Report
Где в Delphi 7 находится репотр ??????? ... |
| 24.10.2003, 13:06 |
Report
...Delphi 7 has been released and has the usual QuickReport standard bundled with it. If the components don't appear on the palette, use the packages menu to install Dclqrt70.bpl from the bin directory. Install Dcltqr70 too if you want the TeeChart integration. ... |
| 24.10.2003, 13:36 |
start [/forum/topic.php?fid=58&gotonew=1&tid=2116253]: |
65ms |
56ms |
| others: | 218ms |
| total: | 399ms |
