Подскажите аналоги "chr" и "ord" для wideChar
Подскажите аналоги "chr" и "ord" для wideChar. ... |
| 12.10.2018, 07:47 |
analog, Они довольно просты: Код: pascal 1. 2. ... |
| 12.10.2018, 07:57 |
Необходимо первым делом справку к делфи ставить. Там много полезного можно найти: HELPChr returns the character with the ordinal value (ASCII value) of the byte-type expression, X. The Byte parameter is an unsigned integer value large enough to represent a character. Word or UInt16 is also appropriate, because now that the string type is Unicode, a character is represented by two bytes. Chr is an old Pascal standard function. For clarity, you can use a typecast such as Char() or AnsiChar() depending on the character type needed. ... |
| 12.10.2018, 07:57 |
start [/forum/topic.php?fid=58&gotonew=1&tid=2040291]: |
171ms |
27ms |
| others: | 189ms |
| total: | 426ms |
