Как подружить DevExpress с TStyleManager?
Как подружить DevExpress с TStyleManager.SetStyle ? Стили DevExpress и Delphi что то не дружат. Как починить? ... |
| 29.08.2021, 21:03:30 |
AWSVladimir, дружи в одну девочку https://supportcenter.devexpress.com/ticket/details/t478987/devexpress-themes...you are using TStyleManager. Our VCL controls are not compatible with StyleManager's styles, so I suggest you disable it and consider using our skins in your application. ... |
| 29.08.2021, 21:21:56 |
start [/forum/topic.php?fid=58&gotonew=1&tid=2037072]: |
46ms |
55ms |
| others: | 282ms |
| total: | 458ms |
