Resource governor for '%1' exceeded SQLCODE -685
Resource governor for '%1' exceeded -------------------------------------------------------------------------------- Item Value SQLCODE -685 Constant SQLE_RESOURCE_GOVERNOR_EXCEEDED SQLSTATE WP009 Sybase error code 13715 ODBC 2 State ERROR ODBC 3 State ERROR Parameter 1 The resource whose limit has been exceeded Probable cause The resource governor for the stated resource has determined that the usage of the resource has exceeded its limit. Плиз, помогите советом отчего такое может быть... горю по времени. Изменения - на клиенте очень много открытых запросов... ... |
| 14.07.2004, 17:05 |
Стало вот такое вылазить окошко. Может где-то можно что-то увеличить? :) ... |
| 14.07.2004, 17:13 |
MAX_STATEMENT_COUNT option - delai = 0. Pomozet? pisi versiju, EBF i OS sledujucii raz. ... |
| 14.07.2004, 17:14 |
| 14.07.2004, 17:16 |
| 14.07.2004, 17:17 |
Nol' ноль сделай :) ... |
| 14.07.2004, 17:18 |
Имей ввиду: But you have to take into account that all prepared statements which can't be held in the cache will be paged to a temp file, resulting in increasing it's size and increasing the time to disconnect because all prepared statements are deleted in the file. Suggested: to check for prepared statements and the existance of corresponding 'DROP STATEMENT' commands. ... |
| 14.07.2004, 17:23 |
start [/forum/topic.php?fid=55&gotonew=1&tid=2014360]: |
135ms |
47ms |
| others: | 205ms |
| total: | 427ms |
