Как изменить дату модификации файла?
Из дельфей? ... |
| 09.09.2003, 16:41 |
Используй function FileSetDate(Handle: Integer; Age: Integer): Integer; Description FileSetDate sets the OS timestamp of the file given by Handle to the value given by Age. The DateTimeToFileDate function can be used to convert a TDateTime value to a OS timestamp. The return value is zero if the function was successful. Otherwise the return value is an error code. ... |
| 10.09.2003, 07:59 |
start [/forum/topic.php?fid=58&gotonew=1&tid=2116958]: |
40ms |
33ms |
| others: | 230ms |
| total: | 342ms |
