using controls in MFC
Hi All, I need to create a container, like a panel with some other controls on it, like buttons.. How can I do this? Thanks! ... |
| 23.11.2006, 15:37:42 |
What kind of panel would you like to create? Like CReBar or just a frame around controls... -------------------------------------------------------------- [подпись с другого сайта] ... |
| 23.11.2006, 17:03:28 |
You can use, for example, simple CDialog without header. -------------------------------------------------------------- [подпись с другого сайта] ... |
| 23.11.2006, 17:05:28 |
start [/forum/topic.php?fid=57&gotonew=1&tid=2029945]: |
82ms |
40ms |
| others: | 232ms |
| total: | 414ms |
