DLL
type TInitResDLL = procedure(MgrToolInf: TMgrToolInf); StdCall; .... var hDLL: THandle; pInit: TInitResDLL; ... begin ... hDLL := LoadLibrary(PChar(DllName)); .. if hDLL = HINSTANCE_ERROR then raise Exception.Create(Format(errLoadDLL,[DllName, GetLastError])); ... @pInit := GetProcAddress(hDLL, InitPrcName); if @pInit = nil then begin FreeLibrary(hDLL); raise Exception.Create(Format(errGetInitProc,[DllName])); end; // if try pInit(MgrToolInf); finally ... end; .... ... |
| 25.05.2003, 23:19 |
start [/forum/topic.php?fid=58&gotonew=1&tid=2118204]: |
81ms |
33ms |
| others: | 265ms |
| total: | 430ms |
