имена полей и descriptions
как их можно вытащить в массивчик? ... |
| 11.09.2003, 05:29 |
ладно, имена уже не надо а вот описание, ну пожалуйста... все что хотите потом... в рамках ... |
| 11.09.2003, 07:27 |
TDataSet Indicates the persistent TDataSetField object that owns the nested dataset. property DataSetField: TDataSetField; Description Use DataSetField when the dataset is the nested detail set of another dataset, such as an Oracle8 nested dataset. Read DataSetField to access the data set field component in the master dataset that comprises this dataset. Set DataSetField to a field component in the master dataset to assign this dataset as the value of that field component. Note: When setting the DataSetField property, the dataset must be of (or a descendant of) the class specified by the master dataset’s NestedDataSetClass property. Otherwise, setting DataSetField raises an exception. Further, setting DataSetField to a TDataSetField that is contained in the same dataset raises an exception (A dataset can’t be nested in itself). ... |
| 11.09.2003, 10:46 |
start [/forum/topic.php?fid=58&gotonew=1&tid=2116936]: |
55ms |
46ms |
| others: | 259ms |
| total: | 419ms |
