Вопрос на засыпку: как можно синхронизировать scrollbox-ы?
Изменяешь положение бегунка у одного- аналогично изменяется у другого. Проблема в том, что у него нет события onScroll :( ... |
| 25.11.2002, 04:45:18 |
Копать в сторону WM_VSCROLL, WM_HSCROLL и вокруг них. ______ ... |
| 25.11.2002, 07:33:03 |
unit Unit1; interface uses Windows, Messages, SysUtils, Classes, Graphics, Controls, Forms, Dialogs, Grids; type {$IFDEF WIN32} WParameter = LongInt; {$ELSE} WParameter = Word; {$ENDIF} LParameter = LongInt; TForm1 = class(TForm) ScrollBox1: TScrollBox; StringGrid1: TStringGrid; ScrollBox2: TScrollBox; StringGrid2: TStringGrid; procedure FormCreate(Sender: TObject); procedure FormDestroy(Sender: TObject); private { Private declarations } public { Public declarations } end; var Form1: TForm1; OldWindowProc : Pointer; implementation {$R *.DFM} function NewWindowProc(WindowHandle : hWnd; TheMessage : WParameter; ParamW : WParameter; ParamL : LParameter) : LongInt {$IFDEF WIN32} stdcall; {$ELSE} ; export; {$ENDIF} var TheRangeMin : integer; TheRangeMax : integer; TheRange : integer; begin if TheMessage = WM_VSCROLL then begin GetScrollRange(WindowHandle, SB_HORZ, TheRangeMin, TheRangeMax); TheRange := GetScrollPos(WindowHandle, SB_VERT); {Make sure we wont exceed the range} if TheRange < TheRangeMin then TheRange := TheRangeMin else if TheRange > TheRangeMax then TheRange := TheRangeMax; {Set the horizontal scroll bar} SetScrollPos(form1.ScrollBox2.Handle, SB_Vert, TheRange, true); end; if TheMessage = WM_HSCROLL then begin GetScrollRange(WindowHandle, SB_VERT, TheRangeMin, TheRangeMax); TheRange := GetScrollPos(WindowHandle, SB_HORZ); if TheRange < TheRangeMin then TheRange := TheRangeMin else if TheRange > TheRangeMax then TheRange := TheRangeMax; {Set the vertical scroll bar} SetScrollPos(form1.ScrollBox2.Handle, SB_HORZ, TheRange, true); end; NewWindowProc := CallWindowProc(OldWindowProc, WindowHandle, TheMessage, ParamW, ParamL); end; procedure TForm1.FormCreate(Sender: TObject); begin OldWindowProc := Pointer(SetWindowLong(ScrollBox1.Handle, GWL_WNDPROC, LongInt(@NewWindowProc))); end; procedure TForm1.FormDestroy(Sender: TObject); begin SetWindowLong(ScrollBox1.Handle, GWL_WNDPROC, LongInt(OldWindowProc)); end; end. ... |
| 25.11.2002, 16:01:17 |
Пардо не дописал- положение скролов синхронизируется, а содержимое вот не прокручиватся :( что делать?? ... |
| 25.11.2002, 16:02:19 |
Спасибо, разобрался! Ну и ламмер я! ... |
| 25.11.2002, 16:09:30 |
Код: plaintext 1. 2. Я бы конечно создал класс-наследник - где бы и перекрыл WM_VSCROLL , WM_HSCROLL . Но у тебя красивше ... ))) ... |
| 25.11.2002, 16:12:11 |
start [/forum/topic.php?fid=58&gotonew=1&tid=2119612]: |
57ms |
54ms |
| others: | 213ms |
| total: | 375ms |
