Народ помогите с Excel
нашел пример CDatabase database; CString sSql; CString sItem1, sItem2; CString sDriver; CString sDsn; CString sFile = "ReadExcel.xls"; ...... TRY { // Open the database using the former created pseudo DSN database.Open(NULL,false,false,sDsn); // Allocate the recordset CRecordset recset( &database ); // Build the SQL string // Remember to name a section of data in the Excel sheet using "Insert->Names" to be // able to work with the data like you would with a table in a "real" database. There // may be more than one table contained in a worksheet. sSql = "SELECT field_1, field_2 " "FROM demo_table " "ORDER BY field_1"; (CRecordset::forwardOnly,sSql,CRecordset::readOnly); ............... Вот здесь то и возникла проблема, а что делать если я не знаю названия таблицы, т.е. как мне ее узнать. ... |
| 22.09.2003, 18:33:08 |
start [/forum/topic.php?fid=57&gotonew=1&tid=2035974]: |
30ms |
66ms |
23ms |
98ms |
| others: | 318ms |
| total: | 592ms |
