typelib editor
Что означают параметры replaseable, restricted,UI Default? P.S. Как они переводятся на русский я знаю. C ув. Tors ... |
| 04.05.2004, 20:43:37 |
typelib editor
uidefault Description Indicates that the type information member is the default member for display in the user interface. Allowed on A member of an interface or dispinterface. Comments This attribute is used to mark an event as the default (the first one created) or a property as the default (the one to select first in the properties browser). For example, Visual Basic uses this attribute in the following ways: When an object is double-clicked at design time, Visual Basic jumps to the event in the default source interface that is marked as [uidefault]. If there is no such member, then Visual Basic displays the first one listed in the default source interface. When an object is selected at design time, by default, the Properties window in Visual Basic displays the property in the default interface that is marked as [uidefault]. If there is no such member, then Visual Basic displays the first one listed in the default interface. restricted Description Prevents the item from being used by a macro programmer. Allowed on Type library, type information, coclass member, or member of a module or interface. Comments This attribute is allowed on a member of a coclass, independent of whether the member is a dispinterface or interface, and independent of whether the member is a sink or source. A member of a coclass cannot have both the restricted and default attributes. replaceable - в документации к ODL не нашел, не знаю, что этим хотели сказать ===== Не дождетесь! ... |
| 05.05.2004, 15:12:42 |
start [/forum/topic.php?fid=57&gotonew=1&tid=2035009]: |
49ms |
71ms |
| others: | 327ms |
| total: | 526ms |
