У меня запускается Pentaho DI, но не запускается Pentaho BI
Запустил я start-pentaho.bat Поначалу получил следующее: C:\VERB\Pentaho\biserver_ce_5.0.1>start-pentaho.bat DEBUG: Using JAVA_HOME DEBUG: _PENTAHO_JAVA_HOME=C:\Program Files\Java\jdk1.8.0_131 DEBUG: _PENTAHO_JAVA=C:\Program Files\Java\jdk1.8.0_131\bin\java.exe Using CATALINA_BASE: "C:\VERB\Pentaho\biserver_ce_5.0.1\tomcat" Using CATALINA_HOME: "C:\VERB\Pentaho\biserver_ce_5.0.1\tomcat" Using CATALINA_TMPDIR: "C:\VERB\Pentaho\biserver_ce_5.0.1\tomcat\temp" Using JRE_HOME: "C:\Program Files\Java\jdk1.8.0_131" Using CLASSPATH: "C:\VERB\Pentaho\biserver_ce_5.0.1\tomcat\bin\bootstrap.j ar" А потом появилось окошко с Jav’овской кружкой и заголовком Tomcat, в котором стал сыпаться следующий текст: Java HotSpot(TM) Client VM warning: ignoring option MaxPermSize=256m; support wa s removed in 8.0 рту 25, 2017 11:58:14 AM org.apache.catalina.core.AprLifecycleListener init INFO: Loaded APR based Apache Tomcat Native library 1.1.23 using APR version 1.4 .6. рту 25, 2017 11:58:14 AM org.apache.catalina.core.AprLifecycleListener init INFO: APR capabilities: IPv6 [true], sendfile [true], accept filters [false], ra ndom [true]. рту 25, 2017 11:58:16 AM org.apache.catalina.core.AprLifecycleListener initializ eSSL INFO: OpenSSL successfully initialized with version OpenSSL 1.0.0g 18 Jan 2012 рту 25, 2017 11:58:17 AM org.apache.coyote.http11.Http11AprProtocol init INFO: Initializing Coyote HTTP/1.1 on http-8080 рту 25, 2017 11:58:17 AM org.apache.coyote.ajp.AjpAprProtocol init INFO: Initializing Coyote AJP/1.3 on ajp-8009 рту 25, 2017 11:58:17 AM org.apache.catalina.startup.Catalina load INFO: Initialization processed in 3574 ms рту 25, 2017 11:58:17 AM org.apache.catalina.core.StandardService start INFO: Starting service Catalina рту 25, 2017 11:58:17 AM org.apache.catalina.core.StandardEngine start INFO: Starting Servlet Engine: Apache Tomcat/6.0.36 рту 25, 2017 11:58:17 AM org.apache.catalina.startup.HostConfig deployDescriptor INFO: Deploying configuration descriptor pentaho.xml после этого сыплется еще много всякого текста заканчивается следующим: Caused by: org.pentaho.platform.api.engine.PentahoSystemException: PentahoSystem .ERROR_0014 - Error while trying to execute startup sequence for org.pentaho.pla tform.repository2.unified.BackingRepositoryLifecycleManagerSystemListener at org.pentaho.platform.engine.core.system.PentahoSystem.notifySystemLis tenersOfStartup(PentahoSystem.java:365) ... 32 more 12:00:19,065 ERROR [Logger] Error end: Pentaho BI Platform server failed to properly initialize. The system will not be available for requests. (Pentaho Platform Core 5.0.1-stable.-1) Fully Qualified Server Url = http://localhost:8080/pentaho/, Solution Path = C:\VERB\Pentaho\bi server_ce_5.0.1\pentaho-solutions рту 25, 2017 12:00:19 PM org.apache.catalina.startup.HostConfig deployDirectory INFO: Deploying web application directory pentaho-style рту 25, 2017 12:00:19 PM org.apache.catalina.startup.HostConfig deployDirectory INFO: Deploying web application directory ROOT рту 25, 2017 12:00:19 PM org.apache.catalina.startup.HostConfig deployDirectory INFO: Deploying web application directory sw-style рту 25, 2017 12:00:19 PM org.apache.coyote.http11.Http11AprProtocol start INFO: Starting Coyote HTTP/1.1 on http-8080 рту 25, 2017 12:00:19 PM org.apache.coyote.ajp.AjpAprProtocol start INFO: Starting Coyote AJP/1.3 on ajp-8009 рту 25, 2017 12:00:19 PM org.apache.catalina.startup.Catalina start INFO: Server startup in 122181 ms что не так и что делать ... |
| 25.08.2017, 10:58:21 |
X3 ктоC:\VERB\Pentaho\biserver_ce_5.0.1>start-pentaho.bat DEBUG: _PENTAHO_JAVA_HOME=C:\Program Files\Java\jdk1.8.0_131 Java HotSpot(TM) Client VM warning: ignoring option MaxPermSize=256m; support wa s removed in 8.0 Есть подозрение что для такой старой версии нужна была Java 7. X3 ктопосле этого сыплется еще много всякого текста В котором было самое конкретное сообщение об ошибке. ... |
| 25.08.2017, 11:08:15 |
start [/forum/search_topic.php?author=MaeAs&author_mode=last_topics&do_search=1]: |
26ms |
26ms |
44ms |
89ms |
| others: | 1197ms |
| total: | 1472ms |
