програмка для перебора
Нужна прога, которая перебирает все вариации заданных слов. Входные параметры: 10 слов На выходе: текстовый документ со всеми вариантами перестановок. Или хотябы алгоритм подскажите :) ... |
| 20.10.2005, 11:08:08 |
MSDN rulez: // next_permutation.cpp // compile with: /EHsc // Illustrates how to use the next_permutation function. // // Functions: // next_permutation : Change the order of the sequence to the // next lexicograhic permutation. // disable warning C4786: symbol greater than 255 character, // okay to ignore #pragma warning(disable: 4786) #include <iostream> #include <vector> #include <string> #include <algorithm> #include <functional> using namespace std ; int main() { const int VECTOR_SIZE = 3 ; // Define a template class vector of strings typedef vector<string> StrVector ; //Define an iterator for template class vector of strings typedef StrVector::iterator StrVectorIt ; //Define an ostream iterator for strings typedef ostream_iterator<string> StrOstreamIt; StrVector Pattern(VECTOR_SIZE) ; StrVectorIt start, end, it ; StrOstreamIt outIt(cout, " ") ; start = Pattern.begin() ; // location of first // element of Pattern end = Pattern.end() ; // one past the location last // element of Pattern //Initialize vector Pattern Pattern[0] = "A" ; Pattern[1] = "B" ; Pattern[2] = "C" ; // print content of Pattern cout << "Before calling next_permutation:\n" << "Pattern: " ; for(it = start; it != end; it++) cout << *it << " " ; cout << "\n\n" ; // Generate all possible permutations cout << "After calling next_permutation:" << endl ; while ( next_permutation(start, end) ) { copy(start, end, outIt) ; cout << endl ; } } Output Before calling next_permutation: Pattern: A B C After calling next_permutation: A C B B A C B C A C A B C B A ... |
| 20.10.2005, 11:22:01 |
start [/forum/topic.php?fid=57&gotonew=1&tid=2032593]: |
47ms |
30ms |
| others: | 202ms |
| total: | 317ms |
