2122804]: |
25ms |
70ms |
89ms |
| others: | 304ms |
| total: | 558ms |
