Local SQL Help!!! Nested select!!!
Здравствуйте! Очень нужены вложенный запрос, подобный следующему при работе с LocalSQL (таблицы Paradox) select i.Surname, i.Name, i.Parname, sum(i.Fuel) as 'Fuel' from ( select Surname, Name, Parname, sum(Fuel) as 'Fuel' from T_OilSupply where NumSign = 'а566рт' \ and DateOut <= '30.06.2003' and DateOut >= '01.06.2003' group by Surname, Name, Parname UNION select Surname, Name, Parname, sum(Fuel) as 'Fuel' from T_BusinessTrip where NumSign = 'а566рт' and DateIn <= '30.06.2003' and DateIn >= '01.06.2003' group by Surname, Name, Parname ) i group by i.Surname, i.Name, i.Parname Данный запрос отлично работает для MSSQL (только даты там по-другому).. Но теперь делаю задачу на таблицах Paradox - соответственно LocalSQL... Как можно выкрутиться? С уважением Роман ... |
| 30.09.2003, 14:31 |
Local SQL Help -> Index -> VIEWs To use an SQL statement as a VIEW, save it to a simple text file (with a .SQL extension), such as by using the Windows applet NotePad. Then, in a local SQL statement, mention the file by name where you would otherwise have named a base table. Enclose the file name in quotation marks. For example, assume the SQL statement below saved to the text file CA_CUST.SQL: SELECT CustNo, Company FROM "Customer.db" WHERE (State = "CA") Another local SQL statement can use the result set produced by this saved query by naming the .SQL file in the FROM clause of a SELECT statement: SELECT * FROM "CA_Cust.sql" WHERE (SUBSTRING(Company FROM 1 FOR 1) <= "M") ... |
| 30.09.2003, 14:49 |
Thanks a lot. I try to use saved SQL statement... I didn't think about this way. May be you know how to get select from another TQuery components if it's possible. Best regards Roman xroot@mail.ru ... |
| 01.10.2003, 06:55 |
start [/forum/search_topic.php?author=GeoPHP&author_mode=last_topics&do_search=1]: |
84ms |
41ms |
| others: | 629ms |
| total: | 842ms |
