ALT Key Fix
Update (Dec 18 2006): Per-Erik Andersson came up with a new approach that is MUCH BETTER. It hooks the WM_UPDATEUISTATE message and only requires a single component instance to handle all forms in an application. Source is available at http://cc.codegear.com/item/24282 всем доброго утра! качните, плиз, и перешлите на mib2k2[@]yandex.ru ... |
| 18.12.2017, 08:38 |
start [/forum/topic.php?fid=58&gotonew=1&tid=2041433]: |
250ms |
29ms |
| others: | 199ms |
| total: | 528ms |
