ESENT - встроенная в Windows СУБД
Скорее как напоминалка, но "мужики то не знают", что есть такая вещь MSThe significant technical features of ESENT include: · ACID transactions with savepoints, lazy commits and robust crash recovery. · Snapshot isolation. · Record-level locking — multi-versioning provides non-blocking reads. · Highly concurrent database access. · Flexible meta-data (tens of thousands of columns, tables and indexes are possible). · Indexing support for integer, floating point, ASCII, Unicode and binary columns. · Sophisticated index types including conditional, tuple and multi-valued. · Individual columns can be up to 2GB in size. A database can be up to 16TB in size. · Can be configured for high performance or low resource usage. · No administration required (even the database cache size can adjust itself automatically). · No download. Your application uses the esent.dll which comes with the operating system. https://blogs.msdn.microsoft.com/windowssdk/2008/10/22/esent-extensible-storage-engine-api-in-the-windows-sdk/ https://msdn.microsoft.com/en-us/library/windows/desktop/gg269259(v=exchg.10).aspx Сам не тестировал, API выглядит неудобным, но встречал обертки, например для .NET с человеческим лицом. По сути - Key-Value СУБД ... |
| 25.04.2017, 12:07:49 |
Вот нормальная обертка, раз уж упомянул https://www.nuget.org/packages/ManagedEsent/ ... |
| 25.04.2017, 13:16:00 |
start [/forum/topic.php?fid=56&gotonew=1&tid=2015072]: |
74ms |
63ms |
| others: | 247ms |
| total: | 471ms |
