Контрольная сумма для IP пакета
Сабж. Поможите с алгоритмом )) ... |
| 29.08.2007, 20:11 |
В протоколе IP есть только контрольная сумма заголовка. тынц RFC791Header Checksum: 16 bits A checksum on the header only. Since some header fields change (e.g., time to live), this is recomputed and verified at each point that the internet header is processed. The checksum algorithm is: The checksum field is the 16 bit one's complement of the one's complement sum of all 16 bit words in the header. For purposes of computing the checksum, the value of the checksum field is zero. This is a simple to compute checksum and experimental evidence indicates it is adequate, but it is provisional and may be replaced by a CRC procedure, depending on further experience. ... |
| 29.08.2007, 20:25 |
start [/forum/topic.php?fid=57&gotonew=1&tid=2028279]: |
184ms |
48ms |
| others: | 233ms |
| total: | 522ms |
