Memory leak????
Народ! Может кто сталкивался с подобным? При сборка проекта (когда коннекчусь к фтп серваку) идет следующая подгрузка: Loaded 'ntdll.dll', no matching symbolic information found. Loaded 'D:\WINDOWS\system32\kernel32.dll', no matching symbolic information found. Loaded 'D:\WINDOWS\system32\user32.dll', no matching symbolic information found. Loaded 'D:\WINDOWS\system32\gdi32.dll', no matching symbolic information found. Loaded 'D:\WINDOWS\system32\comdlg32.dll', no matching symbolic information found. Loaded 'D:\WINDOWS\system32\shlwapi.dll', no matching symbolic information found. Loaded 'D:\WINDOWS\system32\advapi32.dll', no matching symbolic information found. Loaded 'D:\WINDOWS\system32\rpcrt4.dll', no matching symbolic information found. Loaded 'D:\WINDOWS\system32\msvcrt.dll', no matching symbolic information found. Loaded 'D:\WINDOWS\system32\comctl32.dll', no matching symbolic information found. Loaded 'D:\WINDOWS\system32\shell32.dll', no matching symbolic information found. Loaded 'D:\WINDOWS\system32\winspool.drv', no matching symbolic information found. Loaded 'D:\WINDOWS\system32\wininet.dll', no matching symbolic information found. Loaded 'D:\WINDOWS\system32\crypt32.dll', no matching symbolic information found. Loaded 'D:\WINDOWS\system32\msasn1.dll', no matching symbolic information found. Loaded 'D:\WINDOWS\system32\oleaut32.dll', no matching symbolic information found. Loaded 'D:\WINDOWS\system32\ole32.dll', no matching symbolic information found. Loaded 'D:\WINDOWS\WinSxS\x86_Microsoft.Windows.Common-Controls_6595b64144ccf1df_6.0.2600.2180_x-ww_a84f1ff9\comctl32.dll', no matching symbolic information found. Loaded 'D:\WINDOWS\system32\MSCTF.dll', no matching symbolic information found. Loaded 'D:\Program Files\stickies\shook45.dll', no matching symbolic information found. Loaded 'D:\Program Files\ABBYY Lingvo 10 Multilingual Dictionary\LvHook.dll', no matching symbolic information found. Кто знает что это и какого он это подгружает??? Особенно интересна последняя подгрузка...лингво... ... |
| 06.10.2005, 17:31:55 |
Memory leak????
Ctrl-Ins-Ins нажимать любишь, чтобы тебе перевод дали ? Вот для этого и делается хук, который грузит кусок кода во все процессы. Погаси Лингву, не будет этой DLL. ... |
| 07.10.2005, 00:14:55 |
start [/forum/topic.php?fid=57&gotonew=1&tid=2032658]: |
49ms |
37ms |
| others: | 214ms |
| total: | 339ms |
