Как создать из программы чистую БД Access?
| 14.05.2003, 14:35 |
Procedure CreateMSAccessDatabase(filename : String); var DAO: Variant; i:integer; Const Engines:array[0..2] of string=('DAO.DBEngine.36', 'DAO.DBEngine.35', 'DAO.DBEngine'); Function CheckClass(OLEClassName:string):boolean; var Res: HResult; begin Result:=CoCreateInstance(ProgIDToClassID(OLEClassName), nil, CLSCTX_INPROC_SERVER or CLSCTX_LOCAL_SERVER, IDispatch, Res)=S_OK; end; begin For i:=0 to 2 do if CheckClass(Engines ) then begin DAO := CreateOleObject(Engines); DAO.Workspaces[0].CreateDatabase(filename, ';LANGID=0x0409;CP=1252;COUNTRY=0', 32); exit; end; Raise Exception.Create('DAO engine could not be initialized'); end; ... |
| 14.05.2003, 14:54 |
start [/forum/topic.php?fid=58&gotonew=1&tid=2118317]: |
129ms |
34ms |
| others: | 240ms |
| total: | 441ms |
