ASA9.0.2 Глюк при старте сервера
Первый раз такая фигня, причем после перезапуска стало все нормально, сервер стартует с 11ГБ под кэш с опцией -cw I. 11/19 18:34:24. Adaptive Server Anywhere Network Server Version 9.0.2.2451 I. 11/19 18:34:24. I. 11/19 18:34:24. Copyright ¬ 1989-2004 Sybase, Inc. I. 11/19 18:34:24. Portions Copyright ¬ 2002-2004, iAnywhere Solutions, Inc. I. 11/19 18:34:24. All rights reserved. All unpublished rights reserved. I. 11/19 18:34:24. I. 11/19 18:34:24. This software contains confidential and trade secret information of I. 11/19 18:34:24. iAnywhere Solutions, Inc. I. 11/19 18:34:24. Use, duplication or disclosure of the software and documentation I. 11/19 18:34:24. by the U.S. Government is subject to restrictions set forth in a license I. 11/19 18:34:24. agreement between the Government and iAnywhere Solutions, Inc. or I. 11/19 18:34:24. other written agreement specifying the Government's rights to use the I. 11/19 18:34:24. software and any applicable FAR provisions, for example, FAR 52.227-19. I. 11/19 18:34:24. I. 11/19 18:34:24. iAnywhere Solutions, Inc., One Sybase Drive, Dublin, CA 94568, USA I. 11/19 18:34:24. I. 11/19 18:34:25. Networked Seat (per-seat) model. Access to the server is limited to 1024 seat(s). I. 11/19 18:34:25. This server is licensed to: I. 11/19 18:34:25. admin I. 11/19 18:34:25. OSS I. 11/19 18:34:25. Running on Windows 2003 Build 3790 I. 11/19 18:34:36. 11534352K of memory used for caching I. 11/19 18:34:36. Physical memory allocated for images: 11468816K I. 11/19 18:34:36. Address space allocated: 2899680K I. 11/19 18:34:36. Using a maximum page size of 16384 bytes I. 11/19 18:34:36. Starting database "BillingStatServer" (c:\db\oss_stat.db) at Fri Nov 19 2004 18:34 I. 11/19 18:34:51. Performance warning: Database file "c:\db\oss_stat.db" consists of 635876 disk fragments I. 11/19 18:34:51. Transaction log: oss_stat.log I. 11/19 18:34:51. Starting checkpoint of "BillingStatServer" (oss_stat.db) at Fri Nov 19 2004 18:34 I. 11/19 18:34:51. Finished checkpoint of "BillingStatServer" (oss_stat.db) at Fri Nov 19 2004 18:34 I. 11/19 18:34:51. Database "BillingStatServer" (oss_stat.db) started at Fri Nov 19 2004 18:34 I. 11/19 18:34:51. Database server started at Fri Nov 19 2004 18:34 I. 11/19 18:34:51. Trying to start SharedMemory link ... I. 11/19 18:34:51. SharedMemory link started successfully I. 11/19 18:34:51. Trying to start TCPIP link ... I. 11/19 18:34:51. Starting on port 2638 I. 11/19 18:34:56. TCPIP link started successfully I. 11/19 18:34:56. Now accepting requests I. 11/19 18:34:58. A read failed with error code: (998), Invalid access to memory location. I. 11/19 18:34:59. A read failed with error code: (998), Invalid access to memory location. E. 11/19 18:35:00. Fatal error: Unknown device error I. 11/19 18:35:00. Fatal error: Unknown device error I. 11/19 18:35:00. I. 11/19 18:35:00. Connection terminated abnormally I. 11/19 18:35:00. Disconnected TCPIP client's AppInfo: HOST=OSS2000;OS=Windows NT 4.0 Build 1381 Service Pack 6;PID=0x121;THREAD=0xf6;EXE=E:\DBSYNCHO\DBSynchro.exe;VERSION=7.0.4.3421;API=ODBC I. 11/19 18:35:01. A read failed with error code: (998), Invalid access to memory location. I. 11/19 18:35:02. A read failed with error code: (998), Invalid access to memory location. I. 11/19 18:35:03. A read failed with error code: (998), Invalid access to memory location. I. 11/19 18:35:12. A read failed with error code: (998), Invalid access to memory location. I. 11/19 18:35:12. A read failed with error code: (998), Invalid access to memory location. I. 11/19 18:35:12. A read failed with error code: (998), Invalid access to memory location. I. 11/19 18:35:13. A read failed with error code: (998), Invalid access to memory location. I. 11/19 18:35:13. A read failed with error code: (998), Invalid access to memory location. ну и т.д. ... |
| 19.11.2004, 18:45 |
start [/forum/topic.php?fid=55&gotonew=1&tid=2014078]: |
145ms |
31ms |
| others: | 210ms |
| total: | 437ms |
