Связи в Hibernate выдает ошибку
[JAVA]@Entity @Table(name = "users") public class User { public enum Role { ROLE_ADMIN, ROLE_USER } @Id @GeneratedValue (strategy = GenerationType.AUTO) private long ID; @Column(name = "firstname") private String firstName; @Column(name = "lastname") private String lastName; @Column(name = "login") private String login; @Column(name = "password") private String passwordHash; @Column(name = "role") private Role role; @OneToMany(mappedBy = "tables") private List<TableC> tableList;[/JAVA] [JAVA]@Entity @Table(name = "tables") public class TableC { @Id @GeneratedValue(strategy = GenerationType.AUTO) private long ID; @Column(name = "table_number") private Integer tableNumber; @Column(name = "assigned") private boolean tableStatus; @ManyToOne @JoinTable (name = "waiter_tables", joinColumns = @JoinColumn(name = "user_id"), inverseJoinColumns = @JoinColumn(name = "table_id")) private User user; @OneToMany(mappedBy = "tables") private Set <Order> orderList;[/JAVA] Добрый день есть два класса под них таблицы users и tables, и связующая таблица waiter_tables. При запуске выдает ошибку Caused by: org.hibernate.AnnotationException: mappedBy reference an unknown target entity property: am.sfl.cafemanager.model.TableC.tables in am.sfl.cafemanager.model.User.tableList at org.hibernate.cfg.annotations.CollectionBinder.bindStarToManySecondPass(CollectionBinder.java:769) at org.hibernate.cfg.annotations.CollectionBinder$1.secondPass(CollectionBinder.java:729) at org.hibernate.cfg.CollectionSecondPass.doSecondPass(CollectionSecondPass.java:70) at org.hibernate.cfg.Configuration.originalSecondPassCompile(Configuration.java:1697) at org.hibernate.cfg.Configuration.secondPassCompile(Configuration.java:1426) at org.hibernate.cfg.Configuration.buildSessionFactory(Configuration.java:1846) at org.hibernate.jpa.boot.internal.EntityManagerFactoryBuilderImpl$4.perform(EntityManagerFactoryBuilderImpl.java:857) ... 66 more ... |
| 09.08.2017, 11:50:21 |
Не пробовали переводить сообщение об ошибки. Оно вам прямо указывает что вы в mappedBy какую-то ерунду написали. ... |
| 09.08.2017, 11:58:35 |
Blazkowicz, ))) Если знал что там писать, то не спрашивал бы тут. Да и при дефолте все равно выдает ошибку. ... |
| 09.08.2017, 12:01:34 |
David Karchikyan))) Если знал что там писать, то не спрашивал бы тут. Да и при дефолте все равно выдает ошибку. Как так-то? Вот тут написано. http://docs.oracle.com/javaee/6/api/javax/persistence/OneToMany.html#mappedBy() И вот тут https://docs.jboss.org/hibernate/orm/4.1/manual/en-US/html/ch07.html ... |
| 09.08.2017, 12:06:24 |
Blazkowicz, Если не трудно покажите как исправить потому что все равно выдает ошибку @OneToMany(mappedBy = "users") private Set<TableC> tableList; @ManyToOne private User user ... |
| 09.08.2017, 12:14:49 |
Вот общий лог ошибки org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'entityManagerFactory' defined in ServletContext resource [/WEB-INF/config-data.xml]: Invocation of init method failed; nested exception is javax.persistence.PersistenceException: [PersistenceUnit: default] Unable to build Hibernate SessionFactory at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1628) at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:555) at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:483) at org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:306) at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:230) at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:302) at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:197) at org.springframework.context.support.AbstractApplicationContext.getBean(AbstractApplicationContext.java:1081) at org.springframework.context.support.AbstractApplicationContext.finishBeanFactoryInitialization(AbstractApplicationContext.java:856) at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:542) at org.springframework.web.context.ContextLoader.configureAndRefreshWebApplicationContext(ContextLoader.java:443) at org.springframework.web.context.ContextLoader.initWebApplicationContext(ContextLoader.java:325) at org.springframework.web.context.ContextLoaderListener.contextInitialized(ContextLoaderListener.java:107) at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:4734) at org.apache.catalina.core.StandardContext.startInternal(StandardContext.java:5196) at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:183) at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:752) at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:728) at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:734) at org.apache.catalina.startup.HostConfig.manageApp(HostConfig.java:1702) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.lang.reflect.Method.invoke(Method.java:497) at org.apache.tomcat.util.modeler.BaseModelMBean.invoke(BaseModelMBean.java:300) at com.sun.jmx.interceptor.DefaultMBeanServerInterceptor.invoke(DefaultMBeanServerInterceptor.java:819) at com.sun.jmx.mbeanserver.JmxMBeanServer.invoke(JmxMBeanServer.java:801) at org.apache.catalina.mbeans.MBeanFactory.createStandardContext(MBeanFactory.java:456) at org.apache.catalina.mbeans.MBeanFactory.createStandardContext(MBeanFactory.java:405) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.lang.reflect.Method.invoke(Method.java:497) at org.apache.tomcat.util.modeler.BaseModelMBean.invoke(BaseModelMBean.java:300) at com.sun.jmx.interceptor.DefaultMBeanServerInterceptor.invoke(DefaultMBeanServerInterceptor.java:819) at com.sun.jmx.mbeanserver.JmxMBeanServer.invoke(JmxMBeanServer.java:801) at javax.management.remote.rmi.RMIConnectionImpl.doOperation(RMIConnectionImpl.java:1471) at javax.management.remote.rmi.RMIConnectionImpl.access$300(RMIConnectionImpl.java:76) at javax.management.remote.rmi.RMIConnectionImpl$PrivilegedOperation.run(RMIConnectionImpl.java:1312) at javax.management.remote.rmi.RMIConnectionImpl.doPrivilegedOperation(RMIConnectionImpl.java:1404) at javax.management.remote.rmi.RMIConnectionImpl.invoke(RMIConnectionImpl.java:832) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.lang.reflect.Method.invoke(Method.java:497) at sun.rmi.server.UnicastServerRef.dispatch(UnicastServerRef.java:323) at sun.rmi.transport.Transport$1.run(Transport.java:200) at sun.rmi.transport.Transport$1.run(Transport.java:197) at java.security.AccessController.doPrivileged(Native Method) at sun.rmi.transport.Transport.serviceCall(Transport.java:196) at sun.rmi.transport.tcp.TCPTransport.handleMessages(TCPTransport.java:568) at sun.rmi.transport.tcp.TCPTransport$ConnectionHandler.run0(TCPTransport.java:826) at sun.rmi.transport.tcp.TCPTransport$ConnectionHandler.lambda$run$256(TCPTransport.java:683) at java.security.AccessController.doPrivileged(Native Method) at sun.rmi.transport.tcp.TCPTransport$ConnectionHandler.run(TCPTransport.java:682) at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142) at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617) at java.lang.Thread.run(Thread.java:745) Caused by: javax.persistence.PersistenceException: [PersistenceUnit: default] Unable to build Hibernate SessionFactory at org.hibernate.jpa.boot.internal.EntityManagerFactoryBuilderImpl.persistenceException(EntityManagerFactoryBuilderImpl.java:1249) at org.hibernate.jpa.boot.internal.EntityManagerFactoryBuilderImpl.access$600(EntityManagerFactoryBuilderImpl.java:120) at org.hibernate.jpa.boot.internal.EntityManagerFactoryBuilderImpl$4.perform(EntityManagerFactoryBuilderImpl.java:860) at org.hibernate.jpa.boot.internal.EntityManagerFactoryBuilderImpl$4.perform(EntityManagerFactoryBuilderImpl.java:850) at org.hibernate.boot.registry.classloading.internal.ClassLoaderServiceImpl.withTccl(ClassLoaderServiceImpl.java:425) at org.hibernate.jpa.boot.internal.EntityManagerFactoryBuilderImpl.build(EntityManagerFactoryBuilderImpl.java:849) at org.springframework.orm.jpa.vendor.SpringHibernateJpaPersistenceProvider.createContainerEntityManagerFactory(SpringHibernateJpaPersistenceProvider.java:60) at org.springframework.orm.jpa.LocalContainerEntityManagerFactoryBean.createNativeEntityManagerFactory(LocalContainerEntityManagerFactoryBean.java:353) at org.springframework.orm.jpa.AbstractEntityManagerFactoryBean.buildNativeEntityManagerFactory(AbstractEntityManagerFactoryBean.java:370) at org.springframework.orm.jpa.AbstractEntityManagerFactoryBean.afterPropertiesSet(AbstractEntityManagerFactoryBean.java:359) at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.invokeInitMethods(AbstractAutowireCapableBeanFactory.java:1687) at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1624) ... 57 more Caused by: org.hibernate.AnnotationException: mappedBy reference an unknown target entity property: am.sfl.cafemanager.model.TableC.users in am.sfl.cafemanager.model.User.tableList at org.hibernate.cfg.annotations.CollectionBinder.bindStarToManySecondPass(CollectionBinder.java:769) at org.hibernate.cfg.annotations.CollectionBinder$1.secondPass(CollectionBinder.java:729) at org.hibernate.cfg.CollectionSecondPass.doSecondPass(CollectionSecondPass.java:70) at org.hibernate.cfg.Configuration.originalSecondPassCompile(Configuration.java:1697) at org.hibernate.cfg.Configuration.secondPassCompile(Configuration.java:1426) at org.hibernate.cfg.Configuration.buildSessionFactory(Configuration.java:1846) at org.hibernate.jpa.boot.internal.EntityManagerFactoryBuilderImpl$4.perform(EntityManagerFactoryBuilderImpl.java:857) ... 66 more ... |
| 09.08.2017, 12:17:54 |
David Karchikyan@OneToMany(mappedBy = " users ") private Set<TableC> tableList; @ManyToOne private User user Ну, вот вообще ничего не смущает. Правда? ... |
| 09.08.2017, 12:18:31 |
David Karchikyanunknown target entity property: am.sfl.cafemanager.model.TableC.users Ну, нет у вас в сущности TableC свойства users. О чем вам Hibernate и пишет. Почему бы не указать свойство которое там есть? ... |
| 09.08.2017, 12:19:55 |
файл config-data.xml Код: xml 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. 15. 16. 17. 18. 19. 20. 21. 22. 23. 24. 25. 26. 27. 28. 29. 30. 31. 32. 33. 34. 35. 36. 37. 38. 39. 40. 41. 42. 43. 44. 45. 46. 47. 48. 49. 50. 51. 52. 53. ... |
| 09.08.2017, 12:20:36 |
короче ни чего не понял, еще больше запутали досвидание ... |
| 09.08.2017, 12:27:45 |
start [/forum/topic.php?fid=59&gotonew=1&tid=2122680]: |
26ms |
51ms |
94ms |
| others: | 325ms |
| total: | 569ms |
