Как создать ярлык????
Здравствуйте!!! Помогите пожалуйста создать ярлык (программно) в Buildere 5!!! Спасибо! ... |
| 29.07.2003, 14:08:27 |
The CreateLink sample function in the following example creates a shortcut. The parameters include a pointer to the name of the file to link to, a pointer to the name of the shortcut that you are creating, and a pointer to the description of the link. The description consists of the string, "Shortcut to file name," where file name is the name of the file to link to. Because CreateLink calls the CoCreateInstance function, it is assumed that the CoInitialize function has already been called. CreateLink uses the IPersistFile interface to save the shortcut and the IShellLink interface to store the file name and description. Код: plaintext 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. 15. 16. 17. 18. 19. 20. 21. 22. 23. 24. 25. 26. 27. 28. 29. 30. 31. 32. 33. 34. 35. 36. 37. 38. 39. 40. 41. 42. 43. 44. 45. ... |
| 30.07.2003, 13:34:14 |
start [/forum/topic.php?fid=57&gotonew=1&tid=2036157]: |
56ms |
64ms |
| others: | 301ms |
| total: | 498ms |
