kernel current process (0x409c8cc0) infected with 11
Добрый день! Имеем: Adaptive Server Enterprise/12.5.2/EBF 12061 ESD#2/P/Linux Intel/Enterprise Linux/ase1252/1844/32-bit/OPT/Wed Aug 11 21:36:26 2004 ASE booted on Linux release 2.4.20-8smp version #1 SMP Thu Mar 13 17:45:54 EST 2003. После запуска сервера, все работает нормально минут 5, потом вылетает. В логе кроме этого больше ничего: 00:00000:00000:2004/10/11 18:38:07.81 kernel current process (0x409c8cc0) infected with 11 00:00000:00000:2004/10/11 18:38:07.81 kernel current process (0x409c8cc0) infected with 11 00:00000:00000:2004/10/11 18:38:07.81 kernel current process (0x409c8cc0) infected with 11 00:00000:00000:2004/10/11 18:38:07.81 kernel current process (0x409c8cc0) infected with 11 00:00000:00000:2004/10/11 18:38:07.81 kernel current process (0x409c8cc0) infected with 11 и т.д. В чем проблема подскажите плиз... ... |
| 14.10.2004, 14:06 |
Вот как оказывается: *Urgent from Sybase: "Infected With 11" when Using Multiple Temporary Databases and Caches Summary: When using Adaptive Server Enterprise version 12.5.2 ESD#2, the message "current process (<spid>) infected with 11" may be reported in the error log. (Oct 14 2004) http://www.sybase.com/detail?id=1032749 ... |
| 15.10.2004, 08:20 |
start [/forum/topic.php?fid=55&gotonew=1&tid=2014159]: |
189ms |
58ms |
| others: | 247ms |
| total: | 555ms |
