Using TCP Sockets in Borland
Hey, Quick qestion about converting the default server socket component in Borland C++ Builder 6 into using TCP rather than UDP. It appears that UDP is being used and occassionally packets are recieved out of order so I would prefer that TCP was used instead. Is there any way to easily do this without using a custom component or the Windows API? Thanks, Brian ... |
| 22.06.2006, 16:47:53 |
I am not sure if you can use sendto/receivefrom logic in TCP. If you can than you should replace UDP component you are using with TCP. What kind of component for UDP are you using? ... |
| 24.06.2006, 00:24:20 |
I am using the default Client Socket (TClientSocket). I had not heard anything about not being able to use sendto/recievefrom logic with tcp/ip so I will have to look into that too. -Brian ... |
| 26.06.2006, 16:57:03 |
I've checked the source in Delphi (that where it originates from). It is not clear to me both from the documentation and from the source but I believe that TClientSocket is a TCP socket. This suggests that you are in TCP connection already. If this is correct then check if your packets are sent in right order. ... |
| 28.06.2006, 23:44:56 |
start [/forum/topic.php?fid=57&gotonew=1&tid=2030926]: |
57ms |
56ms |
| others: | 244ms |
| total: | 420ms |
