Как из делфей активизировать репликацию?
Спасибо. ... |
| 18.12.2002, 10:59:27 |
Какую???????? ... |
| 18.12.2002, 11:13:07 |
SQL Server 2000 MERGE PUSH ... |
| 18.12.2002, 11:16:43 |
рыть куда-то сюда (BOL replication, stored procedures) Introducing Replication Programming As an alternative to using SQL Server Enterprise Manager, you can use the following programming interfaces to implement, administer, and monitor replication: Microsoft® ActiveX® controls, when used within custom applications that employ Microsoft Visual Basic® or Microsoft Visual C++®, provide programmable controls for administering and controlling the Snapshot Agent, the Distribution Agent, and the Merge Agent. These controls can be used to program activities needed to operate replication. Using ActiveX replication controls, you can build custom applications to configure and administer replication. Benefits include: ... |
| 18.12.2002, 11:51:26 |
start [/forum/search_topic.php?author=Wow.%21%21&author_mode=last_posts&do_search=1]: |
197ms |
28ms |
| others: | 1159ms |
| total: | 1445ms |
