Qt, qxmpp: SSL errors
Привет есть код Код: plaintext 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. 15. 16. 17. 18. 19. 20. 21. 22. 23. 24. 25. а вот это я вижу второй день уже: Sat Jul 22 16:57:58 2017 DEBUG Looking up server for domain айпишник Sat Jul 22 16:57:58 2017 WARNING Lookup for domain _xmpp-client._tcp.айпишник failed: Non existent domain Sat Jul 22 16:57:58 2017 INFO Connecting to айпишник:5222 Sat Jul 22 16:57:58 2017 INFO Socket connected to айпишник 5222 Sat Jul 22 16:57:58 2017 SENT <?xml version='1.0'?><stream:stream to='айпишник' xmlns='jabber:client' xmlns:stream='http://etherx.jabber.org/streams' version='1.0'> Sat Jul 22 16:57:58 2017 RECEIVED <?xml version='1.0'?><stream:stream xmlns='jabber:client' xmlns:stream='http://etherx.jabber.org/streams' id='807515066' from='айпишник' version='1.0' xml:lang='en'> Sat Jul 22 16:57:58 2017 RECEIVED <stream:features><starttls xmlns='urn:ietf:params:xml:ns:xmpp-tls'/><mechanisms xmlns='urn:ietf:params:xml:ns:xmpp-sasl'><mechanism>SCRAM-SHA-1</mechanism><mechanism>DIGEST-MD5</mechanism><mechanism>PLAIN</mechanism></mechanisms><c xmlns='http://jabber.org/protocol/caps' hash='sha-1' node='http://www.process-one.net/en/ejabberd/' ver='TQ2JFyRoSa70h2G1bpgjzuXb2sU='/><register xmlns='http://jabber.org/features/iq-register'/></stream:features> Sat Jul 22 16:57:58 2017 SENT <starttls xmlns='urn:ietf:params:xml:ns:xmpp-tls'/> Sat Jul 22 16:57:58 2017 RECEIVED <proceed xmlns='urn:ietf:params:xml:ns:xmpp-tls'/> Sat Jul 22 16:57:58 2017 DEBUG Starting encryption Sat Jul 22 16:57:58 2017 WARNING SSL errors Sat Jul 22 16:57:58 2017 WARNING The host name did not match any of the valid hosts for this certificate Sat Jul 22 16:57:58 2017 WARNING The certificate is self-signed, and untrusted Sat Jul 22 16:57:58 2017 WARNING Socket error: The host name did not match any of the valid hosts for this certificate Sat Jul 22 16:57:58 2017 DEBUG Socket disconnected Я вижу, что она чито-то на русском почти мне говорит, но что не понимаю. Сервер мой, сертификат там лежит, проверял - при изменении пиджины у клиентов перезапрашивают,это работает точно Проблемы где-то между этим кодом и мозгами... ... |
| 22.07.2017, 17:03:00 |
BlackGnomeГуестThe host name did not match any of the valid hosts for this certificate имя хоста, которое указано в сертификате (которое подтверждает, что сервер, к которому ты обращаешься это действительно тот сервер, к которому ты планировал обратиться) не соответствует ожидаемому при прохождении процедуры установки соединения + BlackGnomeГуестThe certificate is self-signed, and untrusted сертификат у тебя самоподписанный, и не вызывает доверия, т.е. сертификат должен быть выдан не самому себе, а уполномоченным центром сертификации, который между клиентом и серверов, является независимой третьей стороной. ... |
| 22.07.2017, 18:20:32 |
CerebrumBlackGnomeГуестThe host name did not match any of the valid hosts for this certificate имя хоста, которое указано в сертификате (которое подтверждает, что сервер, к которому ты обращаешься это действительно тот сервер, к которому ты планировал обратиться) не соответствует ожидаемому при прохождении процедуры установки соединения + BlackGnomeГуестThe certificate is self-signed, and untrusted сертификат у тебя самоподписанный, и не вызывает доверия, т.е. сертификат должен быть выдан не самому себе, а уполномоченным центром сертификации, который между клиентом и серверов, является независимой третьей стороной. Я не понимаю, когда ejabbrd устанавливается, он генерит сам себе ключ? А есть возможность сгенерить внешний БЕСПЛАТНЫЙ ключ? ... |
| 31.07.2017, 15:18:53 |
BlackGnomeГуестА есть возможность сгенерить внешний БЕСПЛАТНЫЙ ключ? можно наверное, тут важно для каких целей он будет тебе выпущен ? В Windows Server можно поставить feature Центра сертификации и выпускать себе самому сколько хочешь и каких угодно НЕ самоподписанных сертификатов. Возможно есть такая же фича и на основе openssl, тебе надо погуглить. С драйверами правда этот трюк не прокатит, им нужен кросс-сертификат завязанный на Microsoft WHQL, но для установки SSL соединения вполне подойдет ... |
| 31.07.2017, 16:02:47 |
start [/forum/topic.php?fid=57&gotonew=1&tid=2018112]: |
28ms |
65ms |
92ms |
| others: | 369ms |
| total: | 630ms |
